graylscott
Drives: T5GP
Post by graylscott »
Hello
I'm hoping I don't get booted of here for posting this as I don't have a Polo, I have a 2013 VW Transporter T5GP.
I know they share electrical systems and I also know that this forum is where the knowledge is about these systems! :)
I am looking to retrofit auto-headlights and genuine bi-xenons, but I am stuck with the pesky 17pin headlight switch.
I have tried making a loom using instructions from ciclo I found on the internet.
I have changed my BCM for a 090-D as instructed to by ciclo and am now opening a new topic as requested :)
My problem is, that with the loom in place, everything but the main beam works.
In off position: DRLs work
In sidelight position: Sidelights work + if I pull the switch out to fogs, the foglights work.
Auto position: Nothing (no DRL and nothing when dark outside)
Main beam: Nothing (the light even goes off on the switch)
Full beam: Does not work on any switch setting
Full beam (flash): works on all settings.
The loom I made includes a fog light relay, but my fogs are factory so I'm not sure if it was needed. The fogs work as cornering lights with or without the new loom.
I'm really hoping you can help on this as everyone on the T5 forums just keep telling me to get one of those auto-headlight kits from ebay. I want OEM standard!!
Thanks in advance!
G
Re: Auto headlight retrofit
Hello graylscott, welcome (again :)).
Please, post a VCDS Autoscan. It is not necessary to add a relay for the fog lights on the T5, ...but there is no problem if you add it.
Edit: Two Autoscans, before Auto lights wiring, and after ALW with 7H0937090 D BCM.
All the lights (without exception) will work perfectly in your T5GP. You can be sure. OEM!!! :wink:
graylscott
Drives: T5GP
Thanks ciclo
Still have no network on my VCDS laptop, but I'll bring home a thumb drive from work tonight so I can transfer to my Mac.
Before I do though, I'll give you a bit more info.
I am in a bit of a muddle with it a couple of things at the moment.
I have changed my BCM to the 090D and run two wires from instrument cluster to BCM.
My window regulators now work, as does my instrument cluster illumination. The problem is now that I have no feedback from my sliding door. It locks and unlocks fine via the fob, but the door doesn't show as being open on the cluster. If I open the door after unlocking without opening any others, the car will re-lock as it doesn't know the door has been opened. There is also a bulb warning on the dash, but this might be unrelated.
Is there additional wiring needed for the BCM?
I have fitted the xenon headlights with a kufatec harness (I bought it before found you) and coded based on their instructions. The lights are behaving very strangely.
In the off position, Only the the bottom half of the LEDs light up.
In the sidelight position, everything at the front is off. (You can't really tell in the picture as there is glare)
In the dipped beam position, only the projector bulbs are illuminated with the cut-off shields in the dipped position and the LEDs go off.
If I put the stalk into full beam position, you can hear the cuttoff shields drop into 'full beam' position, but the projectors go off and the inside H7 bulbs illuminate on their own.
If I pull the stalk back to flash someone, the cutoffs drop and the projectors stay on. Also the inside H7 bulbs illuminate.
Like I said, I will upload coding tonight so you can see the errors I have. (There are a few) :?
Thanks again
Gray
graylscott
Drives: T5GP
One more thing ciclo, are you able to supply the looms I need to complete this job?
I feel like this job is best left to the professionals (you) :D
I am applying knowledge of the Polo 6R here, I'm not sure it applies to the Transporter too.
can you describe the intended factory operation of the headlights?
main beam, is it by the xenon on the outside?
on the inside, it's the H7. is that the high beam?
and for high beam, should it always be H7 and xenon? of just H7?
did you run a wire from T73b/1 (black) to operate a new relay, that runs to the old wire from T17/4?
so the relay is as follows:
86 - GND
86 - T73b/1
30 - constant 12V, i.e. T17/15 wire
87 - T17/4 wire
it this is all good, it would be interesting to see the value of byte 18 and the value of byte 23 bit 0.
maybe it's necessary to add 20 to the value of byte 18 or set byte 23 bit 0 to 1.
If you do a high beam flash and you hear the relay, the problem is byte 23 bit 0.
iichel wrote: Tue Jan 02, 2018 7:05 pm I am applying knowledge of the Polo 6R here, I'm not sure it applies to the Transporter too.
86 - GND
86 - T73b/1
87 - T17/4 wire
...and T5 Bixenon headlights have an additional lamp for the High Beam in the place where the 6R Bixenon headlights have the static cornering lights.
graylscott
Drives: T5GP
Hi iichel
Forgive my n00b question, but T17? I don't have access to elsawin so I'm kind of in the dark :(
But in answer to your question, no I haven't added any relays nor run any extra power to the BCM. could this be the door issue?
Correct function of lights is as follows (i think)
Off position - LED DRL only (full)
Sidelight position - LED DRL only (dimmed)
Dipped position - Xenon with cutoff shield up + LED DRL (dimmed)
Full beam (push stalk) - Xenon with cutoff shield down + H7 + LED DRL (dimmed)
Flash (pull stalk) - Xenon with cutoff shield down + H7 + LED DRL (dimmed)
DRLs are supposed to dim with indicators too (they don't)
Gray
graylscott
Drives: T5GP
This is my auto-scan without the headlight switch wiring
Tuesday,02,January,2018,20:05:44:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH056633   License Plate: CU13OJZ
Mileage: 167070km-103812mi   Repair Order:
Chassis Type: 7H (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 56 61 77 0B
VIN: WV1ZZZ7HZDH056633   Mileage: 167070km-103812miles
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FK    HW: 03L 907 309 M
   Component: R4 2.0l TDI   H44 9978
   Revision: 26H44---    Serial number: 00000000000000
   Coding: 01254012232400080000
   Shop #: WSC 00592 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906019FK 004006
   ROD: EV_ECM20TDI01103L906019FK_003.rod
   VCID: 79F98BC1F808C18988-802C
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BT 300 045 P    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H07 2552
   Revision: 00H07V01
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_VW41.rod
   VCID: 428B2C2DD55E425199-8016
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A90A9B24A89174A96110
   Shop #: WSC 02736 790 49152
   VCID: 3A7B54CDB58E0A91C1-806E
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaticT5.rod
   VCID: 7CF792D5F73AF4A193-8028
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H78 0725
   Revision: B9078001    Serial number: 0671 135152826
   Coding: B8F279B84A612411932889716EAB8E50C280662F7E855841320003020000
   Shop #: WSC 02759 790 12345
   VCID: 2F6D75997ECCDF3966-807A
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 101012 05  54  0403
   Coding: 0730AD
   Subsystem 2 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  002 3313
   Coding: 010000
   Subsystem 3 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29150002478840076056
   Coding: A5FFFF
2 Faults Found:
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 19:59:28
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 19:59:28
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0106
   Revision: --------    Serial number: 32901225402382
   Coding: 108101
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K.rod
   VCID: 3A7B54CDBD8E0A91C1-806E
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00E7AUG
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 356147F19490E5E92C-8060
   Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
   Component: KOMBI         H06 0605
   Coding: 760A01
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
   VCID: 2E53689D71C6D6316D-807A
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H78 0725
   Revision: B9078001
   Coding: 042300
   VCID: 70EFB6E5A37280C13F-8024
   Component: IMMO          H06 0605
   Serial number:
   VCID: 6ADBA48D8DAE7A1171-803E
Address 56: Radio (J503)       Labels: None
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4R6214659
   Coding: 16000400040005
   Shop #: WSC 00078 790 00236
   VCID: 4683303DF1767E71B5-8012
5 Faults Found:
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 19:59:28
00873 - Bass Speaker Rear Right (R17)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 19:59:28
00876 - Treble Speaker Rear Left (R14)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 19:59:28
00877 - Treble Speaker Rear Right (R16)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 19:59:28
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 19:59:26
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H78 0725
   Coding: 030B1A73
   Shop #: WSC 02737 790 00000
   VCID: 6BD5A1898A5463190A-803E
2 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 20:00:27
02252 - Generator
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Time Indication: 0
                    Date: 2018.01.02
                    Time: 20:00:27
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663583958
   Coding: 0A00010000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 39794BC1B8880189C8-806C
2 Faults Found:
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Date: 2018.01.02
                    Time: 19:59:27
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167071 km
                    Date: 2018.01.02
                    Time: 19:59:27
End-------------------------(Elapsed Time: 03:48)--------------------------
graylscott
Drives: T5GP
The diagram I used to create the loom is this.
I will thoroughly review the information you provided. I've already seen some mistakes in the coding, but please wait for me to review everything thoroughly.
Do you currently have any Kufatec wire installed?
If yes, you have to post the Kufatec wiring installation guide (Link? or link to the sale) ... and you have to tell me which Kufatec wires are currently installed.
The diagram used for Auto lights is correct :mrgreen: , but as I told you it was not necessary to install the fog lights relay for your T5. Now you must leave it as it is, no problem. :wink:
graylscott
Drives: T5GP
I have a kufatec RLS loom which has been in for 6 months or so (although it only functions as a rain sensor currently as lights aren't going via the BCM)
The first time I did a RLS retrofit (on a Passat B6) I made the loom myself but was lucky enough to gave the 10pin light switch already in that car. I shouldn't have been so lazy this time
I also have the standard Kufatec xenon retrofit loom. I bought it without noticing that it says that it is only for vehicles with Rain/Light sensor.
Here is a link to the install instructions.
https://www.dropbox.com/s/rzbedzgoef2sb ... 9.pdf?dl=0
Hope this helps!
Thanks again for all your help!!
graylscott wrote: Tue Jan 02, 2018 9:44 pm I also have the standard Kufatec xenon retrofit loom. I bought it without noticing that it says that it is only for vehicles with Rain/Light sensor.
https://www.kufatec.de/shop/en/volkswag ... r-vw-t5-gp
Says ---> Note: ONLY for vehicles with rain / light sensor, Pr.-Nr .: 8K3
8K3 PR code = Separate daytime running lights with low beam assistant and "Coming Home" feature.
So the wiring shown below is correct but not in its entirety for your T5 (No 8K3 or 8K8 from factory).
As you can see on image, only two wires arrive to the BCM (for parking/side lights -according Kufatec installation guide-) and your T5 needs two more, from T14 connectors to BCM (for DRLs).
But we'll talk about this a bit later, now it is necessary a previous preparation of the coding for your new BCM and other things.
Let's start:
(you can take a seat, this topic will be very interesting if Gray is willing to get all the lights to work correctly on his T5, ...all is solved in my mind 8))
After having to work hard to get correct information from your T5 (because you have not posted an autoscan with your previous BCM... :lol:) I've coded your new BCM with the final coding so that your Bixenon headlights and the automatic lights work correctly.
This BCM final coding will help us in the long (but easy) process to solve all current problems.
First thing to do, take/plug the VCDS in your T5 and do the following:
- Go to address 19, Gateway, enter in the Installation List, remove address 61 and save the changes.
- Go to address 9, Cent Elect (BCM), enter this final long coding:
B0A03DBA0EE1241193284E716EEB8E554280662F60855841320000020000
How to do it? like explained in this guide (point 20) :arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing (copy-paste)
It will solve the sliding door problem and other things (the current coding from your previous autoscan is a disaster) and it will throw several faults related to lights.
The more faults the better and easier to solve the problems.
Repeat with me... the more faults the b... ('m kidding...hahaha)
- Go to Autoscan, click on Gateway Installation List, wait..., Clear All DTCs, wait..., Done, repeat this process...
Now click Start button. Wait the full reading and Save the Autoscan. Post here. This is the more important Autoscan.
I'll check the autoscan and you'll be getting ready to make several changes to the original wiring. It will be a long but easy process that I will explain here in detail for everyone who took a seat. :lol:
*takes seat
graylscott
Drives: T5GP
Fantastic, thanks ciclo!
I've been on the edge of my seat at work wanting to get back to give this a try!
I'm definitely willing to do what it takes to get this sorted.... Hopefully it can help others in my predicament!
The good news is that the coding you gave me did indeed fix the sliding door feedback issue (but you knew that :wink:)
The bad news, no additional errors in the autoscan.
Wednesday,03,January,2018,17:37:11:53651
www.Ross-Tech.com
Scan: 01 02 03 04 08 09 10 15 17 19 25 56 77 0B
   Revision: 00H07V01
   Coding: 0014
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
   Coding: B0A03DBA0EE1241193284E716EEB8E554280662F60855841320000020000
   Coding: 0730AD
   Coding: 010000
   Coding: A5FFFF
2 Faults Found:
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Time Indication: 0
                    Date: 2018.01.03
                    Time: 13:58:02
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Time Indication: 0
                    Date: 2018.01.03
                    Time: 13:58:02
   Coding: 108101
   Coding: 760A01
   Revision: B9078001
   Coding: 042300
   Serial number:
5 Faults Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Time Indication: 0
                    Date: 2018.01.03
                    Time: 13:58:02
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Time Indication: 0
                    Date: 2018.01.03
                    Time: 13:58:02
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Time Indication: 0
                    Date: 2018.01.03
                    Time: 13:58:02
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Time Indication: 0
                    Date: 2018.01.03
                    Time: 13:58:02
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Time Indication: 0
                    Date: 2018.01.03
                    Time: 13:58:00
2 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Date: 2018.01.03
                    Time: 13:58:01
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 167079 km
                    Date: 2018.01.03
                    Time: 13:58:01
End-------------------------(Elapsed Time: 03:43)--------------------------
Any ideas?
graylscott
Drives: T5GP
Do i need to have re-fitted the headlight switch wiring at this point?
