gearbox oil filler
deadcat
gearbox oil filler
Post by deadcat »
Anyone take a picture of where the filler is for the gearbox fluid so I know Ive got the right one?
Ta.
pettsy
Moderator
Post by pettsy »
Don't do it where i said, because i have been mis-informed :oops: :evil:
sorry!
hardhitter
Moderator
Post by hardhitter »
Not really
Look where the n/s driveshaft is, next to that.
Theres two, the top one is where you fill up, the bottom one where you drain it.
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
Dont put any oil in where pettsy said whatever you do! Thats an inspection hole for the clutch!. where the driveshafts bolt to the gearbox there are two huge grub screws on the side of the shorter driveshaft. The upper one is the filler plug and the bottom one is the drain. The oil level should be at the bottom of the filler plug hole.
metz
Moderator
Post by metz »
Hahaha nice one mr petts :-)
even i knew it wasn't for putting oil in and i'm dumb. :-D
Karl_CLCoupe
Post by Karl_CLCoupe »
It would make for interesting gear changes don't you think? :lol:
Karl.
LogIK
Post by LogIK »
A lot of motorbike clutches are actually wet (submerged in a bath of oil,) which I find very strange.
But yeah, don't be pouring oil in that hole!
Tahrey1043
Post by Tahrey1043 »
i'd appreciate someone taking a picture showing how to actually get at the blessed thing - seeing it isnt so much of a problem :)
GroovyCarrot
Sponsor
Post by GroovyCarrot »
I'll try to get you a photo of it tomorrow afternoon. Mind you, now it gets dark around 4:30 it may not come out great :(
Tahrey1043
make sure you put the wrench in the hole without removing the crap-catcher :D
ps still havent seen any of those wheeltrims about - sorry :(
GroovyCarrot
Sponsor
Never mind, if you let me know your details I'll send yours, no point me keeping them :)
pettsy
Moderator
Post by pettsy »
b*****d!
i was told thats where ya fill it up :oops:
good job im lazy and haven't tried it :lol:
LogIK
Post by LogIK »
Right, I've just taken one now in the pitch black, but I think you can make it out pretty well.
That is the filler plug. The drain plug is below that and looks exactly the same.
polo_GT
Post by polo_GT »
How would you fill the gearbox up with oil though as the hole is in an awkward place. Just read in haynes it saids to put 3.1 litres in a 5 speed, is that right as you know what haynes are like?
Would you use the same oil as what is recommended in haynes?
Tahrey1043
Yep, thats the one, i just cant get it to reach. Guess I need to get a flatter headed driver, but thats extra cash which a better technique may solve for free :D
(thinking: adjustable wrench on the hex fitting)
The figure in haynes is probably quite approximate, i just bought 3 1-litre bottles of 80w90 from a local supplier (there's not many grades to choose from really) to fit the 2.8 L it specs for a 4-speed. The idea is to get the top bolt off (so you know that you can), open the bottom one and let it drain, then replace the lower bolt, fill through the top hole until you can't fill no more, and replace the bolt. You might want to get 4 bottles in case you spill some :D
