Polo 1.2tdi red abs coding has disappeared
Fiz786
- Drives: Polo 6r 1.2tdi red
Hi all I am new to the forum so please forgive me if I make any mistakes.
I lost my key for my polo so I ordered one from the dealers and had a local locksmith code it, when I run an autoscan it comes up with no coding for the abs and they are all zeros? I tried looking online and could not code the module using some of the codes that are out there?
I believe that the long coding is depended on individual cars?
Can anyone please help me.
P.s it's a bit hard for me post the autoscan as I use a laptop that does not have wifi in to connect online. But if mess army I will post.
Thank you so much
Thank you so much
Re: Polo 1.2tdi red abs coding has disappeared
Right, first some questions:-
1) is your car really a 6R or a newer 6R 6C - ie what is the part number of the ABS controller?
2) which version of VCDS are you using as if it is an earlier version, it might not have files covering the later controllers?
3) as it seems like you are a competent VCDS user, surely the first thing you did was to run a full autoscan on that car when you first got it and saved that data?
So, as per above, reprogram the controller from saved data - or get brave and start programming from scratch - or seek help from your VW workshop as it could be that you have corrupted the ABS controller programming.
Send me an autoscan via PM please
Fiz786
hi thanks for you replies, my car is a 6r not the new one i have my auto scan below
VCDS Version: Release 15.7.4 Running on Windows XP x86
Data version: 20160216
www.Ross-Tech.com
Friday,22,July,2016,18:51:20:41525
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBU079562 Mileage: 60940km-37866miles
56-Radio -- Status: OK 0000
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 A HW: 03P 907 425 A
Component: R3 1.2 DCM3.7 H06 9297
Revision: 11002001 Serial number: 00000000000000
Coding: 00114010000500080000
Shop #: WSC 00488 210 82594
ASAM Dataset: EV_ECM12TDI03103P906021A 001011
ROD: EV_ECM12TDI03103P906021.rod
VCID: 264397E95945380E24-8072
1 Fault Found:
16230 - Control Module for Instrument Cluster
U1019 00 [047] - Missing Signal for Oil Level/Temperature
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 60949 km
Date: 2016.07.22
Time: 00:27:55
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 31414 790 31414
VCID: 071DFA6DB28F01063F-8052
4 Faults Found:
03306 - Coding Not Valid
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 106
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:17:38
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x2593
Hex Value: 0x00FF
Hex Value: 0x7F80
Hex Value: 0x7EF9
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 10
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:21
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x1493
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 10
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:21
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B93
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Fault Priority: 0
Fault Frequency: 10
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:21
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x2093
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326B7BB96D8D54AEB8-8066
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2012.05.05
Time: 19:25:37
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 086 H HW: 6R0 937 086
Component: BCM PQ25 M++4 H46 0230
Revision: BD046001 Serial number: 0392 087110352
Coding: 3CB02BBF08A10000003008003D2B0CD00000410F60060000200000000000
VCID: 41892475D82BFF3631-8014
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 1611
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 007 1611
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 007 1611
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 007 1611
Coding: 08BC32
4 Faults Found:
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.21
Time: 00:00:02
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:40
03591 - Control Circuit for Horn
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Time Indication: 0
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 2
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:39
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00JYM20
Coding: 003237
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A9B0359ED1D3C6EE0-801E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB404V0GR3471DD
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405B0F3PEC1IC
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB40650FAMABGEK
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB405N0H1GGJH5V
Part No SW: 6R0 920 961 F HW: 6R0 920 961 F
Component: KOMBI H05 0304
Coding: 440000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 39794C95B8FBA7F679-806C
1 Fault Found:
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 60949 km
Date: 2016.07.19
Time: 19:25:37
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 086
Component: GW-K-CAN TP20 0230
Coding: 002300
VCID: 70EFB1B1A30126BE8E-8024
Component: IMMO H05 0304
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADBA3D98DDDDC6EC0-803E
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10140
Shop #: WSC 13765
VCID: 6DD1A8C52033CB56A5-8038
1 Fault Found:
00816 - Power Steering Sensor (G250)
30-00 - Open or Short to Plus
Address 56: Radio (J503) Labels: 1K0-035-1xx-56.lbl
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2L0337402
Coding: 0500040002
VCID: 6BD5A6DD8A27C566BB-803E
End-------------------------(Elapsed Time: 02:04)--------------------------
the car does not seem to want to start?
iichel i tired sending a pm but I'm un able too as I'm a newbie lol
really appreciate any help i can get from you guys.
www.Ross-Tech.com
1 Fault Found:
Fault Priority: 2
Fault Frequency: 2
Mileage: 60949 km
Date: 2016.07.22
Time: 00:27:55
Revision: --------
4 Faults Found:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 106
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:17:38
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x2593
Hex Value: 0x00FF
Hex Value: 0x7F80
Hex Value: 0x7EF9
000 - -
Fault Priority: 0
Fault Frequency: 10
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:21
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x1493
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 10
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:21
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B93
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 10
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:21
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x2093
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Revision: 0002S 02
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2012.05.05
Time: 19:25:37
Coding: 18BC30
Coding: 08BC30
Coding: 08BC32
Coding: 08BC32
4 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.21
Time: 00:00:02
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:40
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Time Indication: 0
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 2
Reset counter: 66
Mileage: 60949 km
Time Indication: 0
Date: 2016.07.19
Time: 19:25:39
Coding: 003237
Coding: 440000
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 60949 km
Date: 2016.07.19
Time: 19:25:37
Coding: 002300
Serial number:
Coding: 10140
Shop #: WSC 13765
1 Fault Found:
Coding: 0500040002
Long coding:
230224E3417400BBC42A24E882D300921300
Steering angle adaption
ABS module
Login 40168
Channel 66
Keep the wheels straight
Relogin
40168
Channel 60
Relogin
40168
Function 04 channel 103
ABS module
Login 40168
Channel 66
Relogin
40168
Channel 60
Relogin
40168
Fiz786
wow thats great, thanks so much i will go and have bash at it in the morning,
quick question do i enter this coding in the coding section? as in copy and paste? do i need security to do it?
In the long coding section. No code needed
Fiz786
Thanks that worked a treat! My car still wont start! Lol normally your supposed to hear a priming noise from the fuel pump when you put the key on but i cant hear that
I was wondering if you could get hold of the fuse and relay diagrams for it?
Do i need to post a seporate topic??
Hello, greetings to all forum members. Could someone please help me with the long coding for the ABS module of a 2011 Polo 6R?
Thank you in advance.
Sunday,20,January,2019,12:32:38:00007
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WVWZZZ6RZBY178605 License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBY178605 Mileage: 207560km-128971miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 HW: 03P 906 021
Component: R3 1.2l TDI H04 9982
Revision: 11001001 Serial number:
Coding: 00114014002400080000
ASAM Dataset: EV_ECM12TDI03103P906021 001027
VCID: 65C107956461C16246-8030
4 Faults Found:
14108 - Cruise Control Switch (E45)
P0568 00 [047] - Implausible Signal
Fault Priority: 2
Fault Frequency: 7
Mileage: 207561 km
Date: 2019.01.20
Time: 08:31:41
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 27 °C
Intake air temperature: 18 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.460 V
Unlearning counter according OBD: 0
Cruise Control System (CCS): switch position: 00
Cruise Control System (CCS): status: 00000000
Terminal 15 status: On
Sensor for engine block temperature: raw value: 27 °C
Cruise Control System: specified speed: 0 km/h
15890 - Injector: Cylinder 1 (N30)
P0201 00 [191] - Circuit Malfunction
MIL ON - Confirmed - Not Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 5
Mileage: 207561 km
Date: 2019.01.20
Time: 08:34:23
Engine speed: 940.00 /min
Normed load value: 97.6 %
Coolant temperature: 28 °C
Intake air temperature: 26 °C
Voltage terminal 30: 11.617 V
Engine status: Engine running
Rail pressure regulation: status: RPC_TL_IMV_ONLY
Mean injection quantity: 25.5 mg/stroke
Ambient air pressure: 101 kPa
Voltage terminal 30 stabilized: 11.7 V
Accelerator pedal travel-Position: 14.9 %
Starter control: Interlock- or P/N-signal: 00010001
Terminal 87 status: On
Sensor for engine block temperature: raw value: 28 °C
Starter control: terminal 50: 00000000
Gear Ratio: 0
Fuel pressure: 23300 kPa rel
15919 - Glow Plug Cylinder 2
P066C 00 [063] - Short to Ground
Fault Priority: 2
Fault Frequency: 3
Mileage: 207561 km
Date: 2019.01.20
Time: 08:34:27
Engine speed: 1362.75 /min
Normed load value: 83.5 %
Intake air temperature: 28 °C
Voltage terminal 30: 13.796 V
Electric auxiliary heater: relay activation: 0
Glow status: 08
Outside air temperature: 16 °C
15921 - Glow Plug Cylinder 3
P066E 00 [063] - Short to Ground
Fault Priority: 2
Fault Frequency: 3
Mileage: 207561 km
Date: 2019.01.20
Time: 08:34:27
Glow status: 08
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Revision: --------
VCID: 071D2D1DB22D337294-8052
2 Faults Found:
000 - -
Fault Priority: 0
Fault Frequency: 4
Reset counter: 72
Mileage: 207561 km
Time Indication: 0
Date: 2013.06.12
Time: 08:48:26
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x32E7
Hex Value: 0x259C
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7FF8
000 - -
Fault Priority: 0
Fault Frequency: 3
Reset counter: 72
Mileage: 207561 km
Time Indication: 0
Date: 2013.06.12
Time: 08:50:07
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3211
Hex Value: 0x149C
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Part No SW: 6R0 820 045 F HW: 6R0 820 045 F
Revision: 0002S 02
VCID: 3169A3C568295DC26A-8064
Revision: BD046001 Serial number: 0392 057110222
Coding: 24B02BBF08A10000003008003C2B0CD00000410F60040000200000000000
VCID: 4189F305D889CD429A-8014
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Serial number: KU0-KU026.01.1110786
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Serial number: KU0-KU014.01.1112333
Coding: 08BC30
Serial number: KU0-KU012.01.1112874
Coding: 08BC32
Serial number: KU0-KU013.01.1114577
Coding: 08BC32
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00G3HSU
Coding: 003232
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD429EDBF0E1A4B-801E
Serial number: 3575HRB405B0BI7S9H9M
Serial number: 3585HRB40690C15I4OTG
Serial number: 3515RRB405F0510IH0IX
Serial number: 3525RRB40550DOAA9PMZ
Part No SW: 6R0 920 861 E HW: 6R0 920 861 E
Component: KOMBI H04 0304
Coding: 140A00
Shop #: WSC 00788 648 00255
VCID: 377D9DDD8E4D83F224-8062
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Coding: 002200
VCID: 70EF66C1A3A314CA25-8024
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 137607 km
Time Indication: 0
Date: 2013.06.12
Time: 03:27:31
Component: IMMO H04 0304
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74A98D7FEE1A6B-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F6DA5BDEA1D4B327C-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:55)--------------------------
www.Ross-Tech.com
4 Faults Found:
Fault Priority: 2
Fault Frequency: 7
Mileage: 207561 km
Date: 2019.01.20
Time: 08:31:41
Fault Priority: 2
Fault Frequency: 5
Mileage: 207561 km
Date: 2019.01.20
Time: 08:34:23
Gear Ratio: 0
Fault Priority: 2
Fault Frequency: 3
Mileage: 207561 km
Date: 2019.01.20
Time: 08:34:27
Glow status: 08
Fault Priority: 2
Fault Frequency: 3
Mileage: 207561 km
Date: 2019.01.20
Time: 08:34:27
Glow status: 08
Revision: --------
2 Faults Found:
000 - -
Fault Priority: 0
Fault Frequency: 4
Reset counter: 72
Mileage: 207561 km
Time Indication: 0
Date: 2013.06.12
Time: 08:48:26
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x32E7
Hex Value: 0x259C
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7FF8
000 - -
Fault Priority: 0
Fault Frequency: 3
Reset counter: 72
Mileage: 207561 km
Time Indication: 0
Date: 2013.06.12
Time: 08:50:07
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3211
Hex Value: 0x149C
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Revision: 0002S 02
Coding: 18BC30
Coding: 08BC30
Coding: 08BC32
Coding: 08BC32
Coding: 003232
Coding: 140A00
Coding: 002200
1 Fault Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 137607 km
Time Indication: 0
Date: 2013.06.12
Time: 03:27:31
Serial number:
Coding: 11230
Shop #: WSC 31414
Address 56: Radio
Cannot be reached
Why was your coding lost?
Hello, because I changed the instrument cluster and engine control unit
Hola,
The ECU coding is incorrect.
The instrument cluster coding is probably incorrect.
... please show us a photo of the glove box button.
Thanks.
Thanks.
This isn't my glove compartment, but it's similar. I don't have the car here, so I downloaded it.
- full.jpg (273.21 KiB) Viewed 4132 times
Okay, so if the glove box of the 6R where the instrument cluster and ECU were replaced has the 'SET' button for the TPMS system.
These are the codings for that 6R according to the provided autoscan:
01 ECU:
00114010000400080000
03 ABS:
210224E3417400BA842B24E282D600421300
17 Inst Cluster:
140A01
The IMMO part is always a sensitive matter, but since my role isn't to dispense justice (I'm just an enthusiast), and since it's becoming quite clear in today's world who's really stealing from whom (a fact known for centuries, especially in the last century and even more so from 2008 to the present day
), I hope you have enough luck to sort out your technical issues.
If you are kind enough, please report the result for the benefit of all users of this forum.
By the way, VW was so stingy in 2011, selling cars without navigation systems or with absurd radios... making that period of our poor lives a real shi.t. ...how endearing! Even the smallest period of time lived is irreplaceable in our short existential period.
01 ECU:
03 ABS:
17 Inst Cluster:
140A01
Good morning, thank you very much. I'll try it as soon as I get to the car.
Thank you very much.
