Thank you Mr. ciclo. Yes, I will do it.ciclo wrote: Wed Apr 01, 2026 11:32 am Exactly, and that's why the T73b/34 needs to be connected.
Install the wire you discovered yourself. T73b/4 --- T6/3 (1.0mm2).
Take a reading of the BCM's adaptation channels and upload it to a server so we can access it.
https://drive.google.com/drive/folders/ ... sp=sharing
- Disconnect pin T6/3 from the instrument panel illumination dimmer E20 and insulate it
- Disconnect pin T73b/4 from BCM white conector and insulate it (if the pin is already occupied)
- Make a new wire (1.0mm2) and bridge T6/3 to T73b/4
- Upload the adaptations
At the same time, I’ve been diligently studying the VW Polo 6R and VW T6 wiring diagrams as you mentioned.
VW Polo 6R:
VW T6:
Based on the diagrams, I've come up with the following procedure, but it contradicts the bridging of T6/3 and T73b/4. Will it be necessary to add this wiring with relay J602 in the next step as well?
- Disconnect pin T6/3 from the instrument panel illumination dimmer E20 and connect it to pin 1A of relay J602.
- Connect pin 2A of relay J602 to a grounding point.
- Connect pin 3A of relay J602 to terminal +30 behind a fuse (I'm not sure which fuse to choose here?).
- Connect pin 5A of relay J602 to pin T6/3 of the instrument panel illumination dimmer E20.
