Parking Sensors
Re: Parking Sensors
'With extreme care'
Gently press the terminal tab. There are normally two travels.
It should come out relatively easily.
If you find yourself pulling the wire too hard, you're doing something wrong.
When reinserting the wires, first check that the tab is at the correct angle. You can use a utility knife blade to reposition it. Gently.
Have a nice weekend!
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Sat Nov 08, 2025 1:52 am Image
'With extreme care'
Ok does it need some other clips to be removed before that step? Besidea that on the picture rhat I pulled of?
Re: Parking Sensors
The connector you're showing looks like a coupling (aftermarket wiring).
Please show it from the front, or tell me the reference number of that connector so I can tell you which tools to use.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Sat Nov 08, 2025 7:51 am The connector you're showing looks like a coupling (aftermarket wiring).
Screenshot_20251108_085631_Photo Editor.jpg (911.84 KiB) Viewed 6795 times
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
Buci wrote: Sat Nov 08, 2025 8:00 am
Re: Parking Sensors
To press the tab...
The original connector is 8E0 972 112, but in this wiring they have used another original 8W0 which is compatible.
Re: Parking Sensors
Since I see you have no experience with VW connectors, you must do this job very meticulously. Do not use improvised tools to remove the terminals or you will end up breaking the connector, ...and the installation is over until 'you install a new connector with terminals'.
It's intriguing that you decided to do this installation without basic knowledge... :lol: I suppose there has to be a first time for doing something unfamiliar.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Sat Nov 08, 2025 8:16 am Since I see you have no experience with VW connectors, you must do this job very meticulously. Do not use improvised tools to remove the terminals or you will end up breaking the connector, ...and the installation is over until 'you install a new connector with terminals'.
Ahhh...So I must give up today from removing it....I do not have real tools for it..there is now improvised tool? Nidle?
Re: Parking Sensors
There are many, all those you have at your disposal and your imagination knows how to handle, but none are recommended.
Don't do it until you have the appropriate tools.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Sun Nov 02, 2025 7:09 pm As I mentioned before, if the bars aren't displaying correctly on the screen, you need to swap the T3/2 wires that run from the PDC sensors to the PDC module. Just use the logic of figuring out which sensor corresponds to the displayed bars.
'For example':
1234 but they're displayed on the opposite side of the screen. It's simple: reposition the T3/2 wires, connecting 4 to 1, 3 to 2, 2 to 3, and 1 to 4 at the PDC unit connector.
Create your own correspondence diagram beforehand.
Ahhjh...wait for the new tool? Okkk..I must this because of my problem with T3/2 wires for the rear..you told me how but I did not know the tool is needed. I checked the pdf scheme and it says that 2, 3, 4, 5 pins are the ones that I must exchange between them. Pin 2 to pin 5, pin 5 to pin 2 etc..whyyyy did they did it in the oposite way?
Re: Parking Sensors
Presumably, the kit you purchased should also include a connector/coupling to be able removing/installing the bumper, you can also swap the PDC sensor CTRL wires there.
If you want, show us the connector/coupling (T6?).
With the right tools and after studying the diagrams, swapping the wires shouldn't take more than 10 minutes... maybe less, depending on your skills with contact terminals.
I've sent you a private message, please check your inbox. Thank you.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Wed Nov 12, 2025 2:42 am Presumably, the kit you purchased should also include a connector/coupling to be able removing/installing the bumper, you can also swap the PDC sensor CTRL wires there.
Sorry but I am confused now. You already told me two posts up and I showed you the connector for the rear senzors that goes in the pdc modul. Six wires in T12 connector. What other connector are you talking about?
Re: Parking Sensors
This T6 (3B0) is the coupling I'm referring to... in case your aftermarket wiring harness has it.
Buci
Drives: 6R 2011
Re: Parking Sensors
Post by Buci »
ciclo wrote: Wed Nov 12, 2025 6:08 am Image
From the picture It seems that I have that conncector on the front senzors and it goes through the engine bax and in to the cabine. I was wondering how will I pull it through in to the cabine? It is really big part.
