Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
Re: Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
sanders, where do you live in the netherlands? maybe you can have a go with my module?
sanders
- Drives: 6r bluemotion tdi 1.2
Yes I live in Enschede, but do you have a spare module?
sanders
@Adam87,
Thanks for reply, don't have VCP so not able to reflash the AFS module.
My parents live near Ommen, we could meet up when I'm around.
sanders
Changed the module, and same results. Same fault codes in can gateway and headlight range
try this coding: 0192000001000000
sanders
Did this code maken no difference.
Some ideas:
Check the wiring again (meticulously) from the rear sensor to module 55.
Unplug the sensor connector and plug it in again.
Do the basic setting again.
sanders
Thanks for the reply Ciclo, wil report back with my findings.
sanders
Checked the wiring but made no difference. Strange thing is that the gateway still comes with faultcode 01771??
Eduard
- Drives: 6C
Hello gents! Anyone here can help with some tips on where exactly does the afs wiring get inside the car from the sensor ?
Thanks!
Thanks!
Eduard
- Drives: 6C
Thanks buddy! iichel pmed me earlier, wires are now in place
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Hi. this is my brake line bracket in the area for leveling sensor. Do i need to replace this brake bracket to fit in the leveling sensor ? because i tried to fit the sensor mounting, seems like its not right.
