iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865829061700DO Dataset Number: V03935260TT 0001
   Shop #: WSC 30389 123 56831
   ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06556B5948A5C8FA15F-8053
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170615  042 0607
   Serial number:         170629234856
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S4Y17M06D29H19M25S21
   Coding: 06A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01 0032
   Serial number: 14 04 2017  10001690
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1714382PB
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000070188699
   Humidity sensor: interior:
   Blower 1 for left front backrest:
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0158736
   Blower 1 for left front seat cushion:
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Blower 1 for right front backrest:
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0145994
   Blower 1 for right front seat cushion:
   Subsystem 10 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0146336
to
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q1 937 084 B    HW: 5Q1 937 084 B
   Component: BCM MQBAB HO  H44 0512
   Serial number: 02102311001826 Dataset Number: V03935364YD 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 3829D5A172D16E0AD73-806D
   Coding: 0F4DFD
   Coding: 06A8DD
   Light switch:
   Alarm horn:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0096892
and
from
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0448732144 Dataset Number: V03935260TX 0001
   Coding: 1F20200723
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E25C3B950F5503A1DF-806B
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8001216
to
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0577965047 Dataset Number: V03935344GX 0001
   Coding: 1F20200723
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   VCID: 48C9A56102311E8AA73-801D
Slavik helped me to install the new 5Q1 BCM and Q kessy module. With ODIS it was an easy job. i'll have to correct some adaptation channels manually in the BCM but so far it works like a charm. The new Continental BCM has some different channel names compared to the old Bosch BCM.
Finally an error free scan after a while.
The front/rear motor for the passenger seat kept losing its basic setting, so I replaced it with a version with a Hall sensor --> https://www.ebay.de/itm/256332816720
(officially it's not a replacement part)
Image :arrow: :arrow: Image
Address 06,3Q0 959 760 D,recoded (Long Coding-exp),from,
001000020000150081C480808080000000008181000000F400 to
001000020000150081C481808080000000008181000000F400
(30389/123/56831),Thursday,18,January,2024,14:19:56:11868
SLV with Hall Sensor
Thursday,18,January,2024,15:45:34:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: WVWZZZ3CZJEiichel  License Plate:
Mileage: 174100km-108180mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42
          44 47 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7
VIN: WVWZZZ3CZJEiichel   Mileage: 174100km-108180miles
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---    CVN: B7DB7878
   Coding: 091D003A2476050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259J.rod
   VCID: 313FE88591ABBF4290D-8065
   VINID: 9E69EAAAA0D3A9A54008518520274044B7
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5297
   Revision: 06454104    Serial number: TFK01706160335 CVN: 000099EF
   Coding: 0014
   Shop #: WSC 05311 115 00065
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1C612931E629222AD3B-8049
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Q0 614 517 FM    HW: 5Q0 614 517 AH
   Component: ESC           H62 0755
   Revision: 00000000    Serial number: 61907000000236
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 015F7845618BEFC220D-8055
   Coding: 1F20200723
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0024
   Serial number: Y0006PKA28228 Dataset Number: V03935285VX 0001
   Coding: 001000020000050081C481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3C21C9B146E9422A33B-8069
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 3G8 907 044 T    HW: 3G8 907 044 T
   Component: Climatronic   H10 0221
   Coding: 12020024104411011115500D0018592A
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
   ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
   Air quality sensor:
   Humidity sensor: exterior:
   Rear air conditioning block 1:
   Subsystem 3 - Part No SW: 11A 907 049 A    HW: 11A 907 049 A
   Component: E265 KPH SH  H02 0183
   Serial number: G04S01.11.2100972191
   Coding: FFFFFF
   Coding: 0F4DFD
   Coding: 06A8DD
   Light switch:
   Alarm horn:
   Subsystem 8 - Part No: 3G0 963 345
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 L    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0074
   Serial number: 000308417617172 Dataset Number: V03935315EN 0001
   Coding: 8A79267951
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 59EF7025A99B970208D-800D
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V315
   Coding: 351F5FFBDFFFCF28979F813681500D80000000000099000032
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CBA65D0F2F11F2AE9-8013
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 25061741350001 Dataset Number: V03935290WM 0001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD0A549DB770228D-806D
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
   Component: Airbag VW21   006 0721
   Revision: --------    Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
   Coding: 98FCC0C0008000005C5400CF000800000065
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0E45537920D580BAADF-805B
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0031T01500
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Component: BeltPretRevFR  106 1032
   Serial number: 3G1857706G0185R01460
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 606 17
   Component: SideSensor_Df  008 0887
   Serial number: 357000000000507D3628
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 001 806 17
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000008D140C62J
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Dr  301 0148
   Serial number: 3510091305210000000U
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Pr  301 0148
   Serial number: 352002F2F52100000009
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 406 17
   Component: FrontSensor_D  304 0149
   Serial number: 3550040279610000000%
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 KT    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0265
   Revision: FF035035    Serial number: 20170828500092 Dataset Number: V03935250KY 0001
   Coding: 8410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 C
   Component: KOMBI         406 4191
   Coding: 07AD0898FE8C000C01887F0F3001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2A0DFFE9BC7DCC9A517-807F
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0080
   Coding: 9309
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS.rod
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000276932
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5502
   Serial number: 06071710802132 Dataset Number: V03935278KN 0001
   Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
   GVL: 01DE3C0008000600C0FC80000006CC0010000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFEBD177F9932569-802B
   Generator:
   Component: 4-00-03-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL  H03 0219
   Serial number: 17036218123222100161
   Coding: AF0B00
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H10 9070
   Serial number: 5131394104
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H26 0780
   Serial number: 0066181
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3003201700010095
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00017.05.17 Dataset Number: v1260x015G0 0000
   Coding: 0601
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
   VCID: 4CC199711649F2AA83B-8019
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 17000160250002
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71BF2885512BFF42D0D-8025
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
   Coding: 001000020000150081C481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide.rod
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000591782366  Dataset Number: V03935345YL 0001
   Coding: 62954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000606636104
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
   Coding: 00351A20D200028200011000
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 4ACD9F691C3DEC9AB17-801F
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5082
   Dataset Number: 8V0909852AA 0001
   Coding: 93070000
   Shop #: WSC 00015 115 00319
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
   ROD: EV_AMPMst16C3Gen2ALPI_VW48.rod
   VCID: 6B833AED73071592EA1-803F
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 01071710801233 Dataset Number: V03935339UR 0001
   Coding: 000000060100035207007F010A0000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BD2789542DC45A297-8027
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
   Coding: 00351020DE00028200011000
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 49CFA065193BE782B8D-801D
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 022 B    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1367
   Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
   Coding: 02840201000000005111110200880A301F0106E4012004009F
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_VW37.rod
   VCID: 323DE78994AD845AE97-8067
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1915518
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 809 PC    HW: -----------
   Component: ECE 2023  --- 0310
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0446947174 Dataset Number: V03935259HF 0001
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 42DDB749240D34DA797-8017
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG069231 Dataset Number: ----------
   Coding: 01840200E70F200004314817
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0265
   Revision: --------    Serial number: 31344982200000 Dataset Number: V03935262CS 0001
   Coding: 02A8
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 46D5AB59082508FA55F-8013
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1421
   Serial number: E80320003220200 Dataset Number: V03935411EY 0001
   Coding: 0004019821FAC02888DF14001020004000218000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW38.rod
   VCID: 3635DB9978C5987AC5F-8063
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
   Coding: 000410200100028000001000
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS005 0350
   Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: V03935218DJ 0001
   Coding: 208040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 372BD69D7FCF6172DE9-8063
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 16753B191805787AE5F-8043
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0003
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 02:44, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
Thursday,18,January,2024,15:49:04:11868
www.Ross-Tech.com
VIN: WVWZZZ3CZJE025658   License Plate:
VIN: WVWZZZ3CZJE025658   Mileage: 174100km-108180miles
Readiness: 1110 0000
   Coding: 0014
   Coding: 1F20200723
   Air quality sensor:
   Coding: FFFFFF
   Coding: 0F4DFD
   Coding: 06A8DD
   Light switch:
   Alarm horn:
   Coding: 8A79267951
   Coding: 80000D
   Coding: 80000D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 8410
   Coding: 9309
   Generator:
   Coding: AF0B00
   Analog clock:
   Coding: 0601
   Coding: 62954640
   Coding: 93070000
   Coding: E02400
   Coding: E02400
   Data carrier:
   Coding: 02A8
End----(Elapsed Time: 02:41, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
raduss
Drives: Passat b8
Post by raduss »
you're crazy 8)
I know... :oops:
Electronic childproof locks (doors and windows) from Superb 3V / Touran 5TA. It requires a different switch and rar locks, a few wires and coding. Very nice feature to have.
Driver door switch 3G0959857B/C WHS
Rear door locks 5TA839015 /5TA839016 T/AA
Now the driver door switch can lock the child lock and the windows, both or individually. Before you had one button for the windows and manual locks.
Switch differences:
lock differences, you can really see the bulge with the actuator motor:
both locked:
ad by skoda:
More info with coding, wiring, more pics: https://imgur.com/a/Bqgy1OT
In the diagrams for the MQB models - Arteon, Tiguan, Golf - V11 is wired in the same way.
The 'logical' thing is that if the system is present is to make it work or at least try to... although what is really interesting in this matter is to know what the final result will be once you install the missing electronic components on your 5Q1 BCM, obviously the SW is present.
It is highly likely that the missing electronics to power the non-existent pin 46 on your new retrofitted BCM is due to headlight washer systems no longer being fitted to current VW models.
I imagine that there will be some correlation between the luminous capabilities of the new 'LED headlights' used by the new VW models (with 5Q1 BCM), light assist systems, the interference of the headlight cleaning fluid, changes in regulations for the use of this system, or savings in production cost.
I disabled V11 (BCM Adapt ...255) on the 6R (bixenon). Most of the time the headlights got more dirty than cleaned due to the small layer of dust that settles over time.
I like to clean the windshield frequently with the wiper system, but as you all know every five cycles the headlight washer system is activated, which is not necessary at all without extreme weather or environmental conditions.
I didn't even think about installing the headlight washer system on the G7.5 when installing the Matrix headlights. Maybe I would have thought about it if it were possible to activate the headlight washer system from a switch 'other than the Stalk/lever'.
Personally, I always found the headlight washer system ineffective and even absurd for several well-founded reasons...
In cases of extreme weather or environmental conditions, it is better not to drive to avoid having to be rescued by rescue services. Watch videos on YT to see how smart some humans are at getting from point A to point B in extreme conditions. 😁
On both the Polo and the Passat, I made a 'long press for SRA' construction. If the lever is pulled longer than about 1,5 seconds, the headlight washers go. Otherwise only the headlight correction: windscreen washers.
Slavik already offered to do the soldering, only thing needed now is the electrical components. It would be interesting to try and make it work.
giannis20vt
Post by giannis20vt »
iichel wrote: Tue Feb 13, 2024 7:14 am On both the Polo and the Passat, I made a 'long press for SRA' construction. If the lever is pulled longer than about 1,5 seconds, the headlight washers go. Otherwise only the headlight washers.
Wow, that's brilliant. :idea:
Good luck with that project.
With a hot air soldering iron, flux, soldering paste, and a minimum of experience it is very easy to solder electronic components on PCBs.
The most important thing for perfect solders is 'Flux'.
Maybe and for learning purposes you can watch some related videos on YT and buy all these things (as cheaply as possible) on Ali.
Later, and if everything goes well for you and you like soldering, you can buy better components/materials to reach an expert level.
it's a really simple construction using vcds:
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,1 ,10 <-- set to 1 = every cycle
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,1500 ms,10 <-- set to 1500ms for the long press duration
giannis20vt
iichel wrote: Tue Feb 13, 2024 10:04 am it's a really simple construction using vcds:
Great information. Thanks
VAS_ODIS.E (current status on my Golf).
[VO]_Scheinwerferreinigung:
[LO]_Scheinwerferreinigungsanlage: [VN]_not_installed
[LO]_SRA bei Waschwassermangel: [VN]_active
[LO]_Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung: 10 ... to_1.
[LO]_SRA Verzoegerungszeit: 0 [UN]_ms ... to_1500.
[LO]_SRA Waschzeit: 400 [UN]_ms
[LO]_SRA Einweichpausenzeit: 2,000 [UN]_ms
[LO]_SRA Nachwaschzeit: 400 [UN]_ms
[LO]_SRA Pausenzeit: 0 [UN]_ms
[LO]_Waschen: [VO]_Keine_Spannungsanforderung
[LO]_Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung: 0
GOOGLE translator 🤷‍♂️😊
[VO]_Headlight cleaning:
[LO]_Headlight cleaning system: [VN]_not_installed
[LO]_SRA in case of lack of washing water: [VN]_active
[LO]_Number of front washer operations per SRA activation: 10
[LO]_SRA Delay time: 0 [UN]_ms
[LO]_SRA Washing time: 400 [UN]_ms
[LO]_SRA Soak pause time: 2,000 [UN]_ms
[LO]_SRA post-wash time: 400 [UN]_ms
[LO]_SRA pause time: 0 [UN]_ms
[LO]_Wash: [VO]_No_Voltage_Requirement
[LO]_Init offset front washer actuations per SRA activation: 0
