UK-POLOS.NET - THE VW Polo Forum • iichels VW Passat 2.0 TSI DSG 4-Motion 2017 - Page 9
Page 9 of 14
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Posted: Fri Dec 01, 2023 5:51 pm
by iichel
I guess i should use more Odis then! Thank you very much patil
edit:
And done!
Also flashed the dataset for easy kick and set the parameters in the control module... no luck for that unfortunately
Posted: Fri Dec 01, 2023 7:46 pm
by raduss
I compared mine and yours with coding + adaptations. Only I don't have PLA 3.0 activated yet because there was no time to install additional sensors, but I already have the module installed just activated under eight sensors
Posted: Fri Dec 01, 2023 7:52 pm
by iichel
That's a really cool comparison. Is that a publicly available tool or one you made yourself?
Posted: Fri Dec 01, 2023 8:53 pm
by raduss
ODIS-Explorer
Posted: Sat Dec 02, 2023 12:49 pm
by iichel
A new addition to my autobiography:
Current door controler (HW: 5Q0959593B / SW F)
Desired one (HW: 5Q0959593F / SW L):
Will it fit? Nope...
Old connector: 1K0971975
New connector: 4M0971975
They rotated the power plug. Why? :evil: And of course for all four doors.
What else didn't work?
Slip ring: 5Q1953549A / C / F = facelift B8.5 / G7.5 / golf 8 with heating
It needs 5Q1 stalks too.
Will it fit B8 pre-facelift (5Q0 stalks/slip ring from factory)? Physically, yes! Change wiring? Yes! One new wire for LIN, CAN is left over.
Connector is (still) 5Q0972726
Credits to unknown (probably Polish) author.
Wires need to be moved. There is an error in this page, LIN is from T73c/54, not a/54!
Coding is easy, set adaptation channel in BCM:
Address 09 5Q0 937 086 BM
channel ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter
adapted from CAN
to LIN
Remove address 16 from CAN installation list
One error persisted in the DSG gearbox for selector lever P position. I made a new wire to BCM A24 for this, but no luck, the gearbox really needs address 16.
BCM was also sad about P input signal. Perhaps FL BCM will solve this, but for now I put back my 5Q0 slip ring.
I'm pretty sure this will work on a manual gearbox. Heating was working just fine.
A morning of failure and cold.
Posted: Sun Dec 03, 2023 10:23 am
by ciclo
In the Golf7.5 there are also these small differences (door module connectors, ring/stalks), for example Slavik's Golf7.5 (MY J) vs my Golf7.5 (MY K).
Maybe you can find something new/differences in the Golf 7-7.5 diagrams - by comparison - that could be useful to you.
The wiring of the dual-clutch gearbox that corresponds to each model is specified...
It's just an idea.🤷‍♂️
VW is playful with the naming of the BCM MQB connectors depending on the model... although it is specified at the end of the diagrams (in the images of the units).
Posted: Sun Dec 03, 2023 10:38 am
by iichel
The funny thing is, my dq250 gearbox was cancelled with the introduction of the mk 7.5, more or less. I could not find a scan with both the dq250 gearbox and the 5q1 stalks.
I connected the wire from the shift lever P position to BCM a24, like in the facelifted models. But these come with dq200, dq381, dq400e and dq500 But the databus missing communications persisted. I guess the dsg really must see the module 16, since it always had cars with that module present, bar perhaps one year of polo 2g GTI.
One thing I failed to test is to let the car sleep. I'll follow up on that.
Posted: Wed Dec 06, 2023 2:44 pm
by iichel
New battery, yeay! Preventive maintenance on my factory fitted 92Ah AGM battery. It's replaced with a brand new 96Ah Exide AGM battery.
And since the Passat has an aux heater, big battery, battery in the boot, for extra struggles while changing.
To finish it off, changed the serial number in battery adaptation, so the car knows it has a new battery and will charge it accordingly.
The old battery wasn't sure about being a VW battery, a Varta or a JCB. And the Varta is actually from the Bosch factory.
Posted: Wed Dec 06, 2023 6:47 pm
by patil
patil wrote: Fri Dec 01, 2023 5:24 pm Image
Check this adaptation channel in address 76 in ODIS-E. It shouldn't be active in your case. In VCDS adaptations list of address 10, this adaptation channel is not there! :shock:
Let's restore back the reputation of VCDS. :mrgreen:
The adaptation is there albeit with confusing label. ODIS adaptation is more clear though.
Posted: Wed Dec 06, 2023 7:00 pm
by iichel
Thanks patil for re-instating my trust in my favourite tool!
Posted: Wed Dec 13, 2023 5:00 pm
by iichel
iichel wrote: Sat Dec 02, 2023 12:49 pmWill it fit? Nope...
Will it now fit? Yes, I bought myself four correct connectors.
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 L    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0074
   Serial number: 000308417617172 Dataset Number: V03935315EN 0001
   Coding: 0A71267951
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 59EF7025A99B970208D-800C
2 Faults Found:
12716048 - Databus
          U1121 00 [00001001] - Missing Message
          [T¸rsteuerger‰t - Spiegel_01 - fehlende Botschaft]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 168212 km
                    Date: 2023.11.29
                    Time: 12:12:52
12650512 - Databus
          [Steuerger‰t f¸r eCall - TM_01 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 168212 km
                    Date: 2023.11.29
                    Time: 12:12:52
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 190417EDJ1110A Dataset Number: V03935256EF 0001
   Coding: 00351A20D200028000111000
   Shop #: WSC 30389 123 56831
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43D3B24D3B173DD2721-8016
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 170617EFH29274 Dataset Number: V03935256ZD 0001
   Coding: 00351020DE00028200111000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DDB749240D34DA797-8016
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0041
   Serial number: 070617EF614855 Dataset Number: V03935256XR 0001
   Coding: 000410200100028000001000
   ASAM Dataset: EV_DCURearDriveMAXKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
   VCID: 45D7AC55352303E25C5-8010
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 070617EF613546 Dataset Number: V03935256NT 0001
   ASAM Dataset: EV_DCURearPasseMAXKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
to
   Coding: 8A79267951
   VCID: 59EF7025A99B970208D-800D
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
   Coding: 00351A20D200028000011000
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 4ACD9F691C3DEC9AB17-801F
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
   Coding: 00351020DE00028000011000
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 49CFA065193BE782B8D-801D
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
   VCID: 4CC199711649F2AA83B-8019
   Component: TSG HBFS005 0350
   Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
- changed front controllers and coded correctly with the old coding (donor was passat)
- changed rear controllers, wrote dataset and coded correctly (donor was audi A3)
- learn window end stops
- clear all errors
- changed some small codings (dimming exterior mirror via FLA, memory passenger seat disabled)
- enjoy
Posted: Wed Jan 03, 2024 12:23 pm
by iichel
casually picking up some new toys
Posted: Thu Jan 04, 2024 7:11 pm
by iichel
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 3G8 907 044 T    HW: 3G8 907 044 T
   Component: Climatronic   H10 0221
   Coding: 12020024104411011115500D0018592A
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
   ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
   VCID: 3E25C3B950F5503A1DF-806B
   Air quality sensor:
   Humidity sensor: exterior:
   Rear air conditioning block 1:
   Subsystem 3 - Part No SW: 11A 907 049 A    HW: 11A 907 049 A
   Component: E265 KPH SH  H02 0183
   Serial number: G04S01.11.2100972191
   Coding: FFFFFF
3G8 907 044T = seat heating with a funny icon/
Oh right, the local village idiot bought some Arteon seats for his Passarteon ... :twisted: :mrgreen:
https://imgur.com/a/qOwIdiQ
Will convert the 'normal' electric seats to
- Both sides memory (driver on address 36, passenger on address 06), needs a GND to T32/2 and the same 3Q0/5Q0 module, and an adaptation channel set to 'passenger'
- Both sides ventilation
- Both sides massage (like my earlier trick --> viewtopic.php?p=597034#p597034)
Posted: Thu Jan 11, 2024 9:01 pm
by iichel
So I've been putting stuff into cars that don't belong there. Again. I know, you must be getting really tired of me. I'm sorry.
A while ago I saw some Arteon seats for good money.
They needed some love, some airbags, some plastic trim, switches and some seatbelt locks.
So I bought them, bought all the extra parts and decided to get myself an upgrade for a memory passenger seat too.
The current passenger seat was a full electric one with 'dumb' switches.
Shouldn't be that hard and the Superb came with those from factory. And why wouldn't you?
https://forums.ross-tech.com/index.php?threads/29947/#post-251560
It's basically the same module as the driver seat, with an extra GND to to T32/2.
Typically the driver gets a 3Q0 (memory + massage) and the passenger gets a 5Q0 (memory).
I went the 3Q0 + 3Q0 way, because why not, so I got going. Wired it up like a RHD driver seat with memory and massage.
That was pretty easy, I didn't have to change any motors.
So, next step is to do coding and basic settings. I started with the driver seat disconnected and talked to the module on address 36.
Adaptation:
channel IDE06869-installation position
adapted from
Memory seat driver side
to
Front passenger side memory seat
Power off, lock, wait and reboot. Now the module shows up at address 06.
Next step was to check for errors and sure enough, dataset was invalid. So I got myself an Arteon driver seat dataset via SVM tricks and changed the header from 0x0036 to 0x0006.
This way I could use the O-tool to write the dataset to module that now identified as 06. I had to do it via Skoda project 48, since VW 48 wasn't very familiar with module 06.
Next step, basic settings. Of course the seat was pretty unhappy and it took some coding...
Experimental coding allows for many of these motors to be set:
SLV - Sitz Lange Verstellung - Seat front/rear
LNW - Lehne Neigung Verstellung - Backrest angle
SHV - Sitz Höhe Verstellung - Seat height
SNV - Sitz Neigung Verstellung - Seat tilt
LDH - Lehne D? Höhe - Lumbar height
LDW - Lehne D? Weiten - Lumbar front/rear
I set the first four to SLP_with_SLP_ErrorTest and the lumbar gear to Hall_with_Hall_ErrorTest
All basic settings ran just fine, except for the front/rear. I tried a lot but I got fed up and decided to take matters into my own hands.
So I put the passenger module underneath the driver seat (with position sensor for front rear, coded for Hall_ErrorTest) and did the basic setting for that axis on the driver seat.
And then put back the module to the passenger seat. Guess what? That works! Pretty dumb huh?
So, all errors gone, coded the modules like I described here: https://forums.ross-tech.com/index.php?threads/40896/
Now everything works. Pretty neat result. Pretty useless as well, but hey, that's me.
Thursday,11,January,2024,21:16:17:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN:   License Plate:
Mileage: 173093km-107555mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42
          44 47 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7
VIN:   Mileage: 173093km-107555miles
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---    CVN: B7DB7878
   Coding: 091D003A2476050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259J.rod
   VCID: 313FE88591ABBF4290D-8065
   VINID: 9E69EAAAA0D3A9A54008518520274044B7
2 Faults Found:
15170 - Engine Oil Temp. Sensor (G8)
          P0198 00 [00101111] - Signal too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 171917 km
                    Date: 2024.01.04
                    Time: 16:32:32
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 70 ∞C
                    Intake air temperature: 59 ∞C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.953 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 100 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 13090.0 kPa
15171 - Engine Oil Temp. Sensor (G8)
          P0196 00 [00101111] - Implausible Signal
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 171917 km
                    Date: 2024.01.05
                    Time: 10:44:08
                    Engine RPM: 1060.25 /min
                    Normed load value: 11.0 %
                    Vehicle speed: 15 km/h
                    Coolant temperature: 10 ∞C
                    Intake air temperature: 9 ∞C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 14.140 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 32 s
                    MAP_MES_SAE: 75 kPa
                    FAC_TPS_1_SAE: 17.968750 %
                    FUP_H_SAE: 8460.0 kPa
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5297
   Revision: 06454104    Serial number: TFK01706160335 CVN: 000099EF
   Coding: 0014
   Shop #: WSC 05311 115 00065
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1C612931E629222AD3B-8049
2 Faults Found:
10657 - RPM Signal from ECU
          P0726 00 [00000010] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [00000010] - -
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Q0 614 517 FM    HW: 5Q0 614 517 AH
   Component: ESC           H62 0755
   Revision: 00000000    Serial number: 61907000000236
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 015F7845618BEFC220D-8055
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0448732144 Dataset Number: V03935260TX 0001
   Coding: 1F20200723
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB.rod
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8001216
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0024
   Serial number: Y0006PKA28228 Dataset Number: V03935285VX 0001
   Coding: 001800020000150081C480808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3C21C9B146E9422A33B-8069
   Air quality sensor:
   Coding: FFFFFF
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865829061700DO Dataset Number: V03935260TT 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06556B5948A5C8FA15F-8053
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170615  042 0607
   Serial number:         170629234856
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S4Y17M06D29H19M25S21
   Coding: 06A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01 0032
   Serial number: 14 04 2017  10001690
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1714382PB
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000070188699
   Humidity sensor: interior:
   Blower 1 for left front backrest:
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0158736
   Blower 1 for left front seat cushion:
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Blower 1 for right front backrest:
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0145994
   Blower 1 for right front seat cushion:
   Subsystem 10 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0146336
   Coding: 8A79267951
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V315
   Coding: 351F5FFBDFFFCF28979F813681500D80000000000099000032
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CBA65D0F2F11F2AE9-8013
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 25061741350001 Dataset Number: V03935290WM 0001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD0A549DB770228D-806D
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
   Component: Airbag VW21   006 0721
   Revision: --------    Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
   Coding: 98FCC0C0008000005C5400CF000800000065
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0E45537920D580BAADF-805B
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0031T01500
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Component: BeltPretRevFR  106 1032
   Serial number: 3G1857706G0185R01460
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 606 17
   Component: SideSensor_Df  008 0887
   Serial number: 357000000000507D3628
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 001 806 17
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000008D140C62J
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Dr  301 0148
   Serial number: 3510091305210000000U
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Pr  301 0148
   Serial number: 352002F2F52100000009
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 406 17
   Component: FrontSensor_D  304 0149
   Serial number: 3550040279610000000%
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 KT    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0265
   Revision: FF035035    Serial number: 20170828500092 Dataset Number: V03935250KY 0001
   Coding: 8410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 C
   Component: KOMBI         406 4191
   Coding: 07AD0898FE8C000C01887F0F3001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2A0DFFE9BC7DCC9A517-807F
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0080
   Coding: 9309
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS.rod
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000276932
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5502
   Serial number: 06071710802132 Dataset Number: V03935278KN 0001
   Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
   GVL: 01DE3C0008000600C0FC80000006CC0010000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFEBD177F9932569-802B
   Generator:
   Component: 4-00-03-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL  H03 0219
   Serial number: 17036218123222100161
   Coding: AF0B00
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H10 9070
   Serial number: 5131394104
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H26 0780
   Serial number: 0066181
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3003201700010095
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00017.05.17 Dataset Number: v1260x015G0 0000
   Coding: 0601
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 17000160250002
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71BF2885512BFF42D0D-8025
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
   Coding: 001800020000150081C481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide.rod
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000591782366  Dataset Number: V03935345YL 0001
   Coding: 62954640
   ROD: EV_HREntryHellaGen3Kl15.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000606636104
   Coding: 00351A20D200028200011000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5082
   Dataset Number: 8V0909852AA 0001
   Coding: 93070000
   Shop #: WSC 00015 115 00319
   ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
   ROD: EV_AMPMst16C3Gen2ALPI_VW48.rod
   VCID: 6B833AED73071592EA1-803F
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 01071710801233 Dataset Number: V03935339UR 0001
   Coding: 000000060100035207007F010A0000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BD2789542DC45A297-8027
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
   Coding: 00351020DE00028200011000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 022 B    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1367
   Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
   Coding: 02840201000000005111110200880A301F0106E4012004009F
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_VW37.rod
   VCID: 323DE78994AD845AE97-8067
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1915518
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 809 PC    HW: -----------
   Component: ECE 2023  --- 0310
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3829D5A172D16E0AD73-806D
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0446947174 Dataset Number: V03935259HF 0001
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 42DDB749240D34DA797-8017
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG069231 Dataset Number: ----------
   Coding: 01840200E70F200004314817
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0265
   Revision: --------    Serial number: 31344982200000 Dataset Number: V03935262CS 0001
   Coding: 02A8
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 46D5AB59082508FA55F-8013
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1421
   Serial number: E80320003220200 Dataset Number: V03935411EY 0001
   Coding: 0004019821FAC02888DF14001020004000218000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW38.rod
   VCID: 3635DB9978C5987AC5F-8063
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: V03935218DJ 0001
   Coding: 208040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 372BD69D7FCF6172DE9-8063
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 16753B191805787AE5F-8043
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0003
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 02:44, VBatt start/end: 14.2V/14.3V)-----------
Thursday,11,January,2024,21:23:21:11868
www.Ross-Tech.com
VIN: WVWZZZ3CZJE025658   License Plate:
VIN: WVWZZZ3CZJE025658   Mileage: 173093km-107555miles
1 Fault Found:
          P0198 00 [00100111] - Signal too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 173093 km
                    Date: 2024.01.11
                    Time: 21:17:14
                    Engine RPM: 768.25 /min
                    Normed load value: 4.7 %
                    Coolant temperature: 89 ∞C
                    Intake air temperature: 32 ∞C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 14.296 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 3 s
                    MAP_MES_SAE: 35 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.973 V
                    FAC_TPS_1_SAE: 12.890625 %
                    FUP_H_SAE: 18840.0 kPa
Readiness: 1010 0000
   Coding: 0014
   Coding: 1F20200723
   Air quality sensor:
   Coding: FFFFFF
   Coding: 0F4DFD
   Coding: 06A8DD
   Light switch:
   Alarm horn:
   Coding: 8A79267951
   Coding: 80000D
   Coding: 80000D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 8410
   Coding: 9309
   Generator:
   Coding: AF0B00
   Analog clock:
   Coding: 0601
   Coding: 62954640
   Coding: 93070000
   Coding: E02400
   Coding: E02400
   Data carrier:
   Coding: 02A8
End----------(Elapsed Time: 02:44, VBatt start/end: 14.3V/14.4V)-----------
Posted: Thu Jan 11, 2024 9:40 pm
by iichel
Oh, I also got some new stuff:
Will elaborate on that as well, later. :mrgreen:
