Horrible noise
Horrible noise
Turn on polo after our first bit of snow, and the engine is making a noise like a old tractor at tick over, rev up to about 2000rpm and it goes away. Kinda hoping its just some to do with the cold. still seems to perform as normal.
Any ideas? Cheeres
Neil
Any ideas? Cheeres
Neil
I get this nasty noise sometimes (usually at completely random times) and makes a sound like a proper diesal death rattle when starting up doesn't it ? IIRC its the center exaust baffle/silencer having a bit of a rattle, probably something to do with the exaust brackets that seem to have a problem of corroding on the gti's, i've had it a few times and I think its just one of those things (another quirky feature of the gti maybe ?) and wouldn't be worried about it, u probably won't hear it for a long time again.
Hehe, "I demand a GTi for my courtesy car " - that'd be awesome. I bet you got teh 9n tho
My GTi does that same old "tractor rattle" for a split second on startup sometimes, like Prash says I reckon its to do with the exhaust rattling a little - been mentioned on here somewhere before IIRC.
Let us know what the diagnosis is
It wasn’t just when I started it up. It was still doing it after a 4mile drive to my girlfriend’s house. Then on the way back it seemed to get worse.
My dad said when he was with it at the dealers the head mechanic came over and was talking to the vw assistance guy, and said "its probably the cam belt tensioner there prone to braking on these"
I've herd people on here say about these braking before, and the noise is coming from the right area. They’re going too look at her today.
And having a fiat makes you appreciate VW build quality soooo much more I can only race HGV's off the lights now
..... Especially over speed bumps tooEveryone knows a hirecar is the fastest thing in the world on four wheels!
This topic has been REPETEDLY analyzed and partly solved.
The sound is caused by the heat shield covering the catalytic converter.
The choices are
1)Remove it (unknown what effect it will have on heat transfer and the car itself)
2)Try to use noflamable insulation matterial to put between the shields contacts and the chassis. (done it but works partly...)
Don't change the shield...I did and it was costly and unsuccessfull.
Hope it helps..
The choices are
Hope it helps..
Kool. useful info! the problem with mine was confirmed as the cam belt tensioner collapsing. Hopefully they've changed the cam belt aswell, any one know if this will save me any money on my 40000 mile service which is due in the summer.poussou wrote:This topic has been REPETEDLY analyzed and partly solved.
The choices are
Hope it helps..
How many miles?
How many miles has your GTi done when the cambelt tensioner collapsed?
Seems this is another common problem with the Polo GTi - lots of people on this forum have reported this problem - wonders whether VW Customer Service should be made aware, after all, if this is a manufacturers fault as it appears to be, then as it can cause major damage to a 16V engine, and so VW should be replacing these free of charge with new ones that don't collapse.
If we make representations to VW Customer services about our concerns regarding this, then they might do something about it before all our VWs are subject to this dangerous cambelt tensioner collapse and subsequent engine problems.
What do you think?
What do you think?
Sounds like a plan - you might want to start a new thread and get it stickied like the pedal box thread it would indeed be useful to know more about the problem and who's had it.
Mine went at about 53-55k iirc, but have the paperwork to go check on. There are at least four GTi owners on here who've suffered this failure so would be good to see if we could put a case together!
