Page 2 of 2
Posted: Fri Oct 06, 2006 12:19 pm
by olop_chris
After seeing it in the flesh under Si's bonnet, it is really good stuff! Where did you say you got it from?
Mines two pipes at the moment! I would prefer the piping black though!
Posted: Fri Oct 06, 2006 1:16 pm
by Si_GTi
If I recall, it is brake ducting hose with a 69mm diameter? Found on Demon Tweeks
here
Posted: Fri Oct 06, 2006 2:22 pm
by olop_chris
£45.71 (inc VAT)
Ok now i remember you saying! lol
Posted: Sat Oct 07, 2006 2:18 pm
by loud
u can get ducting on ebay for like a tenner.
i just removed the part of the original cold air feed with the valve in it and what a difference, the valve was ruining it like. You hear the air suck like 50 times louder now lol
Posted: Sun Oct 08, 2006 11:41 am
by Mouse_GTI
How did you get rid of the original feed? It looked really awkward. Does the ducting just go down in place of the original feed?
Posted: Sun Oct 08, 2006 11:46 am
by olop_chris
To get rid of the original wing pipe, it does look really awkward....thats why you slide the power steering fluid up and out of the bracket (just push it up, and it will come out) then you can move it, and get to the bolt with ease to unscrew it, then pull the original pipe out from the wing!
Posted: Sun Oct 08, 2006 4:33 pm
by D-Dub
Need to do this to mine! Just took the ducting off and tested it, sounds much better. Does anyone know the size of the ducting?
