lost locking wheel nut
desgreen
Post by desgreen »
I have lost the little nut which takes off the locking wheel nut off my wheels!!! I have Audi S3 alloys on now, any ideas of how I can fix this problem?? Having a crap day as well!!! :(
bstardchild
Moderator
Re: lost locking wheel nut
Post by bstardchild »
desgreen wrote:I have lost the little nut which takes off the locking wheel nut off my wheels!!! I have Audi S3 alloys on now, any ideas of how I can fix this problem?? Having a crap day as well!!! :(
OMG - that's not good news :shock:
Are they the pin type or spline type
Did you not keep the slip of card with the Key code on it so you can order a new one?
I always keep the spare bolts in the original packaging for wheel bolts and the key code key in that - learnt the hard way you see!!!!
Pin type you can sometimes get away with a one size fits all socket (the ones with lots of spung loaded steel rods that allow the socket to grip even a horribly mullered nut
Spline type - never found any way of getting one of them out without teh proper key except the time honoured method - Electric drill and mega sharp bits
Good luck :?
Nelson_Wilbury
Moderator
Post by Nelson_Wilbury »
Your dealer will keep a master set. They will be able to order a replacement key for you (about £12.00).
desgreen
Post by desgreen »
I really duuno, Kwik fit says they could have tried using the method you said but its the wrong nut so they need the exact one. Where can I get one from???? I dont have any info on this locking wheel nut and to be honest never knew they were on!!
desgreen
Post by desgreen »
Hi Nelson
Do I go to a VW dealer or Audi dealer?? The wheels are S3.
pettsy
Moderator
Post by pettsy »
i'd say a vw dealer as i guess the vw bolts will have been used :wink:
