again, nice work
Polo GTi - FAQ - Common Modifications and Advice
frankeygsxr1000
Re: Polo GTi - FAQ - Common Modifications and Advice
Headlight Dipped H7
Headlight Main H1
Headlight sidelight W5W
Indicator PY21W
Side indicator WY5W
Interior 42mm 242 11W
Boot 39mm 239 5W
Numberplate 39mm 239 5W
Brake/Indicator/Reverse Light/Fog Light P21
Some more useful bits!
Headlight Main H1
Indicator PY21W
Side indicator WY5W
Boot 39mm 239 5W
RE: Cruise control.
On the GTi is it really just a case of a MK4 Golf stalk and VAG-COM to enable it on the ECU? I've read of people fitting this to Lupo GTi's and there seems to be additional cabling to connect to the ECU. Is it really as simple as stated in the original post?
MalakianCigaro
I was wondering if somebody could point me in the direction of some pics of taking the rear VW badge off taking it apart and spraying the center body colour, I'm sure i've seen a step by step somewhere, I have searched and as of yet haven't found anything. Any help would be appreciated.
Thanks.
Leon
Thanks.
Leon
- Tim_GTi
- Post Whore
Dead easy man, just pry it off, then cut the plastic tabs on the rear that keep the badge together.MalakianCigaro wrote:I was wondering if somebody could point me in the direction of some pics of taking the rear VW badge off taking it apart and spraying the center body colour, I'm sure i've seen a step by step somewhere, I have searched and as of yet haven't found anything. Any help would be appreciated.
Thanks.
Leon
Once the badge is off you'll understand exactly what to do.
Then just glue them back together. I used a glue gun for this, and B&Q foam tape to stick the badge back to the car.
MalakianCigaro
Thanks very much for the reply, I will give it a go.
myfastpologti
This is an awesome guide, very informative!
Its not really THAT simple. Yes you need a mk4 golf stalk, which then needs to be wired (well.. soldered) to the ECU. Then its a case of threading this all back into the car, and plugged up into the stalk. Then a simple vagcom procedure. Awesome GTI still do this for £160. (Cant remember if that inc. VAT or not)PD wrote:RE: Cruise control.
