electrical help required
my brother has a 1994 mk3 coupe which had a small electrical fire in the scuttle area.
after the fire with the burnt out wiring still in the car the following was happening:-
1) fuel pump under the car constantly running
2) radio turned off when you opened the door
we removed the burnt out parts of the harness and replaced them with good wiring from another polo of the same year. all the connections are good. when the battery was connected the pump didnt run, result.
turned the ignition on and there was no life from the pump at all. so the relays were checked with a multimeter, no obvious problems with the relays. next was the fuse. across the 2 wires the meter picked up around 6v (seemed odd to me).
then we checked that the fuel pump actually worked, so a feed was taken direct from the battery, +ve to +ve earth to earth and the pump ran.
upon closer inspection of the harness to the ECU the number on the replacement harness was 357906373 and on the original harness was 3A0906373 - does the fact that these number are different make a difference?
i'm quickly running out of ideas about this so any help is greatfully received.
amstrange1
amstrange1
Here's the pics of the haynes (with color). On the first image, fuse 1 voltage reading is around 6V, any ideas as to what could be causing this as I'm told that I should be getting 12V? The wire to the Lambda probe is a twin core wire with waht appears to be shielding on the inside of the main cover. Should this shielding be connected to itself (I had to cut it and strip it back to facilitate the reconnection of the enclosed wires)
My brothers 1.0 Coupe
Donor vehicle
Donor vehicle
