UK-POLOS.NET - THE VW Polo Forum • Suspension Problem - Page 2
Page 2 of 3
Posted: Tue Mar 20, 2007 12:26 am
by Arnoldo
Yes my. I can get a pic if it would help explain. Both front and rear on the drivers side are just off the arch rather than the passenger side is about an inch lol.
Sports undercarriage? Explain. U got a solution for me? Both those bits I havent got on my car. Are they needed?
Posted: Tue Mar 20, 2007 9:45 pm
by itsjustme
the undercarriage is a problem, that have many of my friends. I don`t know why but with a winding carriage you can correct it :D but over one Inch is to much.
can you take a picture of your compression leg??
Posted: Tue Mar 20, 2007 11:11 pm
by Arnoldo
Ok compression leg being front shock? Right? This is costing me more and more money and people dont have a clue what the problem is !! Ekk. Thanks so far "itsjustme"
Posted: Wed Mar 21, 2007 10:37 pm
by Arnoldo
Bump.; Problem is still here lol
Posted: Wed Mar 21, 2007 10:51 pm
by Ollie_R
Arnoldo, those metal plates you have left over are meant to go in between the front top mount and the top of the spring, as it has the recess.
Look at the pic below, and you'll see what I mean:
Can you see where it sits?
And the washer is just a random, don't worry about it. Once everything settles, it should even out.
Posted: Wed Mar 21, 2007 11:26 pm
by Arnoldo
Its been settling for about 2-3 weeks m8 lol. Does it take so long for it to settle? Also we used original vw stuff rather than that plate. Would it be ok?
Posted: Wed Mar 21, 2007 11:55 pm
by Ollie_R
It takes a while for it to settle, longer than 2-3 weeks anyway. I'm currently running without that plate on my 60/40 kit, and there's no apparent problems.
Posted: Thu Mar 22, 2007 11:02 pm
by Arnoldo
Did urs ever learn over to one side?
Posted: Thu Mar 22, 2007 11:16 pm
by Ollie_R
No, it hasn't so far.
Posted: Fri Mar 23, 2007 3:36 pm
by Arnoldo
Ollie can u circle exactly were those parts go as im gettin them looked at in the morning by a mechanic. It would be brill if u can. Also are they for the front?
Posted: Fri Mar 23, 2007 4:02 pm
by Ollie_R
Yeah, they're for the front. They're the front spring seats, and they go in between the front spring and the front top mount.
The arrow shows the front spring seat.
Posted: Sat Mar 24, 2007 1:22 am
by Arnoldo
Legend m8. Ill let u know how it goes tom.
Posted: Sat Mar 24, 2007 1:56 pm
by Arnoldo
Ollie tried fitting these this morning but the actual spring cup is too small for the springs :S
Posted: Sat Mar 24, 2007 2:15 pm
by Ollie_R
I'm sure it goes there. If it doesn't fit, just don't use them, I don't. My car is fine without them.
I'm sure once it settles, everything will rectify itself (and look pimp :wink:).
Posted: Sat Mar 24, 2007 2:19 pm
by Arnoldo
Ollie can u do me a favour and take a picture of ur front suspension look from under the arch and also one from under the bonnett. Cheers m8.
