[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Door glass - UK-POLOS.NET - THE VW Polo Forum
My young sons Mk2 polo drivers door glass was smashed last night, does anyone know if the glass from a later model will fit ? before i do a tour of the local breakers.
dpm wrote:My young sons Mk2 polo drivers door glass was smashed last night, does anyone know if the glass from a later model will fit ? before i do a tour of the local breakers.
you may need to swap the rubber seals around but otherwise it should be ok. There are some mk3 coupes that have flush fitting windows - you need to avoid these as they wont fit (i dont think) unless you keep the rubber that they come with.
The front end glass is all the same really between mk2 and mk3.. the rear end glass I believe is the same for coupe and saloon models but I don't think it's the same between mk2 and mk3s.. or something like that. Certainly the front drivers window will fit though.
