Franciswat's Polo 6R 1.6 Bifuel
Franciswat
Drives: 6R 1.6 Bifuel
Re: My polo 6r bifuel
Post by Franciswat »
Thanks guys, on thursday I'll bring my cara to the body worker.
Franciswat
Hi, guys I'd like to retrofit OEM licence plate led.
I think I need and adaptor like this:
Can You tell me somethig how to make this adaptor instead of buying It? In particoular I'd like to know wiring and value of resistors. Thanks!
You don't need any adapter :wink: , you can install the original led plate lights and then if needed we code your BCM. (recent autoscan)
Franciswat
Re: Upgrading my Polo 6R bifuel
Thank you for this beautiful new ciclo!
I will update thread this week end when I'll the the lighs. :wink:
Franciswat
Hi guys, new OEM led licence plate lights finally arrived perfectly packed!
If I remember correctly there's a box to tick in 09. central electric. :roll:
Here's the last autoscan ciclo:
Friday,30,November,2018,23:39:58:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY54xxxx   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZCY54xxxx   Mileage: 81360km-50554miles
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210224E3217100B5842524E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BBF08E1260092380E406C6B0CD100C0412F60842000200000020000
   Shop #: WSC 02737 534 00190
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004011200011991
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005011200017885
   Coding: 08BC30
   Subsystem 3 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0339054
   Coding: 820000
   Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU010011200012406
   Coding: 08BC32
   Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009011200013136
   Coding: 08BC32
2 Faults Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 81362 km
                    Time Indication: 0
                    Date: 2013.04.22
                    Time: 23:35:02
03156 - Sensor for Anti-Theft System (G578)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 81362 km
                    Time Indication: 0
                    Date: 2013.04.22
                    Time: 23:35:02
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20251528901029
   Coding: 100001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XPakrAssis4K 001004
   ROD: N/A
   VCID: 3A7CE9AABDC4D991E7-806E
No ASAM data for: "EV_VW75XPakrAssis4K" (VW25)
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   ASAM Dataset: EV_AirbaVW10PBAVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3575HRB4059124B2F99H
   Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
   Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
   Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaVW10PBAVW250" (VW25)
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3460C7929FA02FE13D-8060
   Revision: B9080001
   Coding: 002200
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADC19EA8DE4A91157-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 6RD 035 187     HW: 6RD 035 187
   Component: Radio         517 5124
   Revision: RB101000    Serial number: VWZZZ4Q5034465
   Coding: 00000400040005
   VCID: 0400575287805F61CD-8050
End-------------------------(Elapsed Time: 02:51)--------------------------
PS This evening I noticed this error at the end of autoscan.
Is that because I may have retrofitted modules (ie PDC) that don't belong in any particular car? :|
Have I to be worried about It?
Franciswat wrote: Fri Nov 30, 2018 10:55 pm Hi guys, new OEM led licence plate lights finally arrived perfectly packed!
www.Ross-Tech.com
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 0003SH02
   Coding: 18BC30
   Coding: 08BC30
   Coding: 820000
   Coding: 08BC32
   Coding: 08BC32
2 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 81362 km
                    Time Indication: 0
                    Date: 2013.04.22
                    Time: 23:35:02
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 81362 km
                    Time Indication: 0
                    Date: 2013.04.22
                    Time: 23:35:02
   Coding: 100001
   ROD: N/A
   Coding: 003232
   ROD: N/A
   Coding: 140A01
   Revision: B9080001
   Coding: 002200
   Serial number:
   Coding: 11250
   Shop #: WSC 00788
Once you install the LED plate lights, try this coding
3CB02BBF08E1260092380EC06C6B0CD100C0412F60842000200000020000
(it all depends on the way the wire dedicated for license plate lights was installed)
Franciswat wrote: Fri Nov 30, 2018 10:55 pm PS This evening I noticed this error at the end of autoscan.
Old VCDS version.
Franciswat wrote: Fri Nov 30, 2018 10:55 pm Have I to be worried about It?
Depends of you. Yes ... or Not. :lol:
Franciswat
Thank you ciclo for the coding. I entered It and plate lights work without errors on instrument cluster.
Someone told me he had not to code anything to get them work without errors but I have some doubt about it.
I thought I had to change byte 27 to 01 when retrofit led licence plate light (iichel wrote that sometime ago); but now I suppose this way only deactivates light check. Doesn't it :?:
I'm pretty happy for result!!!
If It give no problems with car It's ok! :roll:
Thanks mate! :wink:
Franciswat
Hi guys, since I like to try new challenges :lol: I purchased a new car key from ali. This is it:
I have now the problem to program the transponder on the key to make it usable. Looks like I need the immo pin to configurate the key so question is how to retreive it.
Any information about how to proceede with the key configuration?
Franciswat
So everything is more clear since I read this:
:arrow: http://wiki.ross-tech.com/wiki/index.php/Immobilizer
I post it so maybe it can be usefull for someone else.
Franciswat
Today I disassembled front of my Polo 6R to take note of parts which have to be replaced. :cry:
:shock: What happened?
Franciswat
Hi dear ciclo, sadly in september my car (parked) had been involved in an accident. Last week I finally got the money (at least a part of the, about 1300 €) from insurance company to repair it. Spare parts only will cost 1200 € according to Etka. :(
It hurts me to see my car in this conditions but my hope
is to have it back soon better than before. :wink:
Oh, ok, I see.
Good luck with the repair, it doesn't seem like a difficult job.
Franciswat
Thank you ciclo! Sorry for long waiting, now I can finally show you and other mates the car just repaired (4 month from accident!!!) :!:
I asked to replace standard bumper with r-line one I provided, adding 6C upper and lower grills (standard one were broken)! It looks great :!: What do you think? :wink:
The same day I got my car repaired It started snowing for the first time in this year. :mrgreen:
PS Retrofit of headlight washers and front PDC still have to be done.
Looks great! 8) , thanks for the report.
The best is yet to come. :wink:
As for the snow, there are always unexpected coincidences.
In my case, just when I started my tests for High Beam Assist retrofit in our Golf (there were some complications to overcome) began two weeks of persistent fog in the area where I live, making it impossible to get good results.
It was exasperating ... :lol:
