Page 8 of 16
Re: Amarok Oem Bixenon retrofit
Posted: Sun Feb 25, 2018 7:13 pm
by ciclo
georgenis wrote: Sun Feb 25, 2018 3:08 pm
I don’t have the necessary voltage on headlight pin 10.
But, .... you say that the parking lights work in all conditions ... I don't understand anything ...please, clarify!
Posted: Sun Feb 25, 2018 7:32 pm
by georgenis
The pin 10 must have 12V for the DRL.
The parking lights are working ok when activated. The leds are dimmed.
Posted: Sun Feb 25, 2018 7:43 pm
by ciclo
I insist
with link:
viewtopic.php?f=56&t=70902&start=75#p530859
and I copy and paste AGAIN:
Second step
Front parking/side lights
Left
Isolate original wire T10/10 headlight connector.
Install new 0.5mm2 wire from
T10/10 headlight connector to
T73b/5 BCM white connector.
Right
T73b/6 BCM white connetor.
DRLs
Isolate original T17/3 light switch connector. Remove fuses SC26 and SC27.
Install new 0.5mm2 wire from T17/3 to T73b/29 BCM white connector.
Left
Isolate original wire T10/4 headlight connector.
T10/4 headlight connector to
T73b/3 BCM white connetor.
Right
T73a/5 BCM black connector.
Please, answer my question:
What's the use of pin 10 of your bixenon headlights?
A- parking lights
B- DRLs
Posted: Sun Feb 25, 2018 7:56 pm
by georgenis
Both pin 4 and 10 are going in the led modules. The dimming is made by pin 10, 5V with parking lights on. Pin 4 have always 12V.
Posted: Sun Feb 25, 2018 7:59 pm
by ciclo
Good answer. hahahahahaha ...
Please laugh with me .... it's a funny moment.
Posted: Sun Feb 25, 2018 8:03 pm
by ciclo
georgenis wrote: Sun Feb 25, 2018 7:56 pm
So the use of pin 10 is for the parking lights, not for the DRLs as you said here ....
viewtopic.php?f=56&t=70902&start=105#p530906
Posted: Sun Feb 25, 2018 8:04 pm
by georgenis
I'm sure of the wiring because the wires from BCM 73B/5,6 to headlights pin 10, I buyed from Carsystems and are mounted when I tried the first BCM.
Posted: Sun Feb 25, 2018 8:05 pm
by georgenis
Yes, but for the DRL to work, both pins 4 and 10 need 12Volts. I have tested this.
Posted: Sun Feb 25, 2018 8:11 pm
by ciclo
I can provide you 12v on both pins. Do you want them?
Posted: Sun Feb 25, 2018 8:18 pm
by georgenis
I don't understand what You mean.
Posted: Sun Feb 25, 2018 8:30 pm
by ciclo
by coding...
Posted: Sun Feb 25, 2018 8:37 pm
by georgenis
I'm waiting.
Sincerly I'm very happy with what I acheived until now with Your precious help. You lost a lot of time with this matter...Not many persons are like You.
Posted: Sun Feb 25, 2018 8:53 pm
by ciclo
Discovering the secret of Bixenon headlights retrofitting in Amarok 8K0, 8K1 is priceless.
12v both pins ... activate Byte23 Bit5.
This is not for the Amarok ... also activate the Byte21 Bit0 (to test).
(return to the previous coding if you do not find your desired results)
Posted: Sun Feb 25, 2018 9:10 pm
by georgenis
I tried on both codings (the initial and the last with no errors) and still no DRL.
Posted: Mon Feb 26, 2018 4:46 am
by ciclo
Yes, it was the result we expect.
Today I will do some checks with respect to light switch reference number.
