Locked
CNK
Drives: 6R
Post by CNK »
ciclo wrote:CNK, look at all pictures of this link, perhaps this will help. :wink:
I'm trying to fix net side trunk: http://www.uk-polos.net/view ... 60#p469759 but how I can remove the side panel without removal of the rear seat?
Image Image
Image Image Image
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
diskoboy wrote:
diskoboy wrote:
ciclo wrote:diskoboy, remember you have to check the current flow diagrams before making any modification to the original wiring.
Perfect. I'll allready have the connectors - the red one is the same and the new 1k0972928 I have from an Passat - same connector used in the ignition/starter switch :)
All of the pins in the 16-pin-connector are the same in Polo year 2011 (6R) and 2016 (6C) :D
6C climatronic control unit DOES NOT WORK in a 6R. End of story.
                Address 19: CAN Gateway       Labels: 6R0-907-530-V1.clb
Control Module Part Number: 6R0 907 530 B    HW: 1K0 907 951
  Component and/or Version: J533  Gateway   H28 0020
           Software Coding: 7D431D20080000000002
            Work Shop Code: WSC 00788 648 00255
                      VCID: 3260AE41AD7D09B1A84-8067
1 Fault Found:
01336 - Company Data Bus for Comfort System
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 89
                    Mileage: xxx km
                    Time Indication: 0
                    Date: 2052.14.15
                    Time: 14:43:18
I can see in ETKA that 6R0 907 530 E exists, but don't believe that it will ever work...
Thanks for the information. :wink:
It is quite likely that all parts of 6C who are involved with CAN lines will not work on 6R.
CNK
Drives: 6R
Post by CNK »
Thanks ciclo, I will try again :)
On the vwvortex forum I found an interesting shelf from Golf VI (Rear Storage Tray, 1K0061178A):
http://i227.photobucket.com/albums/dd15 ... e18b8d.jpg
This is very useful, but there is no such shelves for Volkswagen Polo :(
grem
Post by grem »
CNK wrote:Thanks ciclo, I will try again :)
This looks like something I definitely need. I found one for the polo but it is from china
http://www.aliexpress.com/item/Rear-Tru ... 42053.html
Search more closely with other words on aliexpress, I've seen such parts cheaper.
For example: http://www.aliexpress.com/item/Rear-Tru ... 58385.html
A very complete video about Polo 6C R-line.
I like this video. :wink:
It is a pity that on Polo 6R/6C is not possible the Highbeam Assistant. HBA
http://en.volkswagen.com/en/innovation- ... ssist.html
On the other hand, it seems that the LEDs headlights provide good lighting at all times, but the appearance of the headlights is not my favorite. :?
They need a better design in appearance. IMHO
shpunt
Drives: Polo 6R
Post by shpunt »
Hello.
Help me pls activate Auto folding mirrors on my VW Beetle 2014 (3 doors).
I have the same door component.
and my coding:
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 28013050140479
Coding: 7CB8697848430C0093A80F306CCB96C4AD42610F60842D41B2A0140A0000
Shop #: WSC 00066 123 12345
VCID: 2D51EF3674B133760F5-8078
Subsystem 2 - Part No SW: 6R0 959 801 BK HW: 6R0 959 801 BK
Component: J386__TSG_FT 003 8662
Coding: 0000A5
Subsystem 3 - Part No SW: 6R0 959 802 BR HW: 6R0 959 802 BR
Component: J387__TSG_BT 003 8662
Coding: 1000A5
What coding for J386 and J387 i can use for Auto folding mirrors ?
(i have factory folding installed)
This is the coding for POLO 6R (LHD, like your Beetle) three doors. Try it and tell us the results :wink:
Undersystem 2 - Styreenhedsnr: SW: 6R0 959 801 BD HW: 6R0 959 801 BD Forklaringsfil: NEZ\6R0-959-801.CLB
Komponent : J386__TSG_FT 003 8620
Kodning : 0280AB
Undersystem 3 - Styreenhedsnr: SW: 6R0 959 802 BF HW: 6R0 959 802 BF Forklaringsfil: NEZ\6R0-959-802.CLB
Komponent : J387__TSG_BT 003 8620
Kodning : 1080AB
Same functions as in the Polo 6R:
My guide: http://www.uk-polos.net/view ... 30#p481352
shpunt
Drives: Polo 6R
Post by shpunt »
ok.
i'll try.
shpunt
Drives: Polo 6R
Post by shpunt »
Ok.
But it can be different coding for Beetle.
I'll try.
Yes, you are right, especially by the system of door closing.
But this is the best information I can provide..., however, if you lose some function, you will have integrate the Bits of your previous coding to the new coding. (enabling or disabling bits)
Удачи вам :wink:
shpunt
Drives: Polo 6R
Post by shpunt »
shpunt
Drives: Polo 6R
Post by shpunt »
this coding dont work on my Beetle.
Beetle have frameless doors, ie glass on top has no border. (the same as VW Passat CC)
and when you open the door - glass drops slightly (exits the rubber seal 5 mm).
but after this coding - the glass does not fall and I can not open the door.
Locked
