stud conversion
bbspolo
Post by bbspolo »
no if u want 2 be quick at pitstops u buy some center lock hubs! Like i have on my cosworth (and what lewis has on his f1 car 8) )
Sadly it limits what wheels u can run! :cry:
tomo87
Post by tomo87 »
i have cosworth engine mounts!
bbspolo
Post by bbspolo »
LOL bit random but well done u! :lol:
tomo87
Post by tomo87 »
RS500 ones to be exact
bbspolo
Post by bbspolo »
sorry 2 p*** on your fire but all cosworth engine mounts are the same :cry:
Only difference is the 909 solid engine mounts but they are welded 2 the chassie
tomo87
Post by tomo87 »
bbspolo wrote:sorry 2 p*** on your fire but all cosworth engine mounts are the same :cry:
ah i see, im only going on what i got qouted on. i was under the impression the RS500 ones are a little more solid?
bbspolo
Post by bbspolo »
depaends what u mean by rs500?
The 500 race cars all used the 909 solid weld in engine mounts (cant see how u could use them on anything other than a cosworth!)
The rs500 road cars used standard engine mounts like the saf cosworth, 3 doors and escos.
However many have been uprated 2 solid mounts (there are loads of companys who sell them) so maby thats what u have?
tomo87
Post by tomo87 »
ye thats the badger, got an uprated one!
right....stud conversion
hahah
bbspolo
Post by bbspolo »
o yer bit of topic! lol
anyway studs only do it if u rearly struggle getting your wheels on and off!
even then i would just sujest pratice!
kinder
Post by kinder »
it was that that amde the wheel fall off as they cross threaded the bolts and it has screwed up thehub and wheel bearing so im puttin new on both sides while im at it and im only doin the stud conversion a sim fed up with balancing the wheel with a 6mm spacer on so just doin one stud so that the space will sit on better
Tim_GTi
Post Whore
Post by Tim_GTi »
kinder wrote:it was that that amde the wheel fall off as they cross threaded the bolts and it has screwed up thehub and wheel bearing so im puttin new on both sides while im at it and im only doin the stud conversion a sim fed up with balancing the wheel with a 6mm spacer on so just doin one stud so that the space will sit on better
The way I see it though is that can still happen, plus you have the added issue of keeping both sides of the stud proper tight.
