Hiya Guys
2020 Polo Match 55000. Today (hot day) engine warning light on!
Car running without any misfires, or any noises.
All levels correct.
Got home, and lifted bonnet - no visual problems - heard what sounds like a very quiet electric motor running (very low noise) rad fan not turrning.
Any immediate ideas come to mind - . When car cools down will check the fan connection. BUT will fan failure be described/included as a legitimate cause for engine light
Ideas welcomed
C
Engine Warning light - any ideas?
Re: Engine Warning light - any ideas?
Read error codes via OBD
CarbonChaos
Anything else is guesswork
- J+silva
- Drives: polo conf.
OBD is the first step if you can't see anything visually.
Polonut
- Drives: 2020 Polo Match 1Litre TSI
As you say OBD is the only way!
when connected - full search revealed the air intake purge sensor at fault. Disconnected, then reconnected - fault then cleared since no re occurace.
Must but one myself - any recommendations for simple but inexpensive unit?
C
C
