Diesel owners, comments on running costs/economy please.
nuttinnew
Post by nuttinnew »
I keep thinking about getting a diesel for the economy (ideally a mk5 Colour Concept TDi :P ) and have pondered an engine swap with 1 .9 SDi as they're reasonably cheap and easy to get and came in a mk4 originally so fitting would be a doddle. My mk4 is an early 1.3 and it seems to average 40-45mpg which isn't bad but it has more motorway use of late than is normal for me, how would a diesel compare?
The car gets used for normal boring daily transport and gets driven with restraint.
I've been playing with some figures to try and guesstimate the difference in running costs, please tell me how wide of the mark I am :D
I'm assuming similar servicing, insurance and fuel-per-gallon costs, basing mileage at 10000 miles per year which seems reasonable.
1300.
£100 road tax
40 mpg
10000 miles at 40mpg would require 250 gallons of fuel.
At a cost of £3.95 per gallon (86.9p per litre) 10000 miles worth of fuel would cost £987.50.
1900 Diesel
£180 road tax
50 mpg
10000 at 50 mpg would require 200 gallons of fuel.
At £3.95 per gallon 10000 miles worth of fuel would cost £790
Whilst there is saving of almost £200 on fuel costs this is countered by more expensive road tax which would work out at a total saving of only around £10 per month...
At 60mpg the saving is around £20 per month but is that a realistic average figure from a 1900 diesel? Is £20 a month worth worrying about? If I were to pay an extra £20 per month it would probably cover the extra needed by a VR, of course one of those would cost more to insure and service.
All opinions and comments welcome and wanted, help me get my head round this please !
Josh_PoloGTi
Site Admin
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
I think I'd stick with the 1.3
david burton
Post by david burton »
you're getting 45mpg and want more?!
Be happy with that, save the money, the hassle, the pain of selling it on (I wouldn't buy a conversion) and no doubt the insurance will be a little higher. I don't think you'd save in the end - things tend to be more expensive for a diesel, and components wear a bit more due to the extra weight.
HTH! 8)
nuttinnew
Post by nuttinnew »
david burton wrote:you're getting 45mpg and want more?!
Ah but the last couple of tankfuls have I think unrepresentative of my normal usage, they've been long motorway runs at slow speeds so the engine has been fully warmed and only subjected to light loads whereas I normally only do very short stop-start journeys where I'll be lucky if it gets off of choke; if I can get the same economy under those cicumstances I will extremely happy believe me :D
I also wonder though if an 'economical daily driver' is really that for the sake of an extra 10-15mpg working both ways i.e. if the savings over something that does a few less mpg isn't that great then why not get summat a bit speedier and more interesting? Hmmmm...
david burton
That's the spirit!
get a 16v-er
for the difference - 200 quid between a diesel and 1.48v, then the 16v is about another 5-10mpg less (high twentys to high thirties)... so you're looking at about another 100 quid a year
definitely worth it! 30p a day 8)
nuttinnew
Post by nuttinnew »
Is that all you can get out of a 16v? :( What are they like on a run? Tbh I need to average about 40 to be able to afford a car, I don't earn a great deal. The problem with something a tad sporty in the 16v vein (i.e. thrives on revs) is I'll never end up driving it sensibly, something that's a doddle in a plodder. My previous GT could end up giving some frightening low mpg figures. Usually while harrassing Cooper Ss so I had a smile on my face and I admit Herr Schrick isn't overly concerned with economy but still...
david burton
someone has got 45mph once, and on a motorway I've got 40mpg at 75.
but as soon as you open it up.....
KITT
Post by KITT »
david burton wrote:for the difference - 200 quid between a diesel and 1.48v, then the 16v is about another 5-10mpg less (high twentys to high thirties)... so you're looking at about another 100 quid a year
Second the 16v option :D Mine does just under 40mpg and that's on a 25 mile commute with 5miles in stop start traffic. Red line it most of the time so if I took it easy would see more. Also, running it on super unleaded seems to improve the ecconomy :)
david burton
KITT - that's darn good! I should try that - does it work out better overall (i.e. pence per mile for super?)
at 80mph I get about 35mpg, never falls below 33 but I do do a lot of motorway miles. I should be getting more mpg! what's your commute like?
KITT
Post by KITT »
I know! I only worked it out last week as I was thinking of getting a different car in the new year and wanted to know what my 16ver was doing. I fill it with ~42lt and get ~370miles to a tank. There's a handy converter here:
http://cheekyink.co.uk/mpg/MPGCalculator.htm
My commute's mainly along the A38 into Bristol with heavy traffic the closer to Bristol you get, where it turns to stop/start for about 5 miles. There a few miles of country roads too near my house where I like to give it some beans :D I can honestly say I don't drive it economically and tend to hold onto the gears when accelerating. I recon 450 out of tank could be possible with careful granny driving ;)
The super unleaded made a little difference but not really that much to be honest. It has helped with the pinking I some times got going up hills in the morning. Also seems to have given it a little more go at the top of the rev range >4500rpm :)
david burton
So how much extra mpg did you notice with super? You'd have to get about 8% more mpg for it to be worth it (on costs alone)
do a proper check - fill to the brim, then fill to the brim when you come to refill it.... I'm curious / jealous!
KITT
Post by KITT »
david burton wrote:So how much extra mpg did you notice with super? You'd have to get about 8% more mpg for it to be worth it (on costs alone)
I doubt it was as much as 8% to be honest but I am getting a very consistant 40mpg :) I always reset the trip when I fill up, always put between 40-43lt into the tank and get between 360-380miles out of it. When I first got the car I used standard unleaded and got over 400 miles usually. Then it dropped to under 400miles at which point I switched to super unleaded. Initally, it went back over 400miles but then steadily decreased as the traffic's got heavier these days :(.
It's been doing 40mpg for the last 6 months so I think it's settled now :) I should add the car had only done 1200 miles (owned by some old dear) when I got it just over a year ago and since then I've added 14000 miles.
srbpower
Post by srbpower »
I run our polo on super and I think it did around the 375 mark on a full tank (So full no more fuel would go in :twisted: ). But a least half was town driving. Have been quite shocked at how good the 1.4 16V is on fuel. I was expecting quite a bit less. Spose she does drive like a girl :wink: :twisted:
I did notice a big difference after it was treated to full filter, plugs, belts and oil change. Plus the fuel line were flushed though.
Anyway I don't know what you are all moaning about my car has just managed just over 150 miles on 45 quid of super :roll: :shock: :cry:
Si :)
KITT
Post by KITT »
srbpower wrote:Anyway I don't know what you are all moaning about my car has just managed just over 150 miles on 45 quid of super :roll: :shock: :cry:
:shock: That makes my other car look positively green!!
Average 20mpg, dropping to single figures on track :cry:
What you got to better twin Webers then? ;)
srbpower
Post by srbpower »
SR20 with nice not turbo popping flames all day :lol: :lol:
Nice car by the way, been in a carbon bodied one with a hyabusa (spelling? ) engine 8) They are just so much fun :twisted:
Si :)
