Multi valves/Multi cylinders
Non-VW related chat - Moderated
bstardchild
Moderator
Post by bstardchild »
Karl_CLCoupe wrote:Anyone remember when manufactuers made a big thing of having 16V engines in their cars? The one that springs to mind is Renault with their 'sporty' 19 16V and Clio 16V. Now it seems like common place to have 4 valves per cylinder.
Karl.
Yeah - seemed soooo much better than just 8V
Nice signature BTW - must have taken some work :lol:
Tahrey1043
Post by Tahrey1043 »
whoops i think i just said up there that a 999cc mpi was likely to be 16v... duhhh :)
mind you theres always that brazilian 16v thousand cc that kicks out more than a G40 when you turbo it - good lord.
(if we talk purely 4cyl for the moment, or you can substitute "SOHC" and "DOHC", whatever)
8v's are good all-rounder everyday engines, nice low down torque but tend to have the power fall off quite a lot at the top end - e.g. mine peaks at 5200 with peak torque about 2800, many others do it about 5000, there's even a few about that have their peak power around 4750 - 4900 and torque about 2500... and that's in a petrol burner! Grunty as anything though and great to trot round town in, just get their asses whipped much past 70mph.
Can use clever tricks however to make them more sporty as there's a lot of untapped potential. GT is a good example... take a regular 1300 8v, give it multipoint injection, give a minor tweak a few other things, suddenly you've got +20hp with the torque holding strong to a good couple thou revs higher... and lots left to give a hardcore modder.
16v's tend to be more performance oriented from the factory, indeed might not be so great at the bottom end of the revs or cruising round the city (well, can be - depends on the setup*) but the freer flow of gases in and out of the cylinder means that the engine can throw out the same strong midrange torque and hold it into the higher revs, producing much more power and allowing lower gearing too. Will whup a similar cc, similar tuned 8v once you're up to A-road speeds, and leave it for dust on the motorway. Power peak tends to be 6000 or more and torque almost exclusively 4000 and higher. Can get crazy power figures out of small cars with the right setup (hence the japanese using it a lot :D)
* just as you can have cammed, ported, etc 8 valves like a traditional hotrod (or indeed a modded G40!) that have a lot of high end power and are lumpy at the bottom, there's enough valvers about with very good all round competence..
carmadaaron
Post by carmadaaron »
more valves mean more power.... what else?
(ie 55bhp 9n has 6v, 65bhp 9n has 12v.....as SiDaBa said earlier)
Prash
Post by Prash »
=more respect =more b*tches 8)
Tahrey1043
55hp 6n = 8v shurely? cuz its only the more modernerer engines wot only have 3 cylinders :D
</pedant>
the bi'tches dont regard if you go stalling it when trying to trickle in traffic in 2nd tho
carmadaaron
if u read carefully, i was talking about a 9n, not a 6n
Tahrey1043
me = teh dumb
sorry thats like the third or fourth time ive done that on the web... i think i have 9n blindness! :oops:
carmadaaron
dont underestimate 3cyl...... this 1 i have is more powerful than my last 4 cyl
:D
Prash
Post by Prash »
Sound good too !
carmadaaron
i believe with more valves, the power peaks higher?
Tahrey1043
um....
yes
and more of it
