I want it to look as oem as possible, and in metal and oval like the one you showed in your topic, looks a bit "tuning" for my tasteciclo wrote: Thu Apr 19, 2018 7:01 am Keep us informed.![]()
I think I'll do it in another way, but I still have to study it ..
I first need to design them better, which isn't easy when you are just starting at 3D design haha
My way to do it is as close to OEM as possible and super high quality (similar to the front tweeters). I assure you, the appearance is impressive, but the best is where they are located.
And ... what's the problem?ORiOn wrote: Wed Jun 13, 2018 9:07 pm I just checked continuity on all of them, and they all work... F*ck...![]()
Well, since it's not the fuses, I have no idea why they don't work...
Let's hope it's something in the coding...
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 37 44 55 56 61 77 0B
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CPTA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 Q HW: 04E 907 309 D
Component: 1,4l R4 TSI X08 5763
Revision: WCX08--- Serial number:
Coding: 00190032242401000000
Shop #: WSC 92521 052 12345
ASAM Dataset: EV_ECM14TFS01104E906016Q 002009
ROD: EV_ECM14TFS01104E906016DL.rod
VCID: 3068DC8B6B27B2C20C-8064
Readiness: 0110 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H01 0002
Serial number: --------------
Coding: 21DD4885232600C984141272C45200550905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F2A7F77D6598D3A35-805A
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Component: LENKW.SENSOR H06 0060
Serial number: 090465LJR0002L
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF432B3E1F394B2CE-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3878E4AB8B576A8244-806C
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 HW: 7H0 937 090
Component: BCM PQ25 Max4 H72 0708
Revision: B9072001 Serial number: 0531 313120016
Coding: 64B029B84821000021280F117EEB9FD90AC1672F7E0D70C1200000030000
Shop #: WSC 00788 648 00255
VCID: 6BD20BE78A81111A79-803E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 221012 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1621
Serial number: KU0KU009101200010457
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1621
Serial number: KU0KU010101200012525
Coding: 58BC30
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Serial number: 0300853
Coding: 820000
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361229300488
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E74F2B3A17354B28E-806A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01S H10 0020
Revision: -------- Serial number: 003GX01G87NL
Coding: 003153
VCID: 4A9CAE63EDBBE81222-801E
Serial number: 3575HRB405L1KR0EG0P-
Serial number: 3585HRB40571KAE8B15X
Serial number: 3515RRB400K4UOFEI8RS
Serial number: 3525RRB400G4UOFEQ1SR
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
VCID: 3566ED9F944597EA5F-8060
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H72 0708
Revision: B9072001
Coding: 002034
VCID: 70E81C8BA3A7F2C24C-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0607
Serial number:
VCID: 6ADC0EE38D7B081202-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663790475
Coding: 020100
VCID: 2A5CCEE345FBC812C2-807E
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 HW: 3C8 035 279
Component: RNS315-EU H59 0319
Serial number: VWZAZ2M5536049
Coding: 040004710200010000008000
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 68D874EB93773A0214-803C
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V9 0069
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11221
Shop #: WSC 00788
VCID: 3068DC8BF727B2C20C-8064
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 019A000001000000
VCID: 77FA2797CEC9A5FA8D-8022
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H72 0708
Coding: 032F7A64
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 00000000004970261222
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: -------- Serial number: 35502105120668
Coding: 060000010100010000000101
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_002.rod
VCID: 244020DB2FDF1E62F8-8070
