Vag-Com - Central Convenience Module - No Comm's
inder
Post by inder »
Trying to talk to the Central Convenience Module in my Polo 1.4 Year 2000, but Vag-Com keeps giving the module does not respond error :(
I've tried removing the battery to 'reboot' it, but it has not done the trick - just meant i have to put the radio code and clock back in :roll:
also saw removing fuses may do the trick - which ones? #s?
please help! i need access to it to setup anti hijack at least :(
can talk to other modules (well Instruments) so cable and connection is fine
workinprogress
Post by workinprogress »
have you tried:-
25- immobilizer
35- central locking (might be this one)
6n2 run of the central locking pump in the boot so its worth trying different channels
