Perfect, thank you. :wink:
You have to buy these two Dimmers:
- 7E0941333 ... with halogen headlights. (e.g, second hand)
- 6Q0941334 ... with bixenon headlights. (e.g, new)
... in order to cover all the possibilities in the new electrical installation (wires), now, with halogen headlights, or when you install the Bixenon headlights in the future.
The parts already installed MFSW/CCS/IC 3d or the new parts (OEM, right parts) that you install in the future will work perfectly (RLS, power windows, etc), ...with the right codings.
Apart:
It is not possible to install an original relay for the automatic lights due to the location of the supports/brackets/holders/boxes that could support/hold/fix it.
(It is possible, but the wires length/weight would be absurd)
This is not a problem, we can use one of the two screws that fix the brackect for the connection housings to the BCM support to hold a non-original Relay (12v 40A).
Example:
What do you think?
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
ciclo wrote: Sun Jul 08, 2018 6:41 am Perfect, thank you. :wink:
Apart:
Example:
What do you think?
Thanks ciclo, my t5 has oem the dimmer the 7E0 941 333 B.
Btw tomorrow i go to France to buy oem brand new xenon adaptive headlights for 750euros,
adding extra relay is no problem I can live with it if it works as it should and without a fault. I can even make the adjustments for the relay holder.
So we start in the beginning what do i need to fix. btw friend of my have the harnas of golf 7 RLS i can buy from him is this the same like my t5 and your 6r? thanks a lot man.
El Boss wrote: Sun Jul 08, 2018 11:58 am Thanks ciclo, my t5 has oem the dimmer the 7E0 941 333 B.
Take a pic of your dimmer, that part number is not correct.
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
Sorry I'm wrong it's level control. :oops:
El Boss wrote: Sun Jul 08, 2018 4:27 pm Sorry I'm wrong it's level control. :oops:
Exactly, ... it's the reason why you must install the previously indicated dimmers.
El Boss wrote: Sun Jul 08, 2018 11:58 am btw friend of my have the harnas of golf 7 RLS i can buy from him is this the same like my t5 and your 6r? thanks a lot man.
What is the mirror (ref. number) you have to install according to the holder attached to the new windshield?
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
ciclo wrote: Sun Jul 08, 2018 5:05 pm
Inside mirror? i dont know. I have to search on web.
I think this is the right number of the rls 5K7 955 559 B around sensor what you think good one or no?
:arrow: Read and draw your own conclusions.
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
ciclo wrote: Sun Jul 08, 2018 7:03 pm :arrow: Read and draw your own conclusions.
Good morning ciclo can you make for me the wiring that provided for AUTO rls and FOG or not? I will pay for it.? And if you can make them on time you can give to my friend he is now for a 4weeks in spain.
Another thing. Xenon adapters are the same as golf6 and polo 6r with led drl or not? Thank you for your help. :mrgreen:
The automatic dimming mirror connector depends on the type of the new mirror you will install, this connector can be 6-pin (T5/6R mirror-->2014) or 8-pin (T6/6C mirror 2015-->).
Therefore, we go back to the previous question, what automatic dimming mirror (part number) are you going to install? (which is depending on the installed retainer plate in the new windshield)
If you had read this thread I would not have to explain what is already explained in the posted links. :roll:
I don't manufacture the wiring for fog lights. Maybe this will be helpful for you:
https://www.kufatec.de/shop/en/volkswag ... vw-t5-2010
Fog lights + Static Cornering Lights. Retrofit. (PQ25)
Install new 0.5mm2 wire from T17/8 light switch connector (or T10/3 RED connector for retrofitted automatic lights) to T73a/7 BCM black connector.
Install new 1.5mm2 wire from the output of a 15amp fuse (+30 signal, Battery) to T73b/11 BCM white connector.
- Left
Install new 1.5mm2 wire from T73b/9 BCM white connector to T2/1 foglight connector.
- Right
Install new 1.5mm2 wire from T73b/10 BCM white connector to T2/1 foglight connector.
Both T2/2 to ground.
+ VCDS
Note: the assignment of slots 2 and 1 in T2 connectors depends on the model (T5/Amarok/6R/... etc)
Shipments are made by mail, I don't meet with anyone (space & time) to deliver parts. Image
El Boss wrote: Mon Jul 09, 2018 7:45 am Another thing. Xenon adapters are the same as golf6 and polo 6r with led drl or not? Thank you for your help. :mrgreen:
NO
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
Ok thank you ciclo. I will read al the threads and see how far i can get work on my t5 included the relay and t6 mirror thate you told me. Thank you.
All you have to do is read this thread. As I told you from the beginning, all possibilities are contemplated. Including the adapter harness T10-T14 for the bixenon headlights (as graylscott did).
This adapter harness T10-T14 (from kufatec) must be modified for your T5 (8K0/8K1). :arrow: Reason.
By adding two new wires.
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
Hey ciclo i have relay 12v50a wil it work with it? Or i need specifically 12v40a? Regards
The original relay is 40A. (645 vw relay)
However, one of 50A can be used.
What's the part number of that 50A relay?
