Vento ~ Polo Sedan 1.5 Tdi RHD
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post by sshakthi123 »
Dear Friends,
I'm opening a new topic seeking a help from you guys to upgrade the BCM and other features associated.
I'm from India owning Vento (Polo sedan) 2017 model comes with a BCM 6R0 937 085 R and I would like to update the BCM and few other options. Can you help me sourcing the BCM and other parts. As said by multiple users from India, it is impossible to get the parts here. So expecting your help to source the required parts.
1. BCM Max
2. No headlight upgrade as of now. I will alive with H7 headlights for some more time
3. Auto light switch (my car has Rain sensor with dimming mirror already)
4. CH, LH
5. Dimming of interior lights along with manual headlight adjuster present
6. Stalk - single side parking
7. DRL sourcing beside fog lights as said here viewtopic.php?f=56&t=69687&start=30#p524168
Thanks in advance,
Sakthi
sshakthi123
Re: BCM Max upgrade in Polo Sedan (Vento in india) manual highline
Hi Ciclo
Can you confirm the required part numbers of BCM, auto light switch, dimmer adjuster switch and a fog lamp with a DRL for Polo sedan or vento.
So I will start procuring it.
Thanks much,
Sakthi
Your private message: (I don't answer private messages. Please, make your questions and provide the info from your car in this thread. Thanks)
sshakthi123 wrote:Fri Nov 02, 2018 7:14 am Hi Ciclo
Here are the part numbers I found for the BCM max upgrade for my vento (india version). I'm in touch with firegrafik to procure some of these now and keep it ready and wait for your help to prepare wiring looms.
Can you confirm these are good to procure.
Part - 1 (will do it now)
BCM - 7E0937090D - I heard the BCM version "C" will have a different radio frequency which may not support india version keys. So shall choose "D"
Light switch - 3С8941431А
Dimmer switch - 6RU941333 9B9
And a wiring harness required.
Will plan for future upgrades (list below)
fog lights with DRL - 6R0941061B, 6R0941062B
fog light harness - link here
trunk camera - 6RF980121
I really appreciate your help.
Thanks much,
Sakthi
About...
sshakthi123 wrote:Fri Nov 02, 2018 7:14 am BCM - 7E0937090D - I heard the BCM version "C" will have a different radio frequency which may not support india version keys.
... this statement is totally incorrect.
sshakthi123
Hi Ciclo,
Please find the pictures from my car.
Image Image Image
Image Image Image
Image Image
here is the latest VCDS scan,
Saturday,24,November,2018,09:08:06:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118   License Plate: 8854-24112018
Mileage: 9860km-6126mi   Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118   Mileage: 9860km-6126miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC)       Labels: None
   Part No SW: 03L 906 023 RS    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116032500080000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CA    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0004
   Serial number: --------------
   Coding: 60DD2F63212A04C50615F46A845920020000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 7F0DB5FEE6FD7ABC61-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 6RU 937 086 R    HW: 6RU 937 086 R
   Component: BCM IM M+4    H42 0452
   Revision: BY042001    Serial number: 6700 250170061
   Coding: 3A904BFF48A10000013800006F2B16900080600F608E2140220000000A00
   Shop #: WSC 124697 483 00190
   VCID: 70EF66C2A3A315C4E8-8024
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 290617 04  42  0106
   Coding: 036800
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2521
   Serial number: 13202848170704050535
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2521
   Serial number: 13102849170705002249
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 1811713320101504AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1522
   Serial number: 13102728170704212031
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1522
   Serial number: 13102729170630002341
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47331323402335
   Coding: 108001
   Shop #: WSC 01234 785 00200
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E7388FAA177B3B42A-806A
   Revision: --------    Serial number: 003GW01BGFS-
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RF 920 862 B    HW: 6RF 920 862 B
   Component: KOMBI         H01 0217
   Coding: 1208000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4B95D12EE2C5161CBD-801E
   Part No SW: 6RU 909 901     HW: 6RU 937 086 R
   Component: GW-K-CAN TP20 H42 0452
   Revision: BY042001
   Coding: 002300
   VCID: 19397B661099B48CFF-804C
   Component: IMMO          H01 0217
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5515
   Revision: --------    Serial number: VWZ7Z2R8103103
   Coding: 0E000400000010
   VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:20)--------------------------
Please review and help on the wiring harness required. (I remember you mentioned you cannot do wiring until Jan, I will wait.)
My requirements are,
1. BCM max adaptation (7E0937090D)
2. Auto light with CH/LH
3. Fog light with DRL
4. No headlight mods for now, but the adaptation to support through new BCM is required
5. Dimmer cum headlight adjuster
Thanks in advance.
Thanks,
Sakthi
Ok. Thank you very much for providing all the information without me having to request it, you will have to wait until January, as we have talked before.
The installation will be very similar to what we have done previously for other Polo Sedan from India.
Please, tell me if you want me to provide the Dimmer along with the wiring. I have to request it from my VW dealer*.
* which is a place I want to go as little as possible. (or never again, preferably) :lol:
sshakthi123
Thanks for getting back. I had ordered the Dimmer switch already so only the wiring part required.
I may get the required parts delivered sometime in December, so January should work for me. What would be the shipping time (to me/india) once you prepared the wiring.
- Sakthi
I always say that 20-30 days (for India). It depends on the traceability of the package, sometimes it took 10 days for package delivery and other times it took 25 days.
I'll try the best for you.
sshakthi123
That's fine. Thanks Ciclo.
Few thing to note
1. can you ensure the wiring supports the parking stalk also. I wish the windows closed upon rain (on the move / park). Does this update supports it?
2. I'm also in search for installing front PDC, can you help sourcing the items required for it. My need is, parking sensors with brackets, wiring harness. Rest of the items like PDC switch, 8k module I have it already.
3. I may want to upgrade to bi-xenon in future but not anytime soon. just a note fyi to provision/prepare the wiring.
Thanks in advance.
1.Yes, there is no problem for the parking function in the stalk once you install the new BCM and the adaptation wiring. It will be coded in the new BCM.
Regarding the windows, will only close in case of rain if you have installed the correct WRMs (not the current ones) and the right codings for this function (RLS is perfect in your case). Please, look for help in the forum (e.g. govindsharma's topic).
2. No. I can't help you with this.
(you have many info in my topic and in the net)
3. Thanks, no problem for Bi-xenon in the future if you install the wiring for them and enter the right BCM coding.
sshakthi123
1. Ok. For windows I'll check for the respective articles
2. I have all the info needed. All I need is a OEM parts which I'm unable to procure here and I don't want a Chinese parts from ali. It will be great if you can help me in this.
3. So I assume changing the wiring harness 10 to 14 pins and rewiring the fog to a switch and xenon SCL to BCM should work.
Sakthi
sshakthi123
ciclo wrote: Mon Nov 26, 2018 12:37 pm 1.Yes, there is no problem for the parking function in the stalk once you install the new BCM and the adaptation wiring. It will be coded in the new BCM.
Ok. upon reading through govindsharma's posts I found my car has static cornering lights works with indicators only. I would need a steering wheel sensor installed to enable to fog work on turning the steering wheel. This may require you visiting a VW dealer (sorry about it :roll: )
Agreed, I have all the info needed. All I need is a OEM parts which I'm unable to procure here and I don't want a Chinese parts from ali. It will be great if you can help me in this.
So I assume changing the wiring harness 10 to 14 pins and rewiring the fog to a switch and xenon SCL to BCM should work. Is it possible to wire this 14 pin connector now and use the H7 halogen headlights for now. So in future once I get Bi-xenons it will be just plug and play. Or does it require reassembling few wires in future?
At last my requirements are,
3. Fog light with DRL (it will be based on your answer on how we will do on #3 above, whether it will be 10 to 14 pin connector now and in future)
6. Steering wheel sensor to enable fog lights on turning the steering wheel
7. Any other coding updates
one note is, I already installed rear PDC connecting can lines from PDC to IC T32 28 and 29. I was referring https://drive.google.com/file/d/0B2nv91 ... FpcDA/view so based on this isolating current wiring of 28 & 29 leave the rear OPS not working.
Thanks much,
Sakthi
It could be problematic to install a G85 steering wheel sensor on your Vento, it may need to be adapted with ODIS.
(the govindsharma's topic it's only for you to read about the WRMs)
sshakthi123
Yes Ciclo, I read about WRM's.
And I would like to install the steering angle sensor as my current cornering supports via indicator stalk only. Would need your help on procuring the steering sensor.
Thanks,
Sakthi
sshakthi123
ciclo wrote: Sat Dec 01, 2018 8:31 am It could be problematic to install a G85 steering wheel sensor on your Vento, it may need to be adapted with ODIS.
Hi Ciclo,
A very happy new year. Just reminding you on the wiring looms I requested for.
Thanks much,
Sakthi
Yes, I have it in my mind. :wink:
I beg you a little of time, the holidays in Spain end on January 7th.
Now I have several projects in progress in my cars (priority over anything), however, soon I dedicate to make your wiring in my spare time.
