HAVE YOU SEEN ANYTHING LIKE THIS???????
Gareth_GT_Hatch
GK engines are like hens teeth Id imagine. The MH head is (As far as I know) the same casting as all 1.3 heads (including the G40) So the head isnt the problem. A better cam (such as a GT cam or an after market one is the way to go. As well as a better carb like that one overmind is selling. And seeing as youve already properly sorted your exhaust system (judging by your list on the other topic) thats all youll need to achieve 75bhp I bet. Oh and there is a manifold on the mk3 1.3/1.4 Spi that might be of use to you (I think it has bigger ports) I have one somewhere but Ive never compared it to the one on my mk2
GroovyCarrot
- Sponsor
Gareth_GT_Hatch
yeah thats what I meant, you dont need any more exhaust mods, just a better carb and a cam.
GC, Im not sure if the MH cam is any better than a HZ one. You would need to have them both side by side to examine lift/duration. A GT cam is definately better than both though.
bear in mid that if you mk2'ers buy a cam that was designed for a mk3 you will have to sort out an electric fuel pump as mk2 camshafts drive the fuel pump whereas mk3s have electric fuel pumps as standard.
GroovyCarrot
- Sponsor
Yeah, I was mulling this over earlier, realised that a carburetted mk2 75bhp gt like the one at the start of this post will have an old type head with the mechanical pump on the other side, and a fuel injected mk2/3 gt will have an electronic pump.. although, it may be something I consider later, I was thinking about adapting a mk3 fuel injection system anyway... it'll go on a back burner for now though
Gareth_GT_Hatch
yeah Ive been contemplating converting to spi as well. I almost have all the bits, (apart from the loom, ecu, injector, and fuel pump) Oh well maybe I dont have most of it then.
I have all the fuel lines though. and the lift pump But wiring all that stuff in would be a bit of a nightmare. Its less difficult on our cars as wever just snuck in under the wave of revisions. so theres brackets for fuel pumps and the ecu and the like...
GroovyCarrot
- Sponsor
Can't see it being too much of a problem.. although I'd choose a time when I didn't need the car for a couple of days before I went ahead and did it
Just realised I'd have to find a way to plug the fuel pump driveshaft hole in the cylinder head.. that damn fuel pump seems to cause all the problems
I assume the SPI wouldn't work properly without the electric pumps?
Gareth_GT_Hatch
id just leave the fuel pump on. No worries about hole plugging then! I doubt the spi would work off a mechanical pump as it doesnt pump at high enough pressure.
Youd also need a mk3 exhaust to fit the lambda probe. Something which slipped my mind before.
But I have a spare one of those as well
(or I will have on thurs when I get my complete barningfield exhaust.
Tahrey1043
if you could do the same upgrades on a 1.0 as you could a 1.3, with like-for-like proportional improvements, you'd see about 60 horse by the end of the day - worth considering if you can't find a 1.3 but have the other things handy...?
(plus the 1.0 should be more rev-happy ... oversquare chamber shape
GroovyCarrot
- Sponsor
As far as the exhaust goes I think I'd probably just cut a hole in mine and get someone to weld a nut to it for the probe to thread into.. un-environmentally friendly as the decat pipe may be, I don't terribly want to strangle the 45bhp any further with a cat
1.0 more rev happy? How do you figure that one? I've always assumed it to be less rev happy than the redline on the coupe s clocks tells me just trying to be safe and not blow it up.. more rev happy could be interesting
Although, the power really falls off after about 5,000 rpm anyway..
Gareth_GT_Hatch
shorter stroke of the 1043 means they can go round that bit quicker. But the AAU engine is an awful engine to try and modify, has smaller valves and ports than all the other engines, 1.0 mk2s have the same head/valves/ports as 1.3s so im told (steve has one on his 90bhp mk1)
Decat mod of a mk3 pipe only costs about £35.
GroovyCarrot
- Sponsor
Ah, but a drill, a nut and a friend with welding kit costs 20p and a pint for his trouble
Student financial logic comes heavily into play in such matters
So.. what would I need:
* Inlet manifold, tb etc
* Electric fuel pump (two of them, aren't there?)
* ECU
* Wiring loom
* Downpipe / lambda probe
What have I missed? I've never delved into anything so sophisticated as electronic injection, I've only just got a handle on carburettors, so I know very little about all this stuff..
* ECU
* Wiring loom
Gareth_GT_Hatch
GroovyCarrot
- Sponsor
