Creaking Clutch
tempo
Creaking Clutch
Post by tempo »
When using my clutch pedal it makes a horrible creaking noise, i'v recently had a new clutch and clutch cable but it still makes the noise, anyone had the same problem? If not anyone know what it may be?
dubbprince
Post by dubbprince »
i think its just your pedal on the pedal box, i would of thought it was your clutch cable...but you had it changed,so check the cable connection at the pedal and grease it up mate.
Sanj.
tempo
Post by tempo »
took the pedal out and cleaned it out was full of crap greased it up and was fine for about a day now its creaking again :x
david burton
Post by david burton »
it's probably the mechanism the pedal connects to - my bird's car does it, and my old polo did it. get some oil on the mechanism. worked for me!
