Polo 1.2tdi red abs coding has disappeared
Re: Polo 1.2tdi red abs coding has disappeared
Good morning, what happened to me with my car is a long story. I took my engine control unit (ECU) in for cloning, but the technicians couldn't do it. Both ECUs, the one from a junkyard and the original, were damaged, and I had to buy a set in France—an ECU, instrument cluster, and long coding for my engine control unit. Because it has a different VIN, it doesn't work.
Thanks for the clarification... it's good to know.
Based on certain details, which I consider obvious, I already suspected that everything was within some kind of natural order.
Let's hope you soon have your 6R in good order.
Good evening. First of all, my thanks. The long coding works perfectly. I really appreciate it. You're a good person. Thank you, thank you.
Thank to you for letting us know.
Enjoy it!
Enjoy it!
