cheap ignition leads
just been to my local motorworld in hinckley, needed some new leads. he rang his supplier and i got a set of champion triple silicone leads for £9.99 all 5 leads. how good is that, they arent the tailor made set but are listed next to the gt in the champion catalogue, so they will definately fit, worth a try if you need some!
- Moderator
NOOOOOOOO! don't buy them!! They're the worst leads known to man.
you'd be better off going to a scrapyard & finding a 2nd hand set of VAG leads in there, seriously!
A mate of mine bought a GT not long ago which had some running issues. The previous owner had obviously tried fixing it on the cheap & had fitted some champion leads. They are so badly made & flimsey you couldn't even push them onto the spark plugs properly. The first thing I did was throw them in the bin for an old set I had off my G40.
Get some Beru ones from German&Swedish - about £30.
