2026 Polo Radio
Johntheo1
Drives: 2018 MK10 AW1
2026 Polo Radio
Post by Johntheo1 »
Every time I switch off off the ignition after reversing (this car has reversing cameras) then I have to select Menu then Radio to get the radio stations back up on the informant screen, this also happens even if no reversing occurs or you even switch off the radio sometimes, I want/wish the radio stations to stay displayed except I require some other item on the menu, which I then select.
CarbonChaos
Re: 2026 Polo Radio
Post by CarbonChaos »
Doesn’t the infotainment screen default to the menu screen when the ignition is cycled anyway ?
Someone correct me if I’m wrong .
OomStu_ZA
Drives: 2019 VW Polo GTi
Re: 2026 Polo Radio
Post by OomStu_ZA »
Seems like you may need a software update to fix the fault.
OomStu_ZA
Re: 2026 Polo Radio
Post by OomStu_ZA »
Any update, did you come right?
Johntheo1
Re: 2026 Polo Radio
Post by Johntheo1 »
No, but it still plays whatever station has been selected so I just press Menu, then select radio again.
