9N3 rear lights
yeah i no wat u mean, that polo in the first pic, has a mercedes set of mirrors grafted on there!
extreme but tasteful!
http://www.polo9n.info/polo-79.html
This guy's had the side repeaters blanked off the wings as well. Expensive. You'd face this problem if fitting 9N3 (if that's what it's calledwoody wrote:yeah i no wat u mean, that polo in the first pic, has a mercedes set of mirrors grafted on there!extreme but tasteful!
Deek.
the "M"s at the end of the part numbers refer to LHD. I'm not sure but I guess "N" refers to RHD cars, but you might want to double check.dxg wrote:But you should note that these lights are asymetrical (i.e. fog light on the offside and reversing light on the nearside, replaced with reversing light on the other) -- you'll need to make sure those part numbers are for the UK lights.
Deek.
so it would be
Left: 6Q6 945 095 N
Right: 6Q6 945 096 N
I installed my 9n3 rear lights today, and put together a small DIY guide for it:
http://students.sabanciuniv.edu/~yetkin ... 0guide.pdf
i hope it is going to be useful for those considering this mod.
Yetkin
Yetkin
carmadaaron
bsodmike
Wow, I want those wing mirrorsdxg wrote:This guy's had the side repeaters blanked off the wings as well. Expensive. You'd face this problem if fitting 9N3 (if that's what it's calledwoody wrote:yeah i no wat u mean, that polo in the first pic, has a mercedes set of mirrors grafted on there!extreme but tasteful!
http://www.polo9n.info/polo-79.html) mirrors to a 9N - unless, of course, you'd be happy with two repeaters...
Deek.
The wing mirrors are really nice, actually. They're lit by an LED in the outer most corner, then there's a series of "ribs" on the glass inner surface that diffuse the light at intervals along the underside -- same principle as used by angel eyes. The led itself is covered by a little section of chromed metal under the glass. I've got close-up pics that should be on the site be the end of this weekend.bsodmike wrote:Wow, I want those wing mirrorsdxg wrote:This guy's had the side repeaters blanked off the wings as well. Expensive. You'd face this problem if fitting 9N3 (if that's what it's calledwoody wrote:yeah i no wat u mean, that polo in the first pic, has a mercedes set of mirrors grafted on there!extreme but tasteful!
Deek.
Deek.
