strange noise
1litreheater
strange noise
Post by 1litreheater »
:roll: Cheers for all the replies on my alloys question, im now gonna get some 16's and lower it about 40-50 mm !
Another question, when im reachin about 40 mph theres this strange windy noise as if theres some air whistling through somewhere, any body know of this or had it before ???
italvisions
Post by italvisions »
could just be that one of the door seal doesn't fit correctly and needs replacing! when you're driving around try and pinpoint roughly where it comes from!
mppolo
Post by mppolo »
i think i get the same, is it when you put your foot on the gas, and when u take it off it stops. it sounds like it is coming from the right left side of the engine. i think it might be a hole in a breather pipe, but im not sure
1litreheater
im not sure if its when i put my foot on the gas or just when im going along, ill check tomorrow and get back to you ! however i think ive found the problem, well i hope i have, theres a flappy bottom door seal on the left door so il change that and hopefully the sound will go !
