Monday,20,August,2018,21:03:09:19846
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: MEXC15608FT079060 License Plate: MH-15-20-18-1
Mileage: 11730km-7288mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 65
VIN: MEXC15608FT079060 Mileage: 11730km-7288miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D84C00F1D15260FAA1-8038
Readiness: 0110 0101
Part No SW: 0AM 300 062 R HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501412085377
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3B203E571F6178BF645-806E
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C94614246F4251C0800904
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 055498AF25A5FE4F421-8050
Serial number: 11121404651355
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F7434073AD9703B-802A
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40DA49BB7A871B67317-8014
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 073170395
Coding: 3AB02BBF08A30000013806917CEB9E905AC0674F600D3041200000030000
Shop #: WSC 12345 123 12345
VCID: 2A0E0B13ECFBF1370F3-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 061216 04 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13202576141210080401
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579141210182244
Coding: 010000
Subsystem 4 - Part No SW: 13 202 579 14 HW: 132 025 791 41
Component: RLS 061216 04 42 2101
Serial number: ΓΏ132025791412101822
Coding: 323234
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13202580141106012556
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581141125202458
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00XAULG
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CC549F493DDA2FE69-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140800
Shop #: WSC 13202 938 00000
VCID: 47C852A75F292C5FF0D-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 688AB11B32770327D97-803C
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECB132CFB3137CF3-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 41DC4CBF710D126F3E9-8014
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
Shop #: WSC 00788 648 00255
VCID: 77A8E2676F499CDF40D-8022
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000053044
ROD: EV_RDKBERU30_005.rod
VCID: 372822672FC95CDF80D-8062
End----------(Elapsed Time: 01:12, VBatt start/end: 13.8V/13.9V)-----------
PROBLEMS:-
1)UNABLE TO LOCK CAR,ABLE UNLOCK BOOT, INDICATORS BLINK WHEN UNLOCK PRESSED
2)AFS NOT MAKING ADJUSTMENT OF HEADLIGHTS
3)DRLS NOT GETTING ON WHEN CAR IS SWITCHED ON , BUT THEY GET ON ONCE HEADLIGTHS ARE ON
4) HOW TO ACTIVATE AUTO WIPE OF WIPERS
