doug&dan wrote:looking like a tasty engine!
doug&dan wrote:a friend of mine has 3 X police senta's
Is he a Autobahnstormers member?
doug&dan wrote:1 of them was an un marked one and still has the flashing lights under the grill! it also still has the manual gearbox which, i believe can only b found in police spec ones!
They don't normally forget about things like that when they decommision them..... I've owned 2 Ex polac ones - one did have a gun rack mounting left in the boot cos to get it out they would have had to unbolt the fuel tank!!!
Manual Gearbox can be found in non Police spec cars - it was a no cost option from new - just not that many people specified it.
The manual box isn't that good and a power is fed through a spring damped flywheel which often breaks up internally leading to a lot of driveline shunt - it's also daft gearing - 150 mph on the limiter so thats why most people think they are tunned.
doug&dan wrote:O and its still fulled tuned for the police! 6 cylinder, 24v 3 litre! rear wheel drive! you can imagine the fun!
(eventually, i hope he'll let me drive it!)
Contrary to common belief they are not chipped or tunned (see gearbox comments earlier) - but they are very light with no electric windows, leather, heated seats (cept in a few of the last L & M reg ones) and very very little sound insulation - even the carpets are thin. Less weight means the 204 bhp hasn't got to work as hard - hence better performance
