g40 brakes
lord_sharpy
g40 brakes
Post by lord_sharpy »
im going to get my set of g40 front brakes in the morning to convert my gt to vented discs, im getting calipers, pads, discs and bolts. im hoping they should go straight on, anything else i need?
cheers
james
Karl_CLCoupe
Post by Karl_CLCoupe »
You using the G40 carriers with those, or will you be using the GT ones?
Karl.
lord_sharpy
carriers
do i need the g40 carriers or can i use gt ones, i should be getting the carriers i think off the g40.
DanW
Re: carriers
Post by DanW »
lord_sharpy wrote:do i need the g40 carriers or can i use gt ones, i should be getting the carriers i think off the g40.
You'll need the carriers, as there different
optima21
Sponsor
Post by optima21 »
no you dont need the carriers the GT ones will be fine as I'm using G40 calipers and GT carriers, but you'll probably be better off if you get the g40 slider bolts
lord_sharpy
bolts
i take it the sliding bolts hold the calipers on, i should be getting everything.
lord_sharpy
BRAKES
just picked them up, need a good clean and service and give them a paint up. got good pads but discs aint much good, anyone used those grooved discs from euro car parts £29.96 and not classed as a modification.
hardhitter
Moderator
Post by hardhitter »
don't bother with grooved discs, you wont really benefit from them. I would just get standard brembo vented discs from gsf with pagid pads or similar.
lord_sharpy
discs
yeh i was lookin at prices, i think its gunna have to be standard discs, the pagid fast road pads are quite good value though.
the calipers did have braided hoses on but the **** at the breakers cut them, so il have to have standard ones now.
Steve_O
Post by Steve_O »
Hmm, surely whilst you're at it you may as well get some new braided hoses?? Extra expense I know - but may as well do it now!! :?
*Oh - boo to the breakers for cutting them!! :x
DanW
Post by DanW »
optima21 wrote:no you dont need the carriers the GT ones will be fine as I'm using G40 calipers and GT carriers, but you'll probably be better off if you get the g40 slider bolts
whoops thought they were different
gtjoe
Post by gtjoe »
them pagid fast road pads are ok, but they take 2 long 2 warm up if u know wot i mean.
