Gearboxes, gear oil, and levels
Le_Combattant
Re: Gearboxes, gear oil, and levels
Post by Le_Combattant »
I just ordered 4 bottles of Top Tec MTF 5300 70W-75W.
But I just founded also MOTUL GEAR POWER FE 75W with almost the same specs...
My god, this story has no end :shock:
Bepis
Drives: 2017 6C GTi Manual
Post by Bepis »
There are already 8 pages of forum posts on just gear oil so a few more wont hurt :lol:
JiSingh1
Drives: 6C 1.0TSI 110BHP
Post by JiSingh1 »
Bepis wrote: Thu Dec 28, 2023 12:52 pm There are already 8 pages of forum posts on just gear oil so a few more wont hurt :lol:
Never ending story thanks to the viscosity and chemical mixture differences ! Makes it hard to choose an oil even when it meets the VW specs.
I do not fancy spending £150 on 3l of original VW oil.
Le_Combattant wrote: Thu Dec 28, 2023 9:54 am I just ordered 4 bottles of Top Tec MTF 5300 70W-75W.
I saw the MOTUL one yesterday .. but oh well I've already found enough, lol.
Will you be using the MTF 5300 soon in your gearbox & comparing it to the FUCHS?
Le_Combattant
JiSingh1 wrote: Thu Dec 28, 2023 12:58 pm
I think yes.
I ordered more bottle than required to "flush" the gearbox.
Because of the s**t design, all oil can't be drained. So on the firt fill, I will drive the front wheels to "mixe" the oils and after drain the maxium I could and then, put new fresh oil.
JiSingh1
Post by JiSingh1 »
Le_Combattant wrote: Thu Dec 28, 2023 4:17 pm I think yes.
Ok that'll be nice to know. I shall wait before I order oil then, you can be the tester for us all, lol.
Is it not possible to drain it all with a tube and vacuum?
Le_Combattant
JiSingh1 wrote: Thu Dec 28, 2023 5:49 pm
I never tried with a vacuum but it's possible to remove more by removing some screws at the bottom.
JiSingh1
Post by JiSingh1 »
Le_Combattant wrote: Thu Dec 28, 2023 6:15 pm I never tried with a vacuum but it's possible to remove more by removing some screws at the bottom.
From the little cap at the bottom? I always wondered what that piece is, but the cost of the sealant for it is expensive if I am correct.
Another thing is, it seems the original VW oil is not a pure synthetic, but is a Ester based formulation, from what I have been told.
https://bobistheoilguy.com/forums/threa ... st-6734292
Le_Combattant
JiSingh1 wrote: Thu Dec 28, 2023 7:15 pm
Not the cap, I tried on the first oil change but I didn't remove it.
Okey, thanks for the link I will check this out.
EDIT: Now I'm reconsidering my purchase.
Liqui Moly or Wolf 75 FE ?
JiSingh1
Post by JiSingh1 »
Le_Combattant wrote: Thu Dec 28, 2023 7:28 pm EDIT: Now I'm reconsidering my purchase.
Why are you reconsidering?
The Liqui Moly is only recommended for VW it seems, whereas the Wolf is more rounded for other brands.
Also, the formulations seem different. Liqui Moly is the brand I have heard of before, but never heard of Wolf before.
Le_Combattant
JiSingh1 wrote: Thu Dec 28, 2023 9:59 pm
After a night of reflextion, I will stuck with Liqui Moly.
JiSingh1
Post by JiSingh1 »
Le_Combattant wrote: Fri Dec 29, 2023 9:05 am After a night of reflextion, I will stuck with Liqui Moly.
lol, fair enough. hope it works out,
I think the main additive for VW is ester. It is also present in the Fuchs oil, but it doesn't have it in the liqui moly, from what I can tell?
REACH # 01-2119493620-38
EC 931-384-6
Le_Combattant
JiSingh1 wrote: Fri Dec 29, 2023 1:25 pm
EC 931-384-6
Could be an issue ?
JiSingh1
Post by JiSingh1 »
Le_Combattant wrote: Fri Dec 29, 2023 3:47 pm
EC 931-384-6
Could be an issue ?
Hard to know. It doesn't seem present in many oils though. I would still think viscosity matters more than additives and the liqui moly is very good at this when warm.
Le_Combattant
JiSingh1 wrote: Fri Dec 29, 2023 4:28 pm
EC 931-384-6
Could be an issue ?
Maybe you are right.
In the Fuchs document, where did you see the ester additive ?
JiSingh1
Post by JiSingh1 »
Le_Combattant wrote: Fri Dec 29, 2023 8:02 pm Maybe you are right.
So on the other forum I linked, I was told it is an Ester and the code in the original VW datasheet, it is 01-2119493620-38.
If you type this code into google, you will get the EC number 931-384-6, which is what is listed in Fuchs.
