iichel wrote: Tue Feb 20, 2018 3:42 pm
i was probably looking at esp8.2i but you need esp9.0i.
pin 12 of the 38-pin connector to the ABS unit goes to pin 4 of the 6-pin connector of the push button.
pin 5 of the 6-pin connector of the push button goes to a +15 (ignition switched 12V, pin 28 blue/black wire of the ABS connector)
pin 6 of the 6-pin connector of the push button goes to a ground point, i.e. connect it to the dash cross member
pin 3 of the 6-pin connector of the push button goes to the button illumination signal (i.e. grey/blue wire in the T28 pin connector of the door wiring loom)
On further testing, it turns out that only the front windows & mirrors close. The rear windows don't go up for rain closing (however they do work on comfort function)
Also, is there a way to enable/disable rain closing from the IC (maxi-dot)?
raghav.rithvik wrote: Wed Mar 14, 2018 2:06 am
Good Evening
Can anyone tell me about this part no. 6RG 051 232.Dear Said that this is VW radio which is made by Blaupunkt model no Philadelphia 835 .Sir please tell me can it work as RNS 510 .(like navigation ,direction, audio and phone function etc in MFD.).
