UPGRADING BCM 6R
Re: UPGRADING BCM 6R
Perfect! Thanks.
VK70
- Drives: VW Vento 1.2 TSI Highline
Thank you very much ciclo and govindsharma.ciclo wrote:
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU021021440523980
Coding: 1400B3
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU004101300011381
Coding: 0400B3
... and all the functions will work like a charm!... auto folding mirror function too.
I will check with my SA in VW if he can source this for me.In case they are not willing to ,can you let me know where you sourced this from.
Thanks again [emoji3]
Sent from my ONEPLUS A5000 using Tapatalk
These WRMs with those references will be very difficult to find in the second-hand market.
In the ETKA these references have been replaced by new ones.
As the automatic folding function was not available in the optional equipment when buying a 6R on those dates (2013-2014, if you look at the previous image of the WRMs) the WRMs that replace these do not have the auto function in any case .
Therefore, it will be necessary that some magicians (e.g. in Russia there are a few
) find a way to load these software into WRMs with the appropriate hardware (pins and electrónic parts).
A separate comment:
The most difficult thing was to code these WRMs so that all possible functions worked correctly.
In the 6R sold in India with folding mirrors (without auto function) you just have to install and code them with the VCDS. No modification is necessary in the wiring.
The best of luck for the huge number of 6R owners in India who asked me about the WRMs for automatic folding function with remote.
A separate comment:
govindsharma
- Drives: polo 1.2 petrol HighLine
Dear Sir Good Evening
As i installed auto fold side mirror in my polo rain closing with lock is not working.I thing i have to change coding of rain sensor can you please tell me its right coding.At present rain closing is working in door unlock as i lock the door it is not working.Second please suggest me radio which is all the function like navigation phone calls, magnetic compass Bluetooth etc and it has full integration with MFD.
Thank you.
Thank you.
RNS310, RNS315, RNS510, Discover Media PQ (needs component protection deactivation).
Your RLS coding is right.govindsharma wrote: Sun Jan 28, 2018 11:18 am Dear Sir Good Evening
As i installed auto fold side mirror in my polo rain closing with lock is not working.I thing i have to change coding of rain sensor (NO). can you please tell me its right coding. At present rain closing is working in door unlock as i lock the door it is not working.
Thank you.
Same as mine.
Is the Rain Closing function in the 6R possible with the car locked? YES.
govindsharma
Sir Than how can it work tell me please.ciclo wrote: Sun Jan 28, 2018 1:32 pmYour RLS coding is right.govindsharma wrote: Sun Jan 28, 2018 11:18 am Dear Sir Good Evening
Thank you.
Same as mine.
Is the Rain Closing function in the 6R possible with the car locked? YES.![]()
I sent you an email. Do the tests.
govindsharma
Dear Good Afternoon
Can anyone tell me how to install diversity antenna in VW polo 6R. What parts are required for this antenna and connection diagram of it.
Thanks in advance if anyone help me in this regard.
Thank you.
Thank you.
raghav.rithvik
- Drives: Polo 6r 1.2 TSI DSG
Apologies for hijacking your post.
Re: Ciclo
I have the following setup
Polo 6r 1.2 GT TSI (India)
I managed to buy the door modules (6r0959802BH & 6r0959801BC) I've used the long codes 1400B1 & 0400B3 respectively.
The issue is as follows,
-left-right & up-down mirror control for both sides have swapped (up does right, down does left & vice versa)
-Only the left mirror(passenger) auto folds (however both fold when I turn the switch on the door)
I also managed to enable passive TPMS on the car by changing the last byte of the ABS module code & IC enabling. Works perfectly. I purchased the reset switch 1K0927121C. Could you help me with the pin config for the ESP module to connect the switch?
P.S. Would you like me to open a new thread completely?
Update : managed to get the mirrors working as intended using 1400B3 for RHD mirror.
Re: Ciclo
Tuesday,20,February,2018,16:33:01:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: MEXB16605GT0XXXXX License Plate: DOORMODULECHANGE
Mileage: 28370km-17628mi Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 02 03 08 09 10 15 17 19 25 44 56
VIN: MEXB16605GT0XXXXX Mileage: 28370km-17628miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6DD0F128BC91FF2E51-8039
Readiness: 0010 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6501
Revision: 00043014 Serial number: CU501510177213
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3A7A0A74755F989684-806F
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C3461A246A4251C0800909
VCID: 0B149FB0A245511EEF-805F
1 Fault Found:
0631 - Tire Pressure Warning
C102D 00 [137] - -
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 11
Reset counter: 0
Mileage: 28323 km
Date: 2018.02.19
Time: 08:32:49
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41887D98D889CB4EC5-8015
Part No SW: 6RU 937 087 M HW: 6RU 937 087
Component: BCM IM H+4 H40 0432
Revision: BZ040001 Serial number: 0300 027160122
Coding: 3AB82BFF48A30000013800007EAB0690F0C041FF608C0000200000000000
Shop #: WSC 124697 483 00190
VCID: 6CD6FC2C8F8BF62646-8039
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 081215 03 37 0059
Coding: 0368DD
Serial number: KU0KU028041441181703
Coding: 1400B1
Serial number: KU0KU013011440132823
Coding: 0400B3
Subsystem 4 - Part No SW: 31G 959 442 HW: 31G 959 442
Serial number: 2991512270400366CX3J
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Serial number: 13202728151126171114
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Serial number: 13202729151127015206
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 18D 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0003
Revision: -------- Serial number: 20841526700549
Coding: 308001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA18VW3218CS0 001002
ROD: EV_VW75XParkAssis8K_VW31.rod
VCID: 31682D5860295BCE35-8064
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW012F7ND
Coding: 003036
VCID: 499865B8E8B9030E1D-801C
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140A01
VCID: 479C6380FEADF57E0B-8012
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H40 0432
Revision: BZ040001
Coding: 002300
VCID: 1938F5F81099B38E6D-804C
Component: IMMO H05 0805
Shop #: WSC 00000 000 00000
VCID: 6ADAFA348D7FE81634-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 41887D98D089CB4EC5-8014
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: Radio 526 Crng
Revision: -------- Serial number: VWZZZ4Q5129492
Coding: 08000440010005
Shop #: WSC 00070 123 12345
VCID: 45806988CCA1E76EF9-8010
Last edited by raghav.rithvik on Tue Feb 20, 2018 2:31 pm, edited 2 times in total.
excuse my potential rude remark, but there are other users apart from ciclo in this forum that are capable of helping you out.
pin 4 of the 38-pin connector to the ABS unit goes to pin 4 of the 6-pin connector of the push button.
pin 5 of the 6-pin connector of the push button goes to a +15 (ignition switched 12V, pin 35 blue/black wire of the ABS connector)
pin 6 of the 6-pin connector of the push button goes to a ground point, i.e. connect it to the dash cross member
pin 3 of the 6-pin connector of the push button goes to the button illumination signal (i.e. grey/blue wire in the T28 pin connector of the door wiring loom)
raghav.rithvik
iichel wrote: Tue Feb 20, 2018 1:17 pm excuse my potential rude remark, but there are other users apart from ciclo in this forum that are capable of helping you out.
Apologies iichel, I meant no disrespect by directing my question. Big fan of your posts.
The pin 4 on my T38 connector is already occupied by a grey wire. However, ESP switch is connected to 15 or 16 (not entirely sure of this number) as I checked continuity to ESP switch pin 4. Should I add TPMS to T38/4?
govindsharma
Can you please elaborate the operation of WRMS in your polo by this coding Ciclo sir can help you regarding this or may be i will tell you the correct coding of that.raghav.rithvik wrote: Tue Feb 20, 2018 1:03 pm Apologies for hijacking your post.
Re: Ciclo
I managed to buy the door modules (6r0959802BH & 6r0959801BC) I've used the long codes 1400B1 & 0400B3 respectively.Code: Select all
Tuesday,20,February,2018,16:33:01:00001 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels) VCDS Version 17.8.0.1 Data version: 20170721 DS276.2 www.Ross-Tech.com VIN: MEXB16605GT0XXXXX License Plate: DOORMODULECHANGE Mileage: 28370km-17628mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 60-VW25 (6RU) Scan: 01 02 03 08 09 10 15 17 19 25 44 56 VIN: MEXB16605GT0XXXXX Mileage: 28370km-17628miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ Component: SIMOS10.22AH10 6270 Revision: --H10--- Serial number: Coding: 00250056232400080000 Shop #: WSC 01234 785 00200 ASAM Dataset: EV_ECM12TFS02103F906070KC 004006 ROD: EV_ECM12TFS02103F906070FP.rod VCID: 6DD0F128BC91FF2E51-8039 No fault code found. Readiness: 0010 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 0AM-927-769.clb Part No SW: 0AM 300 065 N HW: 0AM 927 769 D Component: GSG DSG AG7 431 6501 Revision: 00043014 Serial number: CU501510177213 Coding: 0000020 Shop #: WSC 01324 785 00200 VCID: 3A7A0A74755F989684-806F No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS Component: ESP9.0i front H03 0001 Serial number: -------------- Coding: 62DD2463422A03C3461A246A4251C0800909 Shop #: WSC 01234 785 00200 ASAM Dataset: EV_Brake1ESP90iBOSCH 003031 ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod VCID: 0B149FB0A245511EEF-805F 1 Fault Found: 0631 - Tire Pressure Warning C102D 00 [137] - - MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 11 Reset counter: 0 Mileage: 28323 km Date: 2018.02.19 Time: 08:32:49 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q Component: Climatronic H12 0615 Revision: V0000000 VCID: 41887D98D889CB4EC5-8015 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb Part No SW: 6RU 937 087 M HW: 6RU 937 087 Component: BCM IM H+4 H40 0432 Revision: BZ040001 Serial number: 0300 027160122 Coding: 3AB82BFF48A30000013800007EAB0690F0C041FF608C0000200000000000 Shop #: WSC 124697 483 00190 VCID: 6CD6FC2C8F8BF62646-8039 Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB Component: RLS 081215 03 37 0059 Coding: 0368DD Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB Component: J386__TSG_FT 003 8612 Serial number: KU0KU028041441181703 Coding: 1400B1 Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB Component: J387__TSG_BT 003 8611 Serial number: KU0KU013011440132823 Coding: 0400B3 Subsystem 4 - Part No SW: 31G 959 442 HW: 31G 959 442 Component: E221__MFL-TAT H06 0023 Serial number: 2991512270400366CX3J Coding: 250000 Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S Component: J388__TSG_HL 019 1552 Serial number: 13202728151126171114 Coding: 000000 Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S Component: J389__TSG_HR 019 1552 Serial number: 13202729151127015206 Coding: 000000 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:* None Part No SW: 18D 919 475 A HW: 56D 919 475 Component: PARKHILFE 8K H02 0003 Revision: -------- Serial number: 20841526700549 Coding: 308001 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_EPHVA18VW3218CS0 001002 ROD: EV_VW75XParkAssis8K_VW31.rod VCID: 31682D5860295BCE35-8064 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 6R0 959 655 J HW: 6R0 959 655 J Component: VW10AirbagU06 H10 0020 Revision: -------- Serial number: 003GW012F7ND Coding: 003036 Shop #: WSC 01234 785 00200 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250_VW25.rod VCID: 499865B8E8B9030E1D-801C No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb Part No SW: 6RD 920 870 A HW: 6RD 920 870 A Component: KOMBI H05 0805 Serial number: 00000000000000 Coding: 140A01 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727 ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod VCID: 479C6380FEADF57E0B-8012 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 6RU 909 901 HW: 6RU 937 087 Component: GW-K-CAN TP20 H40 0432 Revision: BZ040001 Coding: 002300 Shop #: WSC 124697 483 00190 VCID: 1938F5F81099B38E6D-804C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H05 0805 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6ADAFA348D7FE81634-803E No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb Part No SW: 1S2 909 144 P HW: 1S2 909 144 P Component: EPS_ECU H61 1702 Coding: 0001000000000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SteerAssisNSK 014008 ROD: EV_SteerAssisNSK_014_VW12.rod VCID: 41887D98D089CB4EC5-8014 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 6RD 035 187 A HW: 6RD 035 187 A Component: Radio 526 Crng Revision: -------- Serial number: VWZZZ4Q5129492 Coding: 08000440010005 Shop #: WSC 00070 123 12345 VCID: 45806988CCA1E76EF9-8010 No fault code found.
i was probably looking at esp8.2i but you need esp9.0i.
pin 12 of the 38-pin connector to the ABS unit goes to pin 4 of the 6-pin connector of the push button.
pin 5 of the 6-pin connector of the push button goes to a +15 (ignition switched 12V, pin 28 blue/black wire of the ABS connector)
