UK-POLOS.NET - THE VW Polo Forum • UPGRADING BCM 6R - Page 10
Page 10 of 14
Re: UPGRADING BCM 6R
Posted: Tue Feb 20, 2018 5:45 pm
by ciclo
raghav.rithvik wrote: Tue Feb 20, 2018 1:03 pm Update : managed to get the mirrors working as intended using 1400B3 for RHD mirror.
viewtopic.php?f=56&t=69603&start=105#p529605
:wink: ... :lol:
Maybe you did not know that I solve problems before they happen. :mrgreen:
Posted: Wed Feb 21, 2018 2:53 am
by raghav.rithvik
iichel wrote: Tue Feb 20, 2018 3:42 pm i was probably looking at esp8.2i but you need esp9.0i.
pin 12 of the 38-pin connector to the ABS unit goes to pin 4 of the 6-pin connector of the push button.
pin 5 of the 6-pin connector of the push button goes to a +15 (ignition switched 12V, pin 28 blue/black wire of the ABS connector)
pin 6 of the 6-pin connector of the push button goes to a ground point, i.e. connect it to the dash cross member
pin 3 of the 6-pin connector of the push button goes to the button illumination signal (i.e. grey/blue wire in the T28 pin connector of the door wiring loom)
Thank you! I will try this today & revert.
ciclo wrote: Tue Feb 20, 2018 5:45 pm
:wink: ... :lol:
Got confused with the next post! Anyway, everything works as intended! Thanks!
Posted: Wed Feb 21, 2018 11:14 am
by ciclo
Thanks to you for sharing your experience, it'll be very useful for others.
Posted: Thu Feb 22, 2018 2:36 am
by raghav.rithvik
.... T28 pin connector of the door wiring loom)
Got the switch working. Thank you
Posted: Mon Mar 12, 2018 5:32 am
by raghav.rithvik
Could you guys help me with the coding for rain closing? Is it possible with my BCM?
Posted: Mon Mar 12, 2018 6:28 am
by ciclo
raghav.rithvik wrote: Mon Mar 12, 2018 5:32 am Could you guys help me with the coding for rain closing? Is it possible with my BCM?
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 081215 03  37  0059
   Coding: 0368DD
Try it with this new coding for RLS.
0668DD
Report the result.
Posted: Tue Mar 13, 2018 6:38 am
by raghav.rithvik
Thanks. Rain closing works with the provided coding.
Posted: Tue Mar 13, 2018 7:00 am
by ciclo
Perfect. 8)
Posted: Wed Mar 14, 2018 2:06 am
by raghav.rithvik
On further testing, it turns out that only the front windows & mirrors close. The rear windows don't go up for rain closing (however they do work on comfort function)
Also, is there a way to enable/disable rain closing from the IC (maxi-dot)?
Posted: Thu Mar 15, 2018 7:55 am
by ciclo
raghav.rithvik wrote: Wed Mar 14, 2018 2:06 am Also, is there a way to enable/disable rain closing from the IC (maxi-dot)?
No.
Posted: Thu Mar 15, 2018 9:24 am
by raghav.rithvik
raghav.rithvik wrote: Wed Mar 14, 2018 2:06 am On further testing, it turns out that only the front windows & mirrors close. The rear windows don't go up for rain closing (however they do work on comfort function)
Anything to make the rear windows go up?
Posted: Thu Mar 15, 2018 11:21 am
by ciclo
000020 Test this coding in both rear WRMs.
Set the comfort function with the window switches.
Good luck! (it would be a miracle if it works)
Posted: Mon Mar 19, 2018 9:38 am
by raghav.rithvik
ciclo wrote: Thu Mar 15, 2018 11:21 am 000020 Test this coding in both rear WRMs.
Coding out of range
Posted: Thu Mar 22, 2018 2:58 pm
by govindsharma
Good Evening
Can anyone tell me about this part no. 6RG 051 232.Dear Said that this is VW radio which is made by Blaupunkt model no Philadelphia 835 .Sir please tell me can it work as RNS 510 .(like navigation ,direction, audio and phone function etc in MFD.).
Thank you.
Posted: Thu Mar 22, 2018 7:02 pm
by ciclo
