COOLANT TEMPS UNDER OBD
Johntheo1
Drives: Polo 2026 95BHP TSI DUSB
Re: COOLANT TEMPS UNDER OBD
Post by Johntheo1 »
Logged some readings today on a 34 mile trip. Polo 2026 95BHP TSI
RPM 1592. Engine Coolant temp 95C. Speed 43MPH. Engine Torque 51.5Nm. Calculated power 11.52BHP. Rad outlet temp 13.2C. Rad outlet specified coolant temp 100.2C.
Engine Oil Temp 77.4C. Cooling fan 1 Activation 10.15%. Cooling recirc pump2 64% (MPG for the trip was 62.5MPG) Ambient 10C.
The fan runs continuously from engine start even though 10% speed won't consume much power.
Also surprising is the low oil temperature at 77C, would have expected it to be ~ at the engine coolant temp or a bit higher, say 100 to 105C like my 2019 65BHP Polo.
Radiator doesn't have to work very hard either with a outlet of 13.2C, the highest was 15C during the trip.
If someone tells how to download a XL file, I will attach the logged data, might be of interest??
Also see that when cruising along at 40MPH and when I switched on the A/C, the "Coolant fan activation requested by A/C" the fan speed went from 10% to 30% but I only left it switched on for a few minutes so it may have reduced the speed later, will test that for a longer period sometime.
toadJo
Drives: POLO GTI 2011 CAVE 180PS
Post by toadJo »
export it then open it with excel
Johntheo1
Post by Johntheo1 »
what do you mean export??
I have it as csv file in the VCDS folder and because I edit it, I have it saved (" Save as") as a excel workbook, but its not accepted when I try to download it.
