Knocking noise from engine ( I think) help
Chat about your MKI or MKII Polo (86 and 86F)
Maker Boy
Post by Maker Boy »
hi all im new to this forum so first of all hi to everyone.
I have a Mk2 polo 1.3 cl i have had it bout 2 months now and its a good car but as off last week there has been a knocking noise from within the engine (i think) it is not consistant and some times it goes away it changes some times when revs are appllied does any body have any ideas on wot this could be.
Thanks in Adavnced all :)
86C
Post by 86C »
The Polo engines have an inbuilt "rattle" anyway. This is usually much more noticeable when the engine is cold and lessens when it warms up.
Could also be big end bearings. Does it make the noise under load or on light throttle?
Maker Boy
Post by Maker Boy »
hi thanxs the knocking happens all the time no matter load or throttle setting some times it will go away but only for a couple of secs.the engine used to be really quiute
ste mk1lx
Post by ste mk1lx »
a bit of a obvious answer but have you checked the oil level?
Maker Boy
Post by Maker Boy »
yup thats the first thing i did and the oil is fine its going for an oil change and to be cheacked over hope its not to major a job :(
ill tell u all wot the problem is tomorw
k4lps
Post by k4lps »
could be the center box rattleing happens to mine every time i drive it hard
GroovyCarrot
Sponsor
Post by GroovyCarrot »
Just to be a bit pessimistic, big end / main bearings would be my first thought. How many miles has it done?
polock
Post by polock »
Woah! was just about to put that :shock: :D
Tahrey1043
Post by Tahrey1043 »
86C wrote:The Polo engines have an inbuilt "rattle" anyway.
They do? :) Never noticed much rattling except for when badly labouring it (for.. um... testing purposes... yeah... that's right... testing... ahem).
Or do you mean the chiahua "growl"? :lol: (damn it sounds loud when i give it a battery-topup idle now!)
take it to a garage and see if you get given that immortal dark-comedy line... "your big ends gone, mate"
GroovyCarrot
Sponsor
Yeah, they don't tend to have an inbuilt knocking noise.. a bit of clunking is common on very high mileage polos when they're cold, you might get a bit of tappet noise if it's been stood for a long time, and the oil pump will sound like it's on its last legs for the first few seconds from cold, but there shouldn't really be a clunking, knocking noise that stays when it's being driven.
