Urgent help required
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
this is the wrong section but i need help now so it'll get noticed here, it can get moved or whatever.
I just fitted my bmc and all was well when i started, but i revved it a couple of times and now my cars idling at 2000rpm
what the fook?
also, on here:
where mouse has connected his ducting to his original cold air feed on the right hand side of the original bit mine has a hose going to like the heat shield over the manifold, whats that hose for? it looks like his is taped up where it used to be
J-GTi
Post by J-GTi »
Disconect your battery for about 30min that should clear it up
loud
Post by loud »
that's what i nearly did, thank god i never
guy on clubpolo told me to check the throttle cable and sure enough it was catching on the screw on the jubilee clip
vdubit
Post by vdubit »
How would us gti owners know that? We dont even have a throttle cable! :lol:
loud
Post by loud »
i didn't know i did either until he told me to check it :P
vdubit
Post by vdubit »
Maybe the gti does as well then, i only say it doesnt as a lupo gti doesnt. I spose it could do. Will have a look later!
Petrified
Sponsor
Post by Petrified »
twas me! :P
, I had the same problem on the lupo. same engine 1.4 AFK which uses the throttle cable. they replaced this in late 2000/2001 with the AUB engine which is drive-by-wire.
much perfer the cable throttle as you get no delay from pressing the pedal to getting the throttle response that you get in the early dwb engines!
loud
Post by loud »
btw i found out why the polo 16v bmc is more expensive than the gti, they are identicle except for some strange reason the 16v comes with a bmc crankcase breather filter :P
loud
Post by loud »
what i can't figure out is why it sometimes makes a roar and sometimes it doesnt, most the time it just sounds normal
occasionally when i drop it in to fourth and boot it i get a huge roar, which sounds totally amazing, but then when i do exactly the same thing again i get no roar really...it's strange
vdubit
Post by vdubit »
Sounds like your using the original intake pipe from the wing. Throw this away as its well restrictive.
olop_chris
Sponsor
Post by olop_chris »
vdubit wrote:Sounds like your using the original intake pipe from the wing. Throw this away as its well restrictive.
This is true.
I found some decent piping at last, so finally got rid of my original intake pipe from the wing last night. Sounds about 10x better now, feels slightly better too :)
Petrified
Sponsor
Post by Petrified »
do you have a pic of what your using now?
i still need to sort it out on mine.
no point in taking the original pipework out if you've just got a pipe stuck in the engine bay sucking in hot air.
olop_chris
Sponsor
Best one ive got really for now.
Si_GTi
Moderator
Post by Si_GTi »
Mine:
Courtesy of Prash 8)
And no, the oil crankcase breather pipe does not feed back into the BMC filter it just looks that way on this pic :)
J-GTi
Post by J-GTi »
Si, Do you know where prash got that air feed hose from?
