iichels VW Passat 2.0 TSI DSG 4-Motion 2017
In other news, the Polo (finally) has its MQB brother, the VW Passat B8 2.0 TSI DSG 4-motion from 2017 (MY2018)
https://imgur.com/a/Kxgf148
Exterior:
- R-Line exterior package
- LED high headlights with DLA and AFS
- LED high tail lights and licence plate lights
- Oryx White paint
- Panoramic sunroof
- Folding mirrors
- Electric tailgate
- Electric folding towbar
- Puddle lights
- Heated windscreen washers
Interior:
- Active Info Display
- Electric folding mirrors
- R-line interior with black roof liner and R-Line door sill trim
- Full electric leather R-Line with memory and massage function
- Keyless entry and start system 'Kessy' with front and rear door keyless locking
- Climatronic 3 zones with auxiliary heater
- Rain and light sensor with automatic lights with CH/LH
- Adaptive cruise control
- Driving mode selection
- Ambient lighting RGB "plus" (RGB in doors, dash; white in ceiling and center console)
- Front and rear seat heating
- Alarm system
- Lane assist
- Lane change assist
- 230V connection in the armrest
Infotainment and assistance systems:
- MIB2.5 9.2 Discover Pro system
- 12K PDC/OPS with PLA3.0 and TJA
- Reversing camera high
- Dynaudio sound system
Running gear:
- DCC with front and rear independent suspension
- Progressive steering rack PR-1N7
- Front 340mm disc brakes with single piston caliper
- Rear 310mm disc brakes with single piston caliper
- Electronic parking brake with auto hold
- 19 inch Verona alloy wheels 3G0601025R 19x8 ET44 with 235/40R19 tires
- Direct TPMS
0x01 Engine:
- Factory fitted CJXA 2.0 TSI EA888 3rd generation engine (280hp/206kW, 350Nm) SIMOS 18
- Chiptuning 415 bhp and 525 Nm --> info
- OEM IHI IS38 turbocharger --> Garrett GTX2867R turbocharger
- OEM Facelift EA888 gen4 engine cover --> info
- Modifications to the OEM air intake --> info
- Later changed to --> R600 intake
- Wagner Competition intercooler --> info
- OEM steel oil sump --> info
- GFB DV+ T9359 diverter valve spacer --> info
- Racingline turbo inlet elbow
- Forge turbo muffler delete
- Audi RS3 LPFP 8V0919087A + controller 4M0906093K + adapter
- Autotech HPFP upgrade
- OEM Audi RS3 coil packs 06H905110P
- OEM Audi RS7 spark plugs 06K905601B
- OEM divertger valve 06H145710D
- OEM EA888 gen 4 06Q boosted PCV (06Q103495B + 06K103210D)
- G12 Evo coolant with 5Q0121407AA 5WA121407F expansion tank without silicate --> info on G12 Evo, info on 5WA tank
0x02 DSG:
- Factory fitted SYP 6-speed DSG gearbox 'DQ250'
- Upgrade OEM DSG oil cooler 02E409061C --> info (later removed due to DQ500 conversion)
- DQ250 SYP --> 7-speed DSG gearbox DQ500 SDM --> info
- VW Tiguan 5NB LED DSG lever 5NB713203K + 3G1711113G --> photo
- How to do a DSG oil service --> info
0x03 ABS:
- Factory fitted MK100 ESC with IPB (integrated parking brake)
- Factory fitted 340mm front discs with single sliding piston calipers and 310mm vented rear discs with single piston sliding calipers and EPB
- Upgraded SW 5Q0614517CH 0743 to 5Q0614517FM 0755
- Audi RS3 8V brake coolers info
- Front 340mm disc brakes --> Audi TTS 4-piston brakes with 338mm discs info --> Audi RS6 400mm ceramic discs with 6-piston Audi RS6 callipers info
- Rear 310mm vented disc brakes with single piston callipers with electronic parking brake --> Audi RS6 370mm vented ceramic brake discs with single-piston calliper and EPB
- ABS later upgraded to HW 5Q0614517BP SW 5Q0614517GS 0993 for experiments with the rear torque splitter differential
0x05 Kessy
- Factory fitted Kessy
- Retrofitted boot sensor 3G0962243 to facilitate easy open 'kick to open' --> info
- 3G0959893C "R" logo on the keys
- Upgraded to HW/SW 3Q0959435Q 1400 in an attempt to gain mirror fold via easy close (and successful)
0x06 Seat memory passenger
- Factory fitted non-memory full electric passenger seat
- Retrofitted passenger seat massage --> info
- Upgraded to Arteon front seats and added memory, massage, ventilation and easy entry --> info
- Updated SW to 3Q0959760D 0024
0x08 Climatronic
- Factory fitted climatronic with front and rear seat heating, Webasto and three-zone control
- Retrofitted facelift front and rear touch climatronic --> info
- Upgraded front touch panel from 3G8907044R to 3G8907044T for seat ventilation
- Retrofitted heated windshield --> info
0x09 Central Electrics
- Factory fitted BCM High (Seat heating, RGB ambient lighting)
- Upgraded to HW/SW 5Q1937084B
- Retrofitted headlight washer electrics to the 5Q1 BCM PCB --> info
- Added RGB ambient lights to the front and rear footwells, door handles and panoramic sunroof --> photo of front and rear door and roof
- Rear DRL stripes in the tail lights --> info
- Coded 30 colour ambient RGB lights --> info
- Upgraded light switch to 3G8941633 ICX for all weather lights
- Upgraded interior lights to touch lights (front 3GB947105, rears 3GB947291 3GB947292)
0x10 Park Steer assist
- Factory fitted 12K PDC/OPS with PLA3.0 and TJA
- Updated SW to 5QA919298L 0074
0x13 Adaptive Cruise Control
- Factory fitted ACC 5Q0 'Bosch' radar (behind the front logo, with the little mirror for calibration)
- Retrofitted 3QF ACC radar --> info
- Added pACC SWaP
0x14 Suspension and wheels
- Factory fitted electronically adjustable dampers with FPA
- Upgraded SW 5Q0907376B 0121 to 5Q0907376C 0130 for DCC slider
- Eibach lowering springs --> info
0x15 Airbags
- Factory fitted front and rear curtain airbags PR-4X4, with front passenger deactivation and driver knee airbag PR-4UN
- Upgraded to HW/SW 3Q0959655CP 0721
0x16 Steering Column electronics
- Added steering column combination switch without assistance button --> 3Q0953521P
- Changed to 5Q0953569B for heated MFSW
- Updated SW 5Q0953521KT from 0245 to 0265 to remove 291104 - Temperature Sensor for Heated Steering Wheel B1455 01 [008] - Electrical Failure
0x17 Instruments
- Factory installed Active Info Display
- Upgraded SW to 3G0920791C 4191 to activate VIEW button
0x18 Auxiliary heating
- Factory fitted auxiliary heater, so it has the battery in the boot and a funny washer reservoir.
- Upgraded SW to 5Q0963272K 0080
- Added second remote 3G0963511C --> info
0x19 CAN Gateway
- Factory fitted 3Q0 Conti High gateway SW train 5xxx
- Flashed SW to 3Q0907530AR 5502
- Modified dataset with DCC slider and R-button controls
- VW Passat B8 facelift MFSW + heating info
0x22 AWD
- Factory fitted Haldex gen 5
- VCDS modifications with RS3 clamping behaviour
- Upgraded to SW 0CQ907554J 7084
- Removed in favour of the Magna torque splitter
0x23 Electromechanical brake booster
- Factory fitted vacuum powered booster
- Retrofitted OEM 3Q1 eBKV in combination with the ceramic brake upgrade --> info
- HW: 3Q0909059A HW: 3Q0909059AA 0074
0x2B Steering Column Lock
- Factory installed ELV
- One of few untouched modules on my car
0x36 Seat memory driver
- Factory fitted with a full electric driver seat with memory, massage and easy entry
- Upgraded to Arteon seats and added ventilation --> info
- Retrofitted Passat B8 rear child seat --> info
0x3C Lane Change
- Factory fitted BSD with Side Assist during parking
- Upgraded 3Q0 based system (3C + CF) to 2Q0 due to incompatibility with AR GW SW
- Upgraded to HW/SW 2Q0907685B + 2Q0907686B 0150 --> info
0x42 Driver door
- Factory fitted central locking with folding mirrors
- Upgraded to HW 5Q0959593F SW 5Q0959593L 0350 due to errors in PDC module
- Retrofitted electronic rear child locks --> info
- Retrofitted double glazing --> info
0x44 Power Steering
- Factory fitted dynamic steering PR-1N7
- Updated SW to 3Q0909144M 5082 with Audi RS3 dataset
0x47 Sound System
- Factory installed Dynaudio
0x4B Multifunctional Module
- Factory installed LED High headlights with AFS and DLA
- Replaced with version F, in combination with my Matrix headlight retrofit.
0x52 Passenger door
- Upgraded to HW 5Q0959592F SW 5Q0959592L 0350 due to errors in PDC module
- Retrofitted auto dimming passenger mirror --> info
0x5F Information Electrics
- Factory fitted Discover Pro 9.2 inch MIB 2.5
- Upgraded to HW 5NA035022 SW 5NA035022B 1367 for DAB+ reception
- DAB+ antenna 3G9035577B
- Apple Carplay and Android Auto from factory
- Retrofitted wireless QI charger 3G0980611 + 3G1864263A
- AAWireless
- Installed MIB toolbox for activation of navigation in AID while using Google Maps
0x65 Tire Pressure
- Factory installed TPMS high with sensors in wheels
- Updated SW to 5Q0907273F 0011
- TinyQ dataset :)
0x69 Trailer
- Everyone loves 69
- Factory installed electrically swivelling towbar
0x6C Backup Camera
- Factory fitted RVC Compact 'Highline' with dynamic lines
- Retrofitted 360 area view camera --> info
- Dynaudio cover for the 360 cam module --> info
0x6D Trunk Electronics
- Factory installed electrical trunk
- Upgraded to HW 5Q0959107C / SW 5Q0959107Q 0265 for easy close
0xA5 Front Camera
- Factory fitted 3Q0 camera with Lane Assist and DLA
- Flashed SW 3Q0980654L 0610 + 60 second mod --> info
- Upgraded to HW 2Q0980653 SW 2Q0980653J 1423 with VZE swap and 600 seconds hands-free
0xA9 Structure Borne Sound
- Retrofitted Sound Actuator --> info
- Flashed Audi TTRS file for 5-cylinder sound.
0xBB Rear door driver side
- Upgraded to HW 8W1959595D SW 5Q0959595L 0350 due to errors in PDC module
0xBC Rear door passenger side
0xCA Sunroof
0xD6 Light Ctrl Left 2
- Replaced with the 992 modules for my Matrix headlight retrofit
0xD7 Light Ctrl Right 2
0x8126 Trq distrib RearL axle
- Retrofitted Magna Torque splitter from Arteon R
- Active rear diff for more sporty performance
- It was easier than thought after getting the correct MQB classic modules --> info
0x8127 Trq distrib RearR axle
Interior upgrades, mods and retrofits:
- Audi Homelink system --> info and operation via center console button
- VW Passat B8 boot management system --> info
- Skoda Superb USB-C charge port in the interior mirror --> info
- Rear USB port (charge only) --> info
- Passat B8 rear luggage curtain 3G9867871
- Passat B8 all weather floormats + boot mat 3G1061500A + 3G9061161
- Passat B8 rear privacy shades 3G9064365 --> info
- Skoda thrash can 5JA061107
- Lights in rear lid 6Q0947291 + 8KD947411 --> info
Exterior upgrades, mods and retrofits:
- Passat B8 alltrack kevlar skid plate --> info
- Wrapped the front fog light 'C' sections --> info
- Passat B8 / Mk7 /Mk8 golf Aero parts --> info
- Passat B8 facelift front logo with camera 3G7853600 --> info
- Tiguan 5NA "R" side emblems --> info
- Passat B8 facelift rear 'Passat' logo 3G9853687C
- Passat B8 facelift rear 'VW' logo 5H0898633
- Passat B8 black mirror caps
- Passat B8 R-Line tail lights with dual rear fog light
- Showroom dealer license plates 3G9071801
- Skoda washer reservoir cap 6V0955485
Wheels upgrades, mods and retrofits:
- Added VW Dynamic hub caps 000071213D
- Added VW wheel covers 000073900
- T-Roc 2GA 19 inch Estoril alloy wheels 2GA601025AQ 19x8 ET44 with 235/40R19 Michelin Pilot Sport 4 tires --> info
- Michelin Pilot Alpin 5 winter tires on the Verona wheels
Accessories:
- OEM VW bike carrier 3C0071105B
- OEM VW band aid kit 00093114
- OEM VW cool box 1T0065400 'Fritz the fridge' info
First:
Wednesday,14,December,2022,19:00:45:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: WVWZZZ3CZJEiichel   License Plate:
Mileage: 131667km-81814mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
          47 4B 52 5F 65 69 6C 6D A5 BB BC CA CF D6 D7
VIN: WVWZZZ3CZJEiichel   Mileage: 131667km-81814miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---    CVN: 73B77959
   Coding: 091D003A2476050B3004
   Shop #: WSC 05311 115 00319
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
   ROD: EV_ECM20TFS0203G0906259B.rod
   VCID: 2B03FAEDB387D593621-807E
   VINID: 9E69EAAAA0D3A9A54008518520274044B7
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01706160335 CVN: 0000580D
   Coding: 0014
   Shop #: WSC 05311 115 00065
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1C612931E629222B1BB-8048
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61907000000236
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
   VCID: 79AF10A5095BB703A0D-802C
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0448732144
   Coding: 1F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E25C3B950F5503BD5F-806A
   Rear lid opener control module:
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 DQ    HW: 5G0 907 044 DQ
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 1202002420411101111550000010192A
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
   Humidity sensor: exterior:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865829061700DO
   ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06556B5948A5C8FBDDF-8052
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170615  042 0607
   Serial number:         170629234856
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S4Y17M06D29H19M25S21
   Coding: 00A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01 0032
   Serial number: 14 04 2017  10001690
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1714382PB
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000070188699
   Humidity sensor: interior:
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617172
   Coding: 0271167951
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50F98D01FA61D64B373-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Coding: 320467DB59FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3537DC9565C39363045-8060
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 B    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0121
   Serial number: 25061741350001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_001_VW48.rod
   VCID: 3829D5A172D16E0B1F3-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PCG5P2/
   Coding: 98FCC0C0008000005C5400CF000800000065
   Shop #: WSC 05314 000 00001
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0849656142B1DE8BAF3-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0031T01500
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Component: BeltPretRevFR  106 1032
   Serial number: 3G1857706G0185R01460
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 606 17
   Component: SideSensor_Df  008 0887
   Serial number: 357000000000507D3628
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 001 806 17
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000008D140C62J
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Dr  301 0148
   Serial number: 3510091305210000000U
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Pr  301 0148
   Serial number: 352002F2F52100000009
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 406 17
   Component: FrontSensor_D  304 0149
   Serial number: 3550040279610000000%
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0235
   Revision: FF033033    Serial number: 20170627200018
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73B3228D2B37CD53EA1-8026
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
   Component: KOMBI         406 3193
   Coding: 07A40898FE8C000801886B0F1001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 290F00E5B97BC78390D-807C
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0075
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS.rod
   VCID: 3B23CAAD43E74513F21-806E
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000276932
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 06071710802132
   Coding: 0B0300347F015900FB00025E9C0F00010001070000000000000000000000
   GVL: 01DE3C0008000600C0DC80000006CC0010040000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 3333E28D6BB78D532A1-8066
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29170001407150107262
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H10 9070
   Serial number: 5131394104
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H26 0780
   Serial number: 0066181
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3003201700010095
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00017.05.17
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
   VCID: 4ACD9F691C3DEC9B797-801E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 17000160250002
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BF2885512BFF4318D-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0022
   Serial number: Y0006QFD15173
   Coding: 001000020000050081C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3A2DCFA94CDD7C1BE97-806E
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
   ROD: EV_RearRadarS1BoschVW48X_VW37.rod
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 190417EDJ1110A
   Coding: 003F1A20D200028000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43D3B24D3B173DD3BA1-8016
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 K    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5072
   Coding: 9307
   Shop #: WSC 00015 115 00319
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00RUVL
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   VCID: 6B833AED73071593221-803E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 01071710801233
   Coding: 000000060100035207004F01020000000000000000000000000000000000
   Shop #: WSC 05311 000 00001
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BD2789542DC45BE17-8026
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 170617EFH29274
   Coding: 003F1020DE00028200001000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DDB749240D34DBB17-8016
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 042 A    HW: 5NA 035 042
   Component: MU-H-LN-EU    H54 1121
   Serial number: A847G0HB006263
   Coding: 02840201000000005111000200080A101F0106E4012004009F
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_VW37.rod
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1915518
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 809 PA    HW: -----------
   Component: ECE 2022  --- 0195
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 40000000081630
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1916EB98A6B33B-8060
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0446947174
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0231
   Coding: 0184020163002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
   VCID: 392FD0A549DB7703E0D-806C
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31433445900000
   Coding: 0288
   ASAM Dataset: EV_DeckLidCONTIAU736 001014
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 41DFB845210B2FC3A8D-8014
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 14061711P11354
   Coding: 000408020000040100222347C150A90094000E300040
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_001_VW36.rod
   VCID: 3C21C9B146E9422BFBB-8068
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0041
   Serial number: 070617EF614855
   Coding: 000E10200100028000001000
   ASAM Dataset: EV_DCURearDriveMAXKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
   VCID: 45D7AC55352303E3945-8010
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 070617EF613546
   ASAM Dataset: EV_DCURearPasseMAXKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 208040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 006008
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D27C4B55DF34B23CC5-8068
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
   ROD: EV_RearRadarS2BoschVW48X_VW37.rod
   VCID: 372BD69D7FCF6173169-8062
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 16753B191805787B2DF-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0003
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 02:50, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
patil
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Post by patil »
Nice colour 👌 Oryx white is pleasant colour, Tiguan sold here has that colour option.
Welcome to MQB club iichel!! 😎...
....But wait, there is nothing left to upgrade in there😁
I'm afraid you're right, hardly anything that needs to be improved.
But that never stopped me now did it? :mrgreen:
So... the first mod has been done. Touch climatronic from the facelifted Passat/Arteon.
Parts:
front unit: 3G8907044R (...C is also fine) for climatronic with aux heater, without seat ventilation.
rear unit: 11A907049A
Since my front panel was new, I needed to do a basic setting of the flaps and a run in for the AC compressor.
All can be done with VCDS. 15 minute job. More pics: https://imgur.com/a/X37mjct
And whilst I was at it, I did the USB-C in the back as well next to the 12V and the 230C sockets
Parts: 3G5035954 + 3G0863916C + connector
Wiring is very easy, I cheated a bit and connected T4/1 and /4 both to the +75 from the 12V socket.
U42 is listed as the position, but U37 is the way to connect it --> https://imgur.com/a/HMCKJu0
giannis20vt
Post by giannis20vt »
Fasten you seatbelts guys he started....
Nice mod. Personaly i prefer the non touch version, i find the touch buttons a little bit annoying because they don't have feedback.
I understand. I prefer the optics of the newer unit and I'll leave it on AUTO and 22 degrees. The old one looks like from a golf mk5.
The wife on the other hand... :mrgreen: seat heater, temperature, defrost...
OEM VW 18x8 'Monterey' alloy wheels with winter tires
3G0601025Q
18x8J ET44 with 235/45R18 wheels for winter
TPMS sensors 5Q0907275B
Some small stuff done (no pics):
3G9867871 cover for luggage compartment
5Q0953569B + 5Q0972726 slip ring for heated MFSW
000071213D dynamic hub caps
3G1061500A rubber mats front and rear
000073900 bags for wheels
The great Slavik helped me out with my MFSW upgrade, from the 5G0 R-line wheel to the 5H0 R-Line touch wheel with heating.
MFSW 5H0419089x + airbag 5H0880201J
Slip ring 5Q0953569B + connector 5Q0972726
Wiring:
:!: There are also slip rings with index C and part number 459. These have different wirings.
i.e.: T14/5 LIN to BCM is not needed for my car
Furthermore, updated the MIB2.5 from 5NA035042A to 5NA035022B with DAB+.
OEM privacy shades installed: 3G9064365
I have had them in all my cars, I'm always very pleased with the result.
VCDS mod for DRL with tail lights, slightly by accident... But looks good!
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,adapted from,not active ,to,Daytime running lamps
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,adapted from,not active ,to,Daytime running lamps
Parking lights:
DRL:
New R-Line logos, to replace the 4Motion logo's that I think are a bit too much...
3G8853688 3G8853689
3G9853687C rear logo to replace the Passat and the 2.0 TSI 4Motion on the boot for the same reason.
Installing the J938 module for Easy Open (kick to open) inside the rear bumper, only for vehicles with Kessy and electric tailgate.
3G0962239E antenna
3G0962243C module
3G0962283A bracket
4H0973704 connector
Some zipties to keep it in place...
Still to do:
change the button in the rear lid
change the 6D boot electrics module
wire it all up
patil
Post by patil »
I think for easy open the control module need to be parametrised?
And I've read somewhere that there is a downside of easy open feature. During car wash.. if you start cleaning rear bumper.. magic may happen :?: :mrgreen:
Probably, I kept locking and unlocking my Polo all the time when cleaning the door handles. The key (pun intended) is to store the keys out of reach of the vehicle when washing.
I got myself a brake kit from the Audi TTS 8S 2.0 TSI.
The front calipers are 4-pots for 340mm (same size) and the rear setup is identical. Just red calipers.
