Page 8 of 10
Re: BCM Max upgrade in Vento IND manual transmission
Posted: Mon Mar 04, 2019 3:12 am
by sshakthi123
benzinkopf wrote: Sun Mar 03, 2019 9:07 am
i think the rain closing is still a mystery. I did change the wrm to the ‘right’ model. but it still wont work when the car is lock. The next to try is to change the RLS type. But still i have doubt in that. because I personally able to activate rain closing in one of my friend’s car with the same RLS model and sunroof. His sunroof did close except the windows, which is expected already since we didnot change any wrm or its coding.
Oops, should I get new WRM's are not
Posted: Thu Mar 07, 2019 5:27 pm
by sshakthi123
ciclo wrote: Sat Feb 23, 2019 8:45 am
Sakthi, I'll send it on Monday (absolutely free) and only the masters of the universe will know when it'll arrive to your address. (15-30 days, SP-IND)
Ciclo, I have got the wire today. Will get it installed in next two weeks (little busy till then). Keep you posted.
Meantime, can you share any more links to enable the features (I have enabled few based on the links you shared before).
Posted: Thu Mar 07, 2019 5:42 pm
by ciclo
Thank you very much for reporting.
Do you mean to the other VCDS tweaks that I've not shared with anyone yet?
Posted: Thu Mar 07, 2019 5:48 pm
by sshakthi123
ciclo wrote: Thu Mar 07, 2019 5:42 pm
Yes
Posted: Thu Mar 07, 2019 6:02 pm
by ciclo
Posted: Thu Mar 07, 2019 6:06 pm
by sshakthi123
ciclo wrote: Thu Mar 07, 2019 6:02 pm
I've always shared with everyone what I know about the BCM PQ25.
Cool
Posted: Wed Mar 27, 2019 2:03 am
by sshakthi123
Ciclo, installed the wire and the
backup lamp error has gone. Many thanks.
living with the following errors,
1.
DRL bulb errors - I have ordered different bulbs and will be changing in a month time
2.
Steering angle calibration error - I am hearing this will not go up unless we install ESP. Also I couldn't find original VCDS (I feel it is costly to spend $200 purchasing original vcds to clear this error if at all possible). So for now leaving as is.
With this
my installation gets completed
and I would like to thank you (Ciclo) for all the help you provided and other friends who patiently answered all my silly questions that gave me a confidence doing these. I'm really thankful for all of you.
Ciclo - I will knock the door if I had to install bi-xenon / LED lights in future.
Attaching the latest scan for reference,
Wednesday,20,March,2019,08:40:49:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118 License Plate: MAR20-2
Mileage: 18620km-11569mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118 Mileage: 18620km-11569miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC) Labels: None
Part No SW: 03L 906 023 RS HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00110116032500080000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
ROD: EV_ECM15TDI02103L906023QT.rod
VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 CA HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0004
Serial number: --------------
Coding: 60DD2F63212A04C50615F46A845920020000
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 7F0DB5FEE6FD7ABC61-802A
Serial number: 03111813470922
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 18629 km
Date: 2015.06.28
Time: 08:37:48
Voltage terminal 15: 12.50 V
Voltage terminal 30: 12.70 V
Terminal 15 status: On
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F306D889CC4C57-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 222180856
Coding: 3A904BFF48A10000013806C07CEB9690F9C063FF608C2141220000030000
Shop #: WSC 12345 123 12345
VCID: 2C57B2B24F0B312494-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 290617 04 42 0106
Coding: 0714DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2521
Serial number: 13202848170704050535
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2521
Serial number: 13102849170705002249
Coding: 040000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 1811713320101504AB1B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1522
Serial number: 13102728170704212031
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1522
Serial number: 13102729170630002341
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 18629 km
Time Indication: 0
Date: 2015.06.28
Time: 08:37:48
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 18629 km
Time Indication: 0
Date: 2015.06.28
Time: 08:37:48
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 6RU 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0018
Revision: -------- Serial number: 28231836203031
Coding: 108002
ASAM Dataset: EV_EPHVA18VW250GP00 001002
ROD: EV_EPHVA18VW250GP00.rod
VCID: 61C913867049AC4C77-8034
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW01BGFS-
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4999EB26E8B9040C8F-801C
Part No SW: 6RF 920 862 B HW: 6RF 920 862 B
Component: KOMBI H01 0217
Coding: 1208000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 4B95D12EE2C5161CBD-801E
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002300
VCID: 68DF0EA29B73DD04B0-803C
Component: IMMO H01 0217
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74AA8D7FEF14A6-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5515
Revision: -------- Serial number: VWZ7Z2R8103103
Coding: 0E000440000010
Shop #: WSC 12345 123 08192
VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:28)--------------------------
Posted: Wed Mar 27, 2019 3:47 am
by ciclo
THANKS to you.
sshakthi123 wrote: Wed Mar 27, 2019 2:03 am
Posted: Sun Aug 18, 2019 4:06 pm
by sshakthi123
Ciclo,
I'm planning to install ESP (ordered the parts). Can you help with 2 things,
1.
As we have already installed the steering angle sensor, now the pending items are only ESP module and ESP off button.
I was referring to the wiring diagram provided for ESP. It says T41/5 to be connected to T32/32. But in our wiring it is connected to SB9 +30 fusebox.
here is the ESP block I ordered,
Do I need to change this(T41/5) or should be good with the current one?
2.
Help me providing coding for ESP. I would like to enable the following options -
ASR, HHC, XDS, Indirect TPMS
VIN - MEXJ1760XJT075118
Model - Diesel manual
current coding;
Posted: Mon Aug 19, 2019 12:45 am
by ciclo
1
- Forget the T32/32 in the diagrams, you don't have to touch anything here. It is a common +30 wire for several devices.
- Why didn't you install the T41/5 at +30 SB5 as it was indicated in the instructions?
- SB9 is a +15 signal and therefore is totally incorrect. Connect to SB5 +30 according to the installation guide (read again the installation guide ... WL0 and then
viewtopic.php?f=56&t=72122&start=30#p547519 , clear as water).
Sorry for the following,
I say it in a friendly way, do not ever do stupid things or foolish occurrences
if you want the G85 sensor to work
properly for your new ESP system.
I suppose that for this reason it was impossible for the G85 to work properly before.
The +30 signal (before ignition switch) and the +15 signal (after you turn the ignition switch) are very different signals.
2
https://skodapilot.com/espcalculator-bo ... i/?lang=en
Posted: Mon Aug 19, 2019 2:03 am
by sshakthi123
Ciclo,
Sorry for the wrong mention. It is connected to SB5 only (still thinking how I mentioned SB9 instead)
So I'll not touch the angle sensor. New install will be on ESP block and off switch only.
I'll refer the link for coding. Let me know any other institutions I have to follow.
Posted: Mon Aug 19, 2019 7:18 pm
by ciclo
Don't worry, we all make mistakes believing we did it right.
For this new installation of the ESP module I recommend that you contact iichel or firegrafik, they can advise you better on the small details for this installation.
To facilitate their work and receive a quick reply:
- Post your progress/questions here.
- Link to them here.
Posted: Mon Aug 19, 2019 8:16 pm
by iichel
It is not very easy to calculate an ESP9.0i coding, but I'll give it a try. I don't have any scans of cars that received this from factory.
My best guess for your ESP 9.0i module:
62DD2C63212A07C54615346A8459E082090D
With
HHC
ASR disabling by button
TPMS indirect
XDS
If you know anyone with the same configuration and ESP9.0i (VW Vento/Polo Sedan, RHD, diesel engine, manual), please post the coding here.
This will make the accuracy of the coding better.
Posted: Tue Aug 20, 2019 5:50 am
by sshakthi123
Sure Ciclo.
iichel,
No stock ESP configuration for India version manual transmissions for both petrol/diesel.
Vento2013 has installed ESP 9.0i in his manual, diesel, Vento. He will share the coding sometime later, will share it then.
Posted: Tue Aug 20, 2019 6:22 am
by iichel
That's nice. Thank you. I'm sure we will be able to make a coding for your esp9.0i retrofit.
