iPod Housing
Overseer
Post by Overseer »
How'd you get it through there then?
I'd prefer not to drill to be honest
Tim_GTi
Post Whore
Post by Tim_GTi »
IIRC I unscrewed the obvious bolts (just the ones you can see in and around the glove box), and after removing the radio, fed it the lead down towards that direction until I saw it poking out.
This was going back to the first week I bought the car. And I knew nothing about it, or how to do it. So it's an easy task mate.
Overseer
Post by Overseer »
Cheers Tim. I'll have a go, when I get the kit.
Overseer
Post by Overseer »
Right, I've bought and recieved an XCarLink, and are going to have a go at installing it tonight (weather permitting).
Being a complete novice, I'm in need of some advice...
The (limited) instructions say I need to connect the Earth cable to a suitable earthing point and suggest the body of the stereo. The cable is like a loop thing; so I just wondered how I connect this to the back of the stereo?
Help?
Just use a splice connector onto the chunky brown cable going into the plugs on the back of the radio :)
Ill get that pic of mine tomorrow - promise!
JPR_polo_gti
Post by JPR_polo_gti »
Overseer
Post by Overseer »
Well I've done mine now. Tried to take apart the glovebox, but failed. Ended up cutting kinda by the hinge - doesn't look too bad. I will post a pic after I finish work this afternoon.
The glovebox itself doesnt come apart :( Its all one-time moulded together
I might get that pic tonight haha
Overseer
Post by Overseer »
Yeah, I noticed lol :lol:. But from what Tim wrote, I assumed you could.
lol it does suggest that now i re-read it :P
Overseer
Post by Overseer »
Mine comes out sort of where Tim suggested. Problem was the cable was quite thick (due to it going to the contol module of the XCarLink), might not need to cut for a thinner cable.
Will post a few pics after work.
Overseer
Post by Overseer »
Pics as promised (cam phone, sorry):
If no one is aware of the XCarLink, it allows you to connect and control an iPod used the standard headunit; and best of all you and still use the CD changer. Works flawlessly, very impressed; even has a 3.5mm jack to connect an MP3 player. Has a lot of cable though, so kind of makes my glovebox look a mess.
I would have put the control box and cabling behind the box, and just had the ipod lead through personally - its the same as the VW one in design.
Overseer
Post by Overseer »
Behind which box?
the glovebox - id shove all that excess wiring and the control box over the back - there is loads of space up there.
