Suspension Problem
Suspension Problem
See below..
Answer to Number 2 is yes it will mate, i know on mine it has helped alot, but again i suppose every Garage that does this is different ie, the one i use is the s**t, Most up to date Hardware and Software to fixx all problems, but there is only a limited number of these in the uk, and i have one in edinburgh lol
Sounds Like it aint Been Fitted Properly, Either that or Parts are wrong in the Kit, if i was you, i'd be putting the OEM Suspension back on mate!Arnoldo wrote:Ok have yet ANOTHER problem. The drivers side rear is near enough touching the arch and the other side is about an inch off it !! Any ideas :S This kit has been a disaster
Aha, you have had the EXACT same prob as me, I to bought the EVO (I beleive) kit off PhilJ and went for an 80mm drop on 15's. Steering was seriously out, wheels lined up and the steering was pointing to the left, when driving, straightened up the wheel and she pulled to one side. Went to Elite in Rainham and they sorted the prob out. Apparently, the guy in Elite was saying the rear end of a polo is generally slightly out and cannot be adjusted, if I could post the picture of the computer printout I got of the before and after, it would make people chuckle. They charged me £50 to do toe in/out, camber and castor. Drives as sweet as anything now. On another note, I found PhilJ extremely helpful after I had fitted the kit, he sounds like an alright bloke.
Ok got the car lowered recently with jacksons 60mm springs and shock kit. Put everything together and shes leaning over on the drivers side now. The wheels and tyres are 15/195/50 and are bbs ra's. Anyone have any ideas? As there was no instructions with the kit, it was simply a guessing game. Only things I can think of would be springs on the wrong way. E.g theres a small end and a large end to the spring. Also there were a couple of bits we didnt use on the kit. These are shown below in the pic.
Anyone got any ideas?
P.s - The steering and camber are now fixed.
![Image](http://img385.imageshack.us/img385/3255/pa302016ia8.th.jpg)
![Image](http://img465.imageshack.us/img465/3896/pa302017ow5.th.jpg)
![Image](http://img153.imageshack.us/img153/2817/pa302019jk9.th.jpg)
I hope I understand you correct. Your car is leaning to the drivers side after you lowerd?!?
Its a problem which have many polo`s with a sport undercarriage.
the littel ring on the pictures looks like the ring which came between the spring carrier and the end of the plunger.
The big think looks like a spring carrier from the rear axle...
