I thought all the saloon 1.3s were NZ? as it was only available at H/very early J plate unless it was a late car with a AAV but not sure.
didnt know about the rear seat vertical section!
I believe the glass except the back window is the same as a coupe so you can fit the green tinted glass out some coupes.
Last year there was a saloon in the local scrapyard and it had door speakers in leather surrounds built into the doors - it looked very profesional! and had the two in the dash so a presumed all saloons had them, but i thought sound distribution would be very poor. I went back the next day for the doorcards and speakers but the car was crushed!
if only i knew it was a mod back then !
On the parcel shelf/flat area behind seats could speakers be fitted or is there a metal plate below perventing it?
didnt know about the headliner being possibly the same as a coupe - would be good to know i will check etka!
Reason for all the questions is I am thinking of making a GT saloon with all the proper GT parts as it would be slightly different. i know others are about (Mr Metz
etc) but fancy making my own version.
