clutch kits
roycwho
Post by roycwho »
I double checked on my invoice
The price should be around 68pounds, not 60pounds
roycwho
Post by roycwho »
Yes, this is right, the pressure plate do not line up with the engine locating lugs.
My mechanic drilled a hole, or holes to line up. He said this was only a simple operation with zero bad effect of operation. 8)
I also changed the clutch cable. I remembered the day I picked up my car, I even didn't know how to operate.....the clutch was just too smooth and light :D
Bit of an update.
The clutch listed previously does not fit!
The three locating holes on the pressure plate do not line up with the engine locating lugs.
Awaiting a call back from Sachs!
I hope Tigz could have a answer.
wulee
Post by wulee »
roycwho wrote:Yes, this is right, the pressure plate do not line up with the engine locating lugs.
Cool! Thanks for your information.
BTW, i order mine from a Hong Kong Sachs dealer @HKD1500 (~GBP97) :)
andyniceday
Post by andyniceday »
just for anyones reference the eurocarparts sachs kit
641440620 (sachs part number 3000.581.001)
fits fine even though the invoice may say not for polo gti
Tim_GTi
Post Whore
Post by Tim_GTi »
How much did it cost you Andy?
andyniceday
£89.61 kit price
£122 Total price ( inc VAT and £15 delivery )
polo_gti21
Post by polo_gti21 »
andyniceday wrote:just for anyones reference the eurocarparts sachs kit
im just a lil lost at this point is the part no. above correct andy or does it still need the drilling of the pressure plate????
just done a quick search for this kit and the one for the gti is listed.
http://www.eurocarparts.com/ecommerce/S ... esults.asp
andyniceday
above part number is correct and required no drilling for my ARC engine, my mechanic said it went on fine and dandy, im sure he would have told me if he had to mess about with it :D
polo_gti21
cheers andy.
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh cheers for that Andy. Just a shame I didnt have this info two weeks ago!
andyniceday
just reference my "houston we have a problem" thread
some slight doubts in my mind now so dont go buying anything yet... :(
Tim_GTi
Post Whore
Post by Tim_GTi »
Just got myself a SACHs kit from GSF.
Is there anything else I should've ordered with it? Or does everything come with it? (release bearing?)
I've ordered a clutch calbe seperatley also.
wulee
Post by wulee »
The Sachs clutch kit 3000.581.001 also fits fine for my ARC engine.
The kit comes with the release bearing and the only extra that is needed for clutch change is the "guide sleeve" (085141181).
The ball bush (6N0711135) and bellow (6N0711167A) of the gear selector linkage may also be renewed at time of clutch change, this correct the marked free play on my gear stick.
The Sachs clutch is much lighter than my previous two stock clutch (Valeo)that i've got previously from stealer . :D
Tim_GTi
Post Whore
Post by Tim_GTi »
Yep, the SACHS kit is ALOT smoother than the OEM replacements from VW.
Both engine codes use the same clutch so it will fit both 8)
Tigz
Post by Tigz »
wulee wrote:
Tim_GTi wrote:
wulee wrote:
Oh really, do u mean Sachs part no 3000 581 001 is incorrect?
I think so, read what Tigz says on the next page of that thread........
Tigz wrote:Bit of an update.
:x
I hope Tigz could have a answer. :(
Sorry mate, missed this.
Sachs didn't seem that interested, I also had rill new holes to fit the clutch.
Bit of a faff really :(
