Bixenon headlights with AFS For polo gt Tsi 2015
hmthakur
Drives: Polo gt tsi 1.2 dsg
Re: Bixenon headlights with AFS For polo gt Tsi 2015
Post by hmthakur »
ciclo wrote:I see that you have edited the previous post.
The new installed BCM, is it brand new or is it used?
Channel 000: Remote Control Clearing
http://wiki.ross-tech.com/wiki/index.ph ... l_Clearing
Channel 001: Remote Control Matching ... 0, test, save, press unlock button...
Ok i was entering 1 in place of 0, test and pressing unlock button. Key was in ignition at on position.
New BCM coding
3AB02BBF08A30000013806917CEB9E905AC0674F600D3041200000030000
New RLS coding
0728DD
Enable 65 address in Gateway Installation List (TPMS), and disable address 55 until the entire AFS is installed. (unit + sensor)
Please, check all the lights, post the results with a new autoscan (and explanations). Faults that should not be permanent will be corrected.
You will have permanent faults in the parking/side lights until you install the terminals/wires correctly.
hmthakur
Post by hmthakur »
Thanks will try it tomorrow and revert back to you
Should i enter this coding and do remote adaptation??
Do it as you prefer.
Tomorrow is better day than today. :lol:
hmthakur
Post by hmthakur »
ciclo wrote:Do it as you prefer.
Tomorrow i will receive bcm pins sent by Nikhil
hmthakur
Post by hmthakur »
Is the bridge at correct place??
Yes. ( :arrow: 646)
hmthakur
Post by hmthakur »
Everything working perfectly, their was problem in wiring. Remote adaptation done car is unlocking but not locking.
Headlight motors not working with afs
hmthakur wrote: Mon Aug 20, 2018 4:48 pm Everything working perfectly,1 their was problem in wiring. 2 Remote adaptation done car is unlocking but not locking.
3 Headlight motors not working with afs
1- Please, explain it better.
2- LOL! (BCM factory mode = 0, all doors closed, press lock button)
3- Where did you buy the AFS unit? Have you installed the correct sensor and unit?
Autoscan!
hmthakur
Post by hmthakur »
ciclo wrote: Sun Aug 19, 2018 8:07 am OK, thanks.
Remote Control Matching, once you enter 0 in the new value you have to save and then press and hold the unlock button.
Remember that the new value for all remote controls must be '0'. It is the same process for all remote controls.
In a couple of hours (asap) I send you the new codings for the new BCM and the new RLS.
ASAP.
hmthakur wrote: Sun Aug 19, 2018 8:01 am headlight problem is due to coding or should i check the wiring again??
or am i installing the bridge incorrectly
Coding.
here its mentioned press unlock
Afs module and sensor is used bought from allegro
hmthakur
Post by hmthakur »
Monday,20,August,2018,21:03:09:19846
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: MEXC15608FT079060 License Plate: MH-15-20-18-1
Mileage: 11730km-7288mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 65
VIN: MEXC15608FT079060 Mileage: 11730km-7288miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6D84C00F1D15260FAA1-8038
Readiness: 0110 0101
Part No SW: 0AM 300 062 R HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501412085377
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3B203E571F6178BF645-806E
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C94614246F4251C0800904
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 055498AF25A5FE4F421-8050
Serial number: 11121404651355
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F7434073AD9703B-802A
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40DA49BB7A871B67317-8014
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 073170395
Coding: 3AB02BBF08A30000013806917CEB9E905AC0674F600D3041200000030000
Shop #: WSC 12345 123 12345
VCID: 2A0E0B13ECFBF1370F3-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 061216 04 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13202576141210080401
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579141210182244
Coding: 010000
Subsystem 4 - Part No SW: 13 202 579 14 HW: 132 025 791 41
Component: RLS 061216 04 42 2101
Serial number: ÿ132025791412101822
Coding: 323234
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13202580141106012556
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581141125202458
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00XAULG
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CC549F493DDA2FE69-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140800
Shop #: WSC 13202 938 00000
VCID: 47C852A75F292C5FF0D-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 688AB11B32770327D97-803C
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECB132CFB3137CF3-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 41DC4CBF710D126F3E9-8014
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
Shop #: WSC 00788 648 00255
VCID: 77A8E2676F499CDF40D-8022
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000053044
ROD: EV_RDKBERU30_005.rod
VCID: 372822672FC95CDF80D-8062
End----------(Elapsed Time: 01:12, VBatt start/end: 13.8V/13.9V)-----------
PROBLEMS:-
1)UNABLE TO LOCK CAR,ABLE UNLOCK BOOT, INDICATORS BLINK WHEN UNLOCK PRESSED
2)AFS NOT MAKING ADJUSTMENT OF HEADLIGHTS
3)DRLS NOT GETTING ON WHEN CAR IS SWITCHED ON , BUT THEY GET ON ONCE HEADLIGTHS ARE ON
4) HOW TO ACTIVATE AUTO WIPE OF WIPERS
ciclo wrote: Mon Aug 20, 2018 5:39 pm
Autoscan!
hmthakur wrote: Mon Aug 20, 2018 6:01 pm
ASAP.
Coding.
Yes, it is the previous process.
(I can't understand that you do not understand the point 2 that I wrote)
In 2 I mean what you comment on later (car not locking) so that you make sure you do everything correctly.
If you have performed the whole process of matching remotes correctly the remote lock button must work and your car must close. YES or YES.
AFS unit (55 Address)
New coding
0116000001000000
hmthakur
Post by hmthakur »
ciclo wrote: Mon Aug 20, 2018 6:45 pm
Autoscan!
ASAP.
Coding.
New coding
0116000001000000
DOES THIS MEAN I HAVE TO REPEAT PROCESS
CHANNEL 01, 0, TEST,SAVE, PRESS LOCK NOW ??
hmthakur wrote: Mon Aug 20, 2018 6:03 pm PROBLEMS:-
3)DRLS NOT GETTING ON WHEN CAR IS SWITCHED ON , BUT THEY GET ON ONCE HEADLIGTHS ARE ON (
3
It is highly probable that the bixenon headlights installation (which is not my problem) is not correct.
Check the wiring. :arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
4
Read the owner's manual.
hmthakur
Post by hmthakur »
Cicolo
Just asking you even if bcm is in factory mode, does it accept coding
